Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-25-2019, 01:33 AM | #1 |
Remember me?
Drives: BRZ Series.Blue
Valve springs: GSC vs Supertech
I'm putting together the last pieces for my built FA20 but I'm stuck on two options for valve springs, GSC beehives (GSC-5056) or Supertech 74lb dual springs (SPRK-1002-BRZ). Im shooting for 18-25 psi with 10:1 pistons. Any help is appreciated.
04-25-2019, 07:42 AM | #2 |
Rust bucket enthusiast
I've been hearing about GSC in the tuning world longer than Supertech. I don't know that either will have a benefit over the other. Who wouldn't want a beehive?
The Following User Says Thank You to DarkPira7e For This Useful Post: | glorydays (04-25-2019) |
04-25-2019, 11:01 AM | #3 |
Drives: 2016 Subaru BRZ
Supertech has been around for a while. I've mostly seen them used on Honda's, I don't think you have anything to worry about if you decide to use them. I would go with whatever fits your budget.
12-22-2019, 04:49 PM | #4 |
Drives: '13 Whiteout
I'm doing the recall would it be worth it to put any of these higher performance springs
in? Im NA but may go FI later on. If I stay NA is there any benefit? |
12-22-2019, 05:05 PM | #5 |
If you're not performing the recall personally, they will not use aftermarket springs. The recall work is to replace 1 part number with another, not to just change the spring arbitrarily
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | Lantanafrs2 (12-22-2019), TommyW (12-22-2019) |
12-22-2019, 05:23 PM | #6 |
01-01-2020, 04:25 PM | #7 |
pessimistic skeptic
I am getting the GSC 5756 springs installed in a week. I will let you know
My springs failed although my car was outside recall. I don't think it is FI but the service recommended something better than stock springs for FI. Since I have voided warranty long ago with installing FI, I decided not to get stock spring installed again. And, since my car is only boosted 9 psi (JRSC), GSC 5756 seemed most suitable. |
The Following User Says Thank You to mrg666 For This Useful Post: | Lonewolf (01-01-2020) |
01-07-2020, 02:13 PM | #8 |
pessimistic skeptic
GSC 5756 is working ok for now.
The Following User Says Thank You to mrg666 For This Useful Post: | tomm.brz (01-07-2020) |
01-11-2020, 04:44 PM | #10 |
Motorsports
Drives: 19BRZ PP, 16 M4
GSC all day, the beehive spring is a far superior design.
Douglas W.
01-27-2020, 01:58 PM | #11 |
pessimistic skeptic
I was feeling uneasy with pushing the engine in the beginning. Since last week weather is warmer and I am feeling more confident about the engine. The GSC 5756 springs made a big difference in power. Engine is revving up much more eagerly. Idle sound also changed quite a bit which, I think, is normal with different springs.
The Following User Says Thank You to mrg666 For This Useful Post: | tomm.brz (01-27-2020) |
01-27-2020, 02:06 PM | #12 |
Drives: brz 2017 hksv2
i'm noticing the same.. i still haven t revved over 5000 yet but it "feels" much solid how it revs , but i think the bit heavier forged rods i put, contribute too.. also the noise of valvetrain at idle is a bit different, I confirm
The Following User Says Thank You to tomm.brz For This Useful Post: | mrg666 (01-27-2020) |
01-27-2020, 02:25 PM | #13 |
pessimistic skeptic
I thought about replacing the short block with a built one while having the springs installed but ... cost and and my decision to stay at this boost level, I didn't. How much was the additional cost to replace the rods, if you don't mind telling?
01-27-2020, 03:02 PM | #14 |
i threw a rod so for me was a mandatory thing
my mechanic doesn t count hours for this kind of job, i replaced oem short block, installed rods in it, new head gaskets, arp head studs and gsc springs and the whole rebuild costed me around 1500€ (1700$ more or less) of labor I threw the rod while at 4000 rpm and less than 0.5bar of boost, but I guess the racing fuel and hugely high ignition timing were what destroyed it |
Similar Threads | ||||
Subaru SB19-001 NEW VALVE SPRINGS FOR FA/FB ENGINES | Trap63 | Issues | Warranty | Recalls / TSB | 0 | 02-12-2019 02:08 AM |
My engine blew up four years ago, now they recall the valve springs | Obsidiank | Issues | Warranty | Recalls / TSB | 12 | 01-02-2019 01:47 PM |
Valve springs | Gunman | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 11-21-2018 02:49 PM |
King Bearings (mains and rods) GSC Valve Springs | Nick B-rz | Engine, Exhaust, Bolt-Ons | 2 | 07-23-2017 10:55 AM |
Kelford Cams FA20 High Performance Valve Springs | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 26 | 09-26-2013 08:58 AM |
