Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
05-04-2018, 03:31 PM | #1 |
Drives: 2017 BRZ-Sport Tech
Sonax Wheel Cleaner ?
Has anyone ever used Sonax Wheel Cleaner on SBC (Special Brilliant Coating) RPF1 and will it strip the clear coat or do any damage to the actual coating of the wheel?
05-04-2018, 03:42 PM | #2 |
I have not but I have used many wheel cleaners on many types of wheels and have never damaged any of them. Those things are built to take it. Just follow the directions and all will be fine.
The Following User Says Thank You to Tcoat For This Useful Post: | OfficeWorker (05-04-2018) |
05-04-2018, 03:53 PM | #3 |
Drives: 2014 Porsche Cayman S
I have that wheel cleaner and I think it is citrus based and fairly safe to use on a variety of wheel types.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
The Following User Says Thank You to paiceyfan For This Useful Post: | OfficeWorker (05-04-2018) |
05-04-2018, 06:00 PM | #4 |
Drives: 2018 WRX STI
Is SBC a powder coating followed by a clear coat? If so, Full Effect is safe for both powder coatings and clear coats...it's pH neutral so you're also good if its anodized or polished. But it's definitely worth doing a test spot regardless.
While I've not used it on that specific finish, I would argue it is one of the safest wheel cleaners on the market (plus it has the added benefit of decon, which a lot of cleaners lack.) I've found that on a wheel that has been ceramic coated, this becomes a true scrub-free cleaning. IIRC, Plus is their stronger concentration of the original Full Effect. |
05-04-2018, 06:36 PM | #5 |
Drives: 2017 BRZ
Note, if your brakes have corrosive dust, Sonax will happily clean it all away and reveal the damage your brakes have done...
The Following User Says Thank You to cjd For This Useful Post: | OfficeWorker (05-05-2018) |
05-05-2018, 10:06 PM | #6 |
I'm really curious to see how well some of the ceramic wheel coatings work with the more corrosive dust that tends to come from the more aggressive track pads. With semi-metallic street pads, I am delighted with how well these coatings seem to protect the wheel's clear coat (and how much they simplify removal) - but I know some of the more aggressive compounds you fellas run on the track can be a LOT nastier, plus there's always the additional heat buildup, so I think it would be really interesting to see if the coating still delivered sufficient protection in this usage scenario!
05-08-2018, 04:37 PM | #7 |
Drives: 15 BRZ LTD, 05 FXT
Sonax rocks. I buy it by the gallon jug off amazon.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
05-08-2018, 05:04 PM | #8 |
Drives: FRS
05-08-2018, 05:11 PM | #9 |
Drives: Subaru BRZ
IIRC, Enkei says to use only mild dish soap and water for their SBC wheels but from googling around it looks like folks use many different products without any detrimental effects....
05-08-2018, 06:38 PM | #10 |
Drives: 2017 BRZ
Why would you apply it to brake rotors?
05-08-2018, 07:13 PM | #11 |
Drives: 86
CarPro Iron X on wheels and regular cleaning with Meguiars D140
05-09-2018, 11:00 AM | #12 |
Drives: FRS
05-09-2018, 11:55 AM | #13 |
Thanks
I find soap and water is good if you keep up with it. Don't like the harsh ones as i feel im breathing in cancer, they are very strong. Gloves and a scarf or n95. Look on tje bottls for the warnings to see if you should consider wearing PPE.
05-09-2018, 04:27 PM | #14 |
Drives: 2017 BRZ
Oh. I always have the wheels off the car when I use it. Is changing wheels a few times most weekends unusual?
Similar Threads | ||||
For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95! | DetailersDomain | Wheels and Tires | 2 | 03-25-2014 02:20 PM |
For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95! | DetailersDomain | Cleaning and Detailing | 0 | 03-25-2014 01:25 PM |
For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95! | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 03-25-2014 01:23 PM |
Save BIG on Sonax Full Effect Wheel Cleaner DetailersDomain.com | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 09-19-2013 10:06 AM |
Here's your shot to WIN A LOT of Sonax Full Effect Wheel Cleaner | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 01-18-2013 07:15 PM |
