Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
03-03-2019, 06:09 PM | #1 |
Drives: 2013 Limited Subaru BRZ
First start after 4 and a half months
First off, I want to apologize if I am posting this in the wrong section it seemed like it would be the most suiting. So, yesterday I had replaced my headers, overpipe and front pipe all with aftermarket parts and I already had a catback on it, so now I have a full exhaust system . Now to my part where maybe i'm just bugging out because the car makes different noises changing so much with all the new exhaust components. I tuned it stage 2+ on the OFT and started it up, mind you its been sitting in my garage for 4 and half months because its winter here in the Northeast. So it started right up no problems at all idle was a little low at times trying to adjust to the tune at times but never stalled. So what had me worried is while it was warming up I popped the hood to make sure everything was kosher and all the sudden I started hearing a little ticking noise not to the beat or idle of the engine though. It was coming from the driver side engine on top somewhere it sounds like. I was thinking maybe just a lifter tick? Fuel pump? Injectors? Not really sure but yeah haven't started the car in a while nonetheless so that could also play a factor possibly just not used to the sounds yet maybe lol. If anyone has any ideas on what it could possibly be feel free to share! Thank you in advance.
03-03-2019, 08:19 PM | #2 |
Is the gas in the tank the same 4 1/2 months old? Fuel pump not happy or maybe injectors...
03-03-2019, 08:52 PM | #3 |
Rust bucket enthusiast
May have been lubricating things still. When it sits for that long, everything goes bone dry. Let it run for a half hour and tell us if it's still there. Could also be a belt or pulley, but terribly unlikely.
03-04-2019, 10:31 AM | #4 |
The Following User Says Thank You to Jcas For This Useful Post: | gravitylover (03-04-2019) |
03-04-2019, 10:32 AM | #5 |
Yeah thats true, I didn't even drive it yet either so im sure im just paranoid and itll go away once it runs more and actually drives and gets everything all lubricated and what not.
The Following User Says Thank You to Jcas For This Useful Post: | DarkPira7e (03-04-2019) |
03-04-2019, 10:53 AM | #6 |
New exhaust heating up, expanding and making a ticking sound. All exhausts do it but new ones can be really loud as everything finds it's place. It may have sounded like it was coming from the top of the engine since the noise bounced around a bit. The fact that it was not tied to the engine speed rules out most of the engine components.
Could also just be the style of header you installed. Some of them make some weird sounds.
The Following User Says Thank You to Tcoat For This Useful Post: | LimitedSlip (03-04-2019) |
03-04-2019, 02:29 PM | #7 |
Yep, like said, I'd suggest you go fill up with fresh gas and then take a long drive (an hour or so). Maybe the car just needs to "shake it out" after its hibernation and the new exhaust parts need a chance to settle in.
humfrz |
03-04-2019, 07:25 PM | #8 |
Drives: 2016 Subaru BRZ
Gas isn't going to go bad in 4 months, I have had motorcycles sit for a year with a full tank and start up like normal after taking them off my trickle charger.
The Following 2 Users Say Thank You to Trueweltall For This Useful Post: | Jcas (03-05-2019), soundman98 (03-05-2019) |
03-04-2019, 07:50 PM | #9 |
Sarcastic SOB
Then why is it recommended to use stabilizer for winter storage? There must be SOME degradation but stabilizer is also a lubricant which helps upon bone dry startup no doubt. It also quiets the crickets.
03-04-2019, 08:27 PM | #10 |
It's recommended so you spend your money on their product, it's marketing 101. Just top off your fuel tank before you store your car, if it's under a year you'll probably be a-okay. If it's outside in direct sunlight being exposed to a greater range of temperature fluctuations you will have more hydrocarbons evaporate and possibly more condensation getting in (e85 and blends).
03-04-2019, 09:45 PM | #11 | |
義理チョコ
Here's someone else's video clip capturing the moment where it switches over. [ame]https://www.youtube.com/watch?v=IBB3GREGPSc[/ame]
03-05-2019, 08:06 AM | #12 | |
The Following User Says Thank You to Jcas For This Useful Post: | Ultramaroon (03-05-2019) |
03-05-2019, 08:06 AM | #13 |
03-05-2019, 08:07 AM | #14 | |
Tags |
brz, engine, headers, noise, tick |
Similar Threads | ||||
FS: STI engine start push start OEM plug and play | sokol | Interior Parts (Incl. Lighting) | 5 | 06-13-2019 02:12 PM |
Half trd parts from the factory? | Grips&slips | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 12-22-2018 07:26 PM |
C-West Half-Lip | 636 | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 04-09-2014 11:08 PM |
WTB: TRD Intake Air Box (Front Half) | FyeaFRS | Want-To-Buy Requests | 0 | 01-23-2014 11:20 AM |
Half Inch Drop? | Ray_32 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 08-28-2013 05:44 PM |
