Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-04-2019, 12:01 PM | #1 |
Rust bucket enthusiast
Anyone Using Stock STI Injectors?
I've been searching exhaustively, so I feel comfortable asking this here. Is anyone using blue or pink STI injectors? They are in near unlimited supply, and can be had far cheaper than new injectors.
If they require modification, what is involved? Seems like they just may need a spacer. I am not looking for feedback on IF I should do this. I'm asking for the sake of asking, as I may be doing. If I had my car currently I'd just check and see. Ok go. |
04-08-2019, 01:54 PM | #2 |
Whooo, I guess that's a no. Not surprised. I'll document my efforts, whether or not I can get them to work for me.
04-29-2019, 09:52 AM | #3 |
Drives: scion frs 2015
not going to work your going to need a tune
07-02-2020, 08:45 PM | #4 |
Drives: Boosted 13 bra
Would also love to know if any other injectors work there tons cheaper then brz specific
07-02-2020, 09:02 PM | #5 |
I ended up using them and had no issues. Just needed to fabricate a spacer for the rails.
Made about 330whp using them |
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | Bonburner (01-09-2023), whataboutbob (12-17-2022) |
07-02-2020, 09:38 PM | #7 |
The only advantage was that I had them from a bugeye I owned years ago. I'm going to be buying ECUTEK's 750cc injector package so that I have injectors that aren't 15 years old in my new build
12-17-2022, 03:54 AM | #9 |
Drives: 2013 JDM ZN6
sorry to bump old thread. Jsut curious do you need to mod the adapter or its' plug & play ? any other modification require to fit these injectors?
12-17-2022, 01:07 PM | #10 |
Had to make little spacers so the rails could seat properly. Plug and play otherwise
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
12-22-2022, 12:16 AM | #11 |
12-22-2022, 07:37 AM | #12 | |
I didn't bother cleaning or changing anything when I threw them on. They worked flawlessly, I switched to ID1050x injectors because my goals changed. I trusted these injectors because they were my mine to begin with and I know they ran fine before I pulled them
12-23-2022, 04:18 AM | #13 | |
12-23-2022, 06:52 AM | #14 |
LMGTFY
Drives: 13 FRS, 91 Miata
Similar Threads | ||||
Stock Frs Injectors 60k miles | LetterVi | Engine, Exhaust, Bolt-Ons | 2 | 07-16-2018 08:20 PM |
WTB: Stock MAP sensor, and stock port injectors | Agent_D | Want-To-Buy Requests | 2 | 05-25-2016 05:08 PM |
WTB: Stock Port Injectors | asphaltkyle | Want-To-Buy Requests | 0 | 03-23-2015 03:57 PM |
Anyone try ID2000 injectors on stock ECU? | Revolutions Performance | Software Tuning | 14 | 03-26-2014 01:10 PM |
