Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
09-20-2018, 02:21 PM | #1 |
Wes
Pentosin MTF has been discontinued
And I was just about to try it, having heard the good reviews. Just wanted to share in case anyone else wants to stock up on remaining units sitting around somewhere. I can't find any here in toronto
Instagram: @gt86ws
09-20-2018, 03:55 PM | #2 |
Drives: BRZ, STI, GT350R, Supra, 987.2
Give Synchrotech's, Mady by Torco, MTF a shot. Absolutely loved it in my built trans.
The Following User Says Thank You to VerusEric For This Useful Post: | rice_classic (10-11-2018) |
09-20-2018, 04:32 PM | #3 | |
6/22/12-2/6/24
So use at your own risk. If you want to stick to the manufacturer's suggested specs .. Motul 300 is a solid choice. Edit: ** that's engine oil ratings, forgot that transmission fluid ratings are a little different. Synchrotech is between Pentosin MTF-2 and OEM specs in terms of viscocity rating FYI.
09-20-2018, 04:38 PM | #4 | |
I'll be trying it in some other transmissions as well. 100% agreed though, this is *not* a weight recommended by OEMs. Use at your own risk. Thanks, Eric |
The Following User Says Thank You to VerusEric For This Useful Post: | Bonburner (09-20-2018) |
09-20-2018, 05:55 PM | #5 |
Wes
While personally for me motul is better than OEM, it wasn't that much better. And becomes less smooth as time goes on. It's only been about 8 months and it feels almost oem.
Instagram: @gt86ws
09-20-2018, 06:23 PM | #6 |
6/22/12-2/6/24
seeing as you're toronto .. I'm not surprised it's been getting notchier lately as the temperatures drop
09-20-2018, 06:28 PM | #7 |
Wes
Could be, so I'm hoping to change it out in october and have it somewhat better. Still won't be as bad as oem, even in below zero. Just a shame cause I was really looking forward to trying pentosin and now I can't. That other brand I don't think is available in canada.
Instagram: @gt86ws
09-20-2018, 06:33 PM | #8 | |
6/22/12-2/6/24
09-21-2018, 03:09 PM | #9 |
Drives: _
Had Pentosin for about 12k miles, but the dealer changed it to Subaru OEM transmission fluid recently while doing warranty work. Pentosin was GL4. Subaru gear oil is GL5. I'm gonna leave it in and see what happens. Not sure if I should believe in the whole GL5 vs yellow metals argument...
09-21-2018, 04:15 PM | #10 |
Drives: _
Just beware that this guy's smile is a little creepy...
[ame]https://m.youtube.com/watch?v=XHwULF-EdtQ[/ame] |
The Following 2 Users Say Thank You to chipmunk For This Useful Post: | Bonburner (09-22-2018), Sportsguy83 (10-06-2018) |
10-10-2018, 10:28 PM | #11 |
Drives: 2013 brz
And how does it compare to the Pentosin. The general consensus at least in Canada where it's cold is that Pentosin MTF-2 75w80 is the best for cold weathers - and it's really smooth. Higher and longer lasting session is another story of course and questionable.
10-10-2018, 10:29 PM | #12 |
Drives: 2013 brz
Also can't find it in Toronto...
10-11-2018, 07:26 AM | #13 |
Drives: 23 BRZ 15 Impreza
Red Line sells 70w/75, 75w-80, 75w-85 and 75w-90 GL4 gear oil.
https://www.redlineoil.com/gear-oil-...-transmissions |
10-11-2018, 07:52 AM | #14 |
Drives: Subaru BRZ
Try contacting Ivan at igarage, that's where I got mine.
Similar Threads | ||||
Pentosin FFL-4 vs MTF2 | takethecake | Engine, Exhaust, Transmission | 0 | 08-02-2017 12:04 PM |
Pentosin MTF2 | Calum | Engine, Exhaust, Transmission | 10 | 12-09-2014 07:43 PM |
Is this the right Pentosin mtf-2 | Raven604 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 07-09-2014 09:58 PM |
Looking for Pentosin MTF-2 in Ontario? | wtout86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 12-26-2012 07:07 PM |
