Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
10-15-2018, 08:06 AM | #1 |
Drives: 17 Toyota 86
Uneven camber with the camber plates maxed.
Just as the title says I have bc coilovers and both camber plates are maxed out. But it’s very uneven. I have -3.2 on the passenger side and -4 on the driver side. Any idea why. I’ve tried doing my own research it couldn’t find anything. I got an alignment but one camber plate is still maxed out while the other side(driver side) has been adjusted to match the -3.2 degrees of camber on the passenger side
10-15-2018, 08:12 AM | #2 | |
Little Member
Drives: Bloo - The 13' BRZ
Sorry but you are technically maxed at the least common measurement between the two sides.
The Following 3 Users Say Thank You to yelsew For This Useful Post: |
10-15-2018, 09:00 AM | #3 | |
10-15-2018, 09:25 AM | #4 |
Full alignment specs (or picture of the print out)? Who installed the suspension, is everything properly installed and torqued?
10-15-2018, 09:43 AM | #5 |
I have the specs at home I’ll get pic when I get off work. But I installed the coils my self and made sure everything was done correctly. Everything felt perfect when I was on stock wheels. But once I got new wheels and tires and an alignment it been driving terrible. I have 18x9.5 et+22 paired with 225/40r18
10-15-2018, 09:47 AM | #6 |
Drives: '23 BRZ
10-15-2018, 10:04 AM | #7 |
Drives: 2014 GT86
- I wouldn't ever guide when aligning, just by position on camberplates. There are some variances between cars/parts, slack of mounts/bushings and as result more then possible differences between what is "max", "min" or specific position in between.
- Do camber on camber rig, where you see what alignment really is and dial to what you want to get to get those measurements right/even, ignoring, "what's measured on plates". - Camber may naturally increase also from extra (driver's) weight. Usually way less then 0.8dg for you though, imho more like 0.1-0.2dg. But if one is anal about that, one may ask suspension techs to dial alignment while one sits in car. - IF you have checked that tire pressures are even, and IF camber is even (as per alignment rig results, not by "maxed out") i'd suspect toe being out of whack / not even side to side or toe not properly set to track straight front vs rear. Worth remembering that on our cars changing toe changes also camber and vice versa, so hopefully they didn't just dial toe, and then separately camber, ignoring changes to toe from camber adjustment. But first thing i'd check (simplest/quickest/for free) would be tire pressures and if tires are mounted right (if tires are directional) on wheels. - btw, do you track car? -3, -4 .. camber sounds way too much for car IF that is only daily driven (0 to -1.5dg for camber sounds more reasonable for DD use). One may have more grip when cornering very hard and fast (if on public roads, then usually that means one most of a time going way above speed limits / hooning / endangering self & others) with more static camber, but this is too much for just daily driven. As side ill-effects for too much camber for driving type there might be less grip in wet/worse grip in straight line/car more tending to follow longitudinal road groves, and uneven tire wear (inside edge). |
10-15-2018, 10:21 AM | #8 |
Get camber bolts and balance the alignment that way instead of being uneven on the camber plates
The Following 5 Users Say Thank You to strat61caster For This Useful Post: | DylanJZA (08-21-2022), finch1750 (10-05-2022), Impureclient (10-15-2018), Racecomp Engineering (10-15-2018), wparsons (10-16-2018) |
10-15-2018, 11:28 AM | #9 |
I recommend setting your camber plates equally, and fine tuning with a camber bolt. This may help reduce your pull.
- Andrew |
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post: | DylanJZA (08-21-2022), finch1750 (10-05-2022), strat61caster (10-15-2018), wparsons (10-16-2018), x808drifter (10-16-2018) |
10-15-2018, 11:28 AM | #10 |
10-15-2018, 11:28 AM | #11 |
Did you leave it at -3.2 R and -4.0 L? Maybe that's why your car is pulling.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
The Following User Says Thank You to tyler_win_photo For This Useful Post: | strat61caster (10-15-2018) |
10-15-2018, 01:16 PM | #12 | |
Front left caster 6.1 front right caster 6.2 Front left toe. .02 front right toe .01 Back left camber -3.5 back right camber -3.4 Back left toe .10 back right toe .05 |
10-15-2018, 01:40 PM | #13 | |
Drives: 2017 Subaru BRZ Limited
Good advice, but if you notice he is on 18x9.5" wheels with 225 section width tires. Sounds like this guy is focused on going full stretched tire tilty boi, so I don't think he is worried about having things like traction or even tire wear or endangering others on public roads. |
The Following User Says Thank You to Tristor For This Useful Post: | kch (10-16-2018) |
10-15-2018, 02:07 PM | #14 | |
Drives: 2014 GT86
But wait, initially you mentioned -4 & -3.2 front camber. Did you dialed in more camber by yourself after this? Great chance to make alignment even worse, if done not on rig or with some extra measurement tools to show result of changes. |
The Following User Says Thank You to churchx For This Useful Post: | whataboutbob (09-26-2022) |
Similar Threads | ||||
KW coilovers and camber (without camber plates) | wparsons | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 07-09-2018 08:53 PM |
Uneven rear camber after lowering springs | Euphues | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 11-11-2015 08:27 PM |
FS: HVT Non-raising camber plates & WL camber bolts | trippinbillies40 | Brakes, Suspension, Chassis | 1 | 05-16-2015 09:00 PM |
17x9 +42 & 245/40 w/ RCE yellow and maxed camber bolts | jeebus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 09-30-2013 10:25 AM |
Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
