Old 06-21-2018, 01:47 PM   #1
MJones_RB
MJones_RB's Avatar
Catch Can Mounting Opinion
I'm planning to install a catch can, a simple generic one that didn't come with any mounting hardware (like the Radium one). Normally catch cans (pcv valve ones) get mounted right next to the battery or right in the center attached to the braces. I had an idea to drill a couple small holes into the firewall, in between the battery and the wiring harness. Then i would use some threaded rivets to mount the catch can directly to the firewall.
I have to check to see if there's anything on the other side of the firewall (AC lines, heater, etc) that I could possibly hit. Just wondering if anyone has any other ideas or opinions to this approach before I start drilling. My buddy thinks I'm nuts for wanting to drill into the firewall.
Thanks!
MJones_RB is offline   Reply With Quote
Old 06-22-2018, 04:10 PM   #2
Sukisuki
Drives: 2017 Brz limited
Racer x fabrication makes a catch can and bracket that goes around that location without needing to drill into the fire wall.
if you look at the installation guide, he basically uses a a bolt with a flange to go through the rubber grommet thats already in the fire wall for a mounting point.
hope that helps.
Sukisuki is offline   Reply With Quote
The Following User Says Thank You to Sukisuki For This Useful Post:
MJones_RB (06-22-2018)
Old 06-22-2018, 07:52 PM   #3
MJones_RB
MJones_RB's Avatar
hope that helps.
Thanks!
Cusco catch can mounting point question dar3d3vil Engine, Exhaust, Transmission 4 05-24-2015 03:41 PM
Mounting OFT? JDsThatGuy Software Tuning 3 04-09-2015 10:49 PM
mishimoto oil catch can mounting jonbonazza Engine, Exhaust, Transmission 3 03-30-2014 02:13 PM
In your opinion.... ric342 Scion FR-S / Toyota 86 GT86 General Forum 9 01-28-2014 12:59 PM
Too low? Opinion pls hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-01-2013 10:11 PM
