Old 02-04-2019, 07:59 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Trunk won't open
Even the physical key won't get it. I loaded in some groceries near the inside switch, and I'm guessing I bumped and caused it to engage. The interior release button and remote won't do it. I even got out my spare key and tried it. No luck. I installed an LED dome light with the gizmo to regulate polarity recently, but it worked a few times after that.
I don't see any easy access from inside the car.
Qwimby1 is offline   Reply With Quote
Old 02-04-2019, 08:06 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
By spare, do you mean the valet key? That doesn't work in the lock. The regular key does.
Qwimby1 (02-04-2019)
Old 02-04-2019, 08:18 PM   #3
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
So to recap, you put the regular key in the lock on the trunk kid and it wouldn't open?
Old 02-04-2019, 08:44 PM   #4
Qwimby1
Thumbs up
Well, I'm used to cars that you get out to crank to start, so this keyless stuff is new to me. There's a little key embedded in the fob that I removed and put in the trunk-key slot. Is that the valet key? It's all I have and it doesn't open the trunk. It can only go in one way because of the plastic piece at the top, and it won't turn in the lock.
The Following User Says Thank You to Qwimby1 For This Useful Post:
Ultramaroon (02-04-2019)
Old 02-04-2019, 08:48 PM   #5
Silverz
Drives: Black frs
What about the button inside the car by the driver’s seat?
Silverz is offline   Reply With Quote
The Following User Says Thank You to Silverz For This Useful Post:
Old 02-04-2019, 08:53 PM   #6
Qwimby1
'14 Monogram Edition with keyless ignition. The PO gave me two electronic sending-unit fobs that have a little metal key that slides out and will fit in the trunk slot, but unless I'm doing something wrong, won't open it.
Old 02-04-2019, 08:55 PM   #7
Qwimby1
You mean the on the panel to the left and below the steering column? Doesn't work. It did till yesterday.
Old 02-04-2019, 09:01 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Hate to say it, but sounds like you are doing something wrong. Physical key opens lock. Did you try your physical (metal) key in the door?
Old 02-04-2019, 09:06 PM   #9
Silverz
Drives: Black frs
Old 02-04-2019, 09:20 PM   #10
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
You can squeeze your hands in the crack to the left and right side of the back seat, feel around for the pulls you can grab them and pull them through the cracks, pull both and you can get the seats down from the inside.
VIP BRZ is offline   Reply With Quote
The Following User Says Thank You to VIP BRZ For This Useful Post:
Old 02-04-2019, 09:23 PM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Just flop the rear seat down, push the valet button, and then push the trunk button. (flop the seat by lifting up on the button's bezels on the top of the rear seat, they will pop off, then pull up on the buttons)
I LIKE TIRES!
The Following 3 Users Say Thank You to Leonardo For This Useful Post:
Qwimby1 (02-04-2019), Spectral Entity (02-14-2019), Tcoat (02-04-2019)
Old 02-04-2019, 09:26 PM   #12
Qwimby1
I GOT IT! Oh, the wisdom that resides on this board! There's a very short little plastic handle on the metal key, and I was afraid to use much turning force, but after watching YouTube I saw I had to. Trunk is open and Valet lock reset. I'll try to figure out how to post thanks for all.
Old 02-04-2019, 09:53 PM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
You're not the first one who was afraid to turn the key. Glad you got it figured out.
Old 02-05-2019, 12:35 AM   #14
humfrz
And that's OK. Just remember to set the brake, gas and spark and you do remember what NOT to do with your thumb -
humfrz
Trunk won't pop open Reflex Issues | Warranty | Recalls / TSB 36 01-02-2021 04:16 PM
Trunk does not open BRZ.Omar Issues | Warranty | Recalls / TSB 4 05-21-2018 08:50 AM
Trunk Won't Open with Either Key Fob or Dash Trunk Release Ehokana Issues | Warranty | Recalls / TSB 15 04-08-2017 04:22 PM
Help Can't Open Trunk Xerious Scion FR-S / Toyota 86 GT86 General Forum 3 04-13-2014 10:10 PM
Trunk will not open BAE Issues | Warranty | Recalls / TSB 14 06-04-2013 05:21 PM
