02-03-2019, 02:36 PM | #1 |
Drives: 2013 FR-S 6spd Whiteout
Mounting used tires... suggestions
I have a set of new wheels that I want to put on my car, but would like to mount the tires on my current wheels (conti extremecontact sport) onto them. The tires are less than a year old, but I’m having a hard time finding a shop that will mount used tires in the OC area. Is there a big danger in mounting used tires?
02-03-2019, 02:39 PM | #2 |
Drives: 2019 BRZ
Um are the wheels a different size than what the used tires are currently on?
I just did the same on my STI at a discount. The wheels were an inch wider so there's a bit of a stretch but they did mention there is a limit to where they wouldn't mount them (stock I'm 8.5, went to 9.5, their limit IIRC was 10). It looks kinda stupid, but I have over 80% tread life on them. Sent from my Pixel 3 XL using Tapatalk |
The Following User Says Thank You to jjlBRZ For This Useful Post: | tunami (02-03-2019) |
02-03-2019, 02:44 PM | #3 |
I bought the brz performance package wheels from another member, tire size is exactly the same. Every shop I’ve called said they don’t mount used tires. I haven’t tried discount tire yet.
02-03-2019, 02:46 PM | #4 |
Drives: 2019 BRZ
Uh... Then wtf. What tire shops are you going to?
This is just a swap, they shouldn't be hassling you unless there's a defect in your current (or tread life) tires, which they should be pointing out... Sent from my Pixel 3 XL using Tapatalk |
02-03-2019, 02:54 PM | #5 |
BAE
Drives: Asphalt FRS
Just pull up to any local mom&pop tire shop and they’ll do it. Usually $15/ tire to dismount, remount and balance.
But i recommend R compound if you cant find a shop in your area. |
The Following User Says Thank You to Decimus For This Useful Post: | tunami (02-03-2019) |
02-03-2019, 03:58 PM | #7 |
You are looking is all the wrong places.
Find a happy Harrys used and discounted tire shop. They are usually in a lesser part of town. They are going to help, but their balancing equipment is two generations old. |
The Following User Says Thank You to ls1ac For This Useful Post: | tunami (02-03-2019) |
02-04-2019, 12:12 AM | #8 | |
Tire Squad tiresquadautorepair.com 15199 Moran St, Westminster, CA 92683 |
The Following User Says Thank You to Thaeyo For This Useful Post: | tunami (02-04-2019) |
02-04-2019, 12:20 AM | #9 | |
humfrz |
02-04-2019, 12:47 AM | #10 |
[insert cool phrase here]
Drives: BRZ Premium
Pifff,
Nah it's just curtain tire shops.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
The Following User Says Thank You to Mr.ac For This Useful Post: | humfrz (02-04-2019) |
02-04-2019, 12:49 AM | #11 |
Drives: 2019 BRZ
It's not a problem in California, it's whatever shop OP is going to.
As I mentioned, I had my tires swapped to a 1 inch wider wheel in my STI a month ago at a Discount Tire. If anyone was going to give me crap it would been them. Sent from my Pixel 3 XL using Tapatalk |
The Following User Says Thank You to jjlBRZ For This Useful Post: | humfrz (02-04-2019) |
02-04-2019, 01:27 AM | #12 |
Discount tires, America's tire, and all of those big chains have a company policy of not performing certain tasks. Such as stretching tires, performing rotations on anything lower than 2-3/32", removing TPMS (even to just transfer...), tires older than 8-10 years, etc.
The Following User Says Thank You to Thaeyo For This Useful Post: | humfrz (02-04-2019) |
02-10-2019, 05:44 AM | #14 |
Drives: 2023 Toyota GR86 Trueno Blue
Check out Menos Tires in Downtown Los Angeles. They close at 10 pm everyday. The only bad thing is they are probably cash only.
https://www.yelp.com/biz/menos-tires...-los-angeles-4 |
Similar Threads | ||||
Mounting tires and different mounting equipment | BR-ZED | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 07-08-2018 11:41 AM |
Meaty tires suggestions for 17x8 35? | YamahaR86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 12-04-2015 12:24 PM |
New Rims and Tires! suggestions?? | Chase1996 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 11-27-2015 10:58 PM |
Mounting tires in the Bay Area | chiefshayan | Northern California | 3 | 09-14-2015 05:01 PM |
Mounting OFT? | JDsThatGuy | Software Tuning | 3 | 04-09-2015 10:49 PM |
