DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
DIY rear bumper air shield
Purpose is to create a wind shield when changing from a stock style suitcase muffler. This should stop air from getting trapped behind the rear bumper which creates a parachute.
I have the Borla exhaust which drops ~10lbs off the car. I know Borla has there own diffuser for their exhaust but it also adds ~8lbs back on. Negating the weight loss of the exhaust. For the record I want to make this out of a sheet of Carbon Fiber. I would need a 2' x3' sheet to make. 2x4 sheets are $300 for 1mm thick. Crazy! If anyone can find a sheet cheaper please let me know For this version I used Coroplast as the plate. I want lightweight,I have no idea how the coroplast will hold up. At least I can transfer the design if I find a better material to use Materials used all found at home depot Sheet of coroplast need at 2'x3' to work with Threaded rods Hollow aluminum tube nuts bolts washers, fender washers Total weight 1.5lbs weighted everything at ~2lbs then minus everything I didn't use ~.5lbs Parts on scale ![]() Rods bolted up to stock heat shield brackets. ![]() ![]() Now showing the aluminum tubes with fender washers giving a solid mount for the shield ![]() Installed! The plate tucks inbetween the rear stock diffuser and mount. used the stock rear diffuser attachments just switched out the black plugs with bolts. Also cut the rod bar after everything was mounted. ![]() An inside view ![]() Have it up all the way to the rear subframe. Plate sits on top or the LCA bolts ![]() Final pic! ![]() UPDATE POST 23!!
The Following 6 Users Say Thank You to SuperTom For This Useful Post: | EndlessAzure (03-24-2019), jordan7831 (08-11-2018), Mazikowski (08-10-2018), MJones_RB (08-17-2018), norcalpb (08-14-2018), sato (08-10-2018) |
How much clearance between the coroplast and the exhaust pipe? Like where the exhaust pipe goes through that cut out?
You can see from the last pic about 1/2" around the pipe area. Gave it more room with the coroplast so it doesn't melt. If I can find cheaper carbon fiber I would cut it closer so no air can't sneak up there
The Gunshine State
Drives: '14 BRZ Limited
For him it was, nice job Tom.
![]() Current DD: M235i |
The Following User Says Thank You to 8RZ For This Useful Post: | SuperTom (08-10-2018) |
Carbon fiber sheet at 1mm thick should be lighter and stronger than aluminum. im looking for at least a 2'x3' sheet. Where are you getting your measurements from please source. 1mm thick aluminum might not be strong enough Id have to hold it in my heads to check for flex |
home depot has sheets at .019" thickness which equates to about a .5mm I will check those out to give me an idea
#10 | |
#11 | |
A 2" x 3" by 1 mm thick piece of carbon fiber weighs .875kg or 1.93lbs. Just using densities of the materials. |
#12 | |
Well I read on the ecomodders forums many of them use coroplast to create flat panels under the cars. Although a rock bouncing up could easily punch a hole in it. Aluminum may be enough I just don't want it to flex crazy if a lot of wind goes through that area. But I don't think it has to be super solid stiff to work. I will test that aluminum sheet when I go to home depot tomorrow. And hopefully its not too heavy. |
#13 |
chicken tonight
I don't see any reason to change up what you have now. Looks great and will be just fine on the highway. It's already tougher than the bumper cover.
The Following User Says Thank You to Ultramaroon For This Useful Post: | SuperTom (08-10-2018) |
#14 |
Any idea what the heat resistance of that plastic is? I know the bumper is very close to the exhaust but the material properties I'm sure are different between the two plastics.
The Following User Says Thank You to D-rek07 For This Useful Post: | Ultramaroon (08-10-2018) |
What are my options for a rear bumper/bumper cover/etc that would fit TRD exhausts. | GNious | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 05-04-2017 06:07 PM |
WTB - Front Lip/Bumper Splash Shield OEm | Xplicit | Canada Classifieds | 0 | 04-10-2017 06:33 PM |
Rear Bumper Exhaust Shield | Ryan5x | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 08-27-2016 12:16 AM |
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision | n7011n | Exterior Parts (Aero, Lighting, Etc.) | 7 | 03-26-2014 04:46 AM |
How long to wait to put x-pel shield on after bumper re-painted? | Ammunition | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 02-21-2014 03:14 PM |
