Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-09-2018, 02:58 PM | #1 |
Drives: WORKS CARB Legal Turbo BRZ
The WORKS "Dr. Jekyll" Valved Catback Exhaust
We are proud to formally introduce the WORKS "Dr. Jekyll" Valved Catback Exhaust!
[ame]https://www.youtube.com/watch?v=C2d2HWtvnDU[/ame] This active style exhaust is the first of its kind for the 86 platform! By utilizing a vacuum/boost operated valve; the driver is able to control the volume and tone of the exhaust on the fly. This is the perfect solution for your daily driver or dual purpose weekend track toy! When closed; the exhaust gasses pass through a straight through muffled section keeping the volume minimal (while also free flowing). In the absence of vacuum (for NA vehicles) or 5+ psi of boost (for boosted vehicles) The valve will open allowing for maximum flow! This is perfect for those of you who constantly get complaints from your neighbors for early morning cold-starts. Driving down the highway is no longer loud and drone-y! Just step on the throttle and hear the valve open to produce a nice throaty tone! - WORKS Team https://store.worksmotorsports.com/B...148.216-fi.htm |
The Following 7 Users Say Thank You to WORKS For This Useful Post: | churchx (11-09-2018), Code Monkey (11-09-2018), eastendraceshop (02-07-2019), humfrz (11-09-2018), jflogerzi (11-10-2018), JonAvalon (11-10-2018), Williampreza (11-09-2018) |
11-10-2018, 12:43 AM | #2 |
Very cool! Can this be done for an axleback at well?
2013 Series 10 FRS #553
11-10-2018, 01:42 AM | #3 |
Drives: 2014 GT86
I'd prefer manual operation though. After all, what operation will be auto-selected but what might be wished in cases of eg. high-speed cruising on autobahns? Or driver may have wish different mode at different moods. Even for track use, there might be tracks with strict local restrictions on noise. Manual mode switch also might be more failure-safe and make product cheaper.
11-10-2018, 02:52 AM | #4 |
Drives: 2013 Subaru BRZ Limited (Black)
This looks fantastic -- I've been waiting for this for a long time.
Unfortunately, from the looks of it, the muffler is a bit small. There's a good chance those with uncatted headers will still see a slight amount of drone on the highway, even with the valve closed. We really need this sort of system with the stock muffler in some ways. Curious to see videos! |
11-10-2018, 11:45 AM | #5 | |
02-07-2019, 05:55 PM | #6 | |||
While it can be done; the factory exhaust system pre-catback is relatively quiet. We have found that the most dramatic change is when paired with a non-resonated midpipe.
The Following User Says Thank You to WORKS For This Useful Post: | FRSBRZGT86FAN (02-07-2019) |
02-07-2019, 07:12 PM | #7 | |
Drives: 2014 GT86
For example if that cable can be routed through front of saloon - one might reuse sound tube hole in firewall. Maybe there are also other better fit/placed technological holes for use. Speaking of simple "light set" usable with stock exhaust i see in way of such: midpipe that allows fitting most of axlebacks (something should be done for it to be usable on both Kouki and Zenki due flange differences IIRC though (hmm, some "flange/mount adapters" on end of midpipe?)) with prefitted manual cutout with cable long enough to be routed through soundpipe hole, some mounting clamps for cable to underside of car, some switch/lever for mount in saloon. And here you go - relatively simple/cheap/light set that can be used with both stock & aftermarket axlebacks, maybe with some catbacks too if replacing their midpipe and if they reuse stock flange shape/position. BTW, product should also be relatively small/light (just midpipe vs complete catback/axleback), that should cheapen logistics (eg. shipping overseas). No welding required to mount, just replacing one exhaust bit, reliable enough, cheap enough (including shipping). Last edited by churchx; 02-07-2019 at 07:26 PM. |
02-07-2019, 08:18 PM | #8 |
Seņor Member
I am sure you could put some sort of electronic valve in the vacuum line that either held the vacuum or opened the line up to the air so you could manually override the exhaust valve.
1974 TA22 Celica
2013 86 GT |
Similar Threads | ||||
BRZ/FRS/86 "Dr. Jekyll" Axle Back Muffler | WORKS | Engine, Exhaust, Bolt-Ons | 14 | 10-24-2017 02:26 PM |
WTT Works ABM for Quieter Catback and a catted 2.5" front pipe | Keenercarguy | Want-To-Buy Requests | 0 | 02-15-2017 09:15 PM |
Perrin 2.5" resonated catback exhaust with 2.75" catless front pipe - $500 | Philly758 | Engine, Exhaust, Bolt-Ons | 7 | 07-08-2015 01:52 AM |
MAPerformance 3" catback/headerback in the works! | MAPerformance | Forced Induction | 10 | 11-15-2013 02:51 PM |
MAPerformance 3" catback/headerback in the works! | MAPerformance | Engine, Exhaust, Transmission | 6 | 11-14-2013 06:17 PM |
