Old 04-20-2019, 06:58 PM   #1
Sharpilot
Drives: 2013 Scion FRS
Engine oil leak driver side
So I've been trying to figure out for months where this leak is coming from. It's not too major as to make my oil go down but it does get annoying when the engine is hot and you can smell oil burning. I'm not sure if it's the timing chain cover or that plastic piece where a sensor is connected. Anyone know the name or part # of this piece?
Note: No I can not take it in for warranty because there are no dealerships that sell this car where I live so all the work has to come out of me.
https://imgur.com/a/2HeIHyw
https://imgur.com/a/wQNzMdD
Sharpilot is offline   Reply With Quote
Old 04-20-2019, 07:05 PM   #2
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
I was going to say a bit normal but that's a hell of a lot. By chance did you do an oil change recently?
Sent from my PH-1 using Tapatalk
ybotspawn is offline   Reply With Quote
Old 04-20-2019, 07:16 PM   #3
Sharpilot
No it's def not from an oil change. I've had this issue ever since I got the car in September 2018 but just haven't been able to find out where it's coming from. I just had to clean the area and wait for it to accumulate again.
The Following User Says Thank You to Sharpilot For This Useful Post:
ybotspawn (04-20-2019)
Old 04-20-2019, 07:19 PM   #4
ybotspawn
ybotspawn's Avatar
What's throwing me off is why its all over the place, the hose, the cover, the sensor. Do you have access to a lift?
Old 04-20-2019, 07:26 PM   #5
maslin
Benz Tech
Drives: 2017 BRZ Premium
Judging by the unevenness of that sealant I’d guess the valve cover has been off. No telling where it’s from, could just be from the cam sensor?
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Old 04-20-2019, 07:27 PM   #6
ybotspawn
ybotspawn's Avatar
Isn't that sealant supposed to be grey?
Old 04-22-2019, 07:55 AM   #7
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I have the same issue. I took it in for the recall thinking it was the timing cover and would be resealed and fixed after. It's not, make me think it's coming from somewhere else. Oil level doesn't budge, just annoying and dirty.
BigTuna is offline   Reply With Quote
Old 04-29-2019, 05:10 AM   #8
Legionsk88
Legionsk88's Avatar
Drives: 2015 WRB Limited BRZ
I had the exact same issue. I ended up taking it in and getting all the seals on the front of the engine replaced. It seems to have fixed the issue so far, had the work done a good 2 months ago.
Legionsk88 is offline   Reply With Quote
Old 05-03-2019, 10:07 PM   #9
TYinhouse
Drives: Scion FRS Firestorm MT
Same here, got the leak fixed during the recall, it was from the timing cover.
TYinhouse is offline   Reply With Quote
Old 05-03-2019, 10:39 PM   #10
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
The seals on that timing cover and cam carrier/cover are SLOPPY.
Wash it and let it idle, see where the oil initially comes out from. When everything's oily it's hard to tell what was oily first.
Oil leak? Front driver side shadow_772 Issues | Warranty | Recalls / TSB 11 11-01-2021 06:34 PM
Driver side valve cover gasket leak solidONE Issues | Warranty | Recalls / TSB 59 02-22-2021 12:52 AM
Oil Leak on driver side EINSTEIN562 Issues | Warranty | Recalls / TSB 3 08-09-2020 12:16 PM
Driver's side engine oil seepage radroach Issues | Warranty | Recalls / TSB 3 06-18-2017 05:55 PM
oil leak, drivers side, front of engine carbonBLUE Issues | Warranty | Recalls / TSB 41 10-02-2015 11:51 PM
