Tracking / Autocross / HPDE / Drifting What these cars were built for! |
05-01-2018, 11:08 AM | #1 |
86Drive Challenge
Drives: 2017 BRZ PP
First things that fail tracking a performance package BRZ
The brake pads and CENTERCAPS.
The pads overheat and give a warped rotor feeling bad enough to end a track day; a little surprising on stock Michelin Primacy HP tires. The real surprise is the front center caps fell out but not the rears; my theory is the front brakes make enough heat to relax the centercap retaining tabs. This was track day #6 in the BRZ at Laguna Seca and the problems only started showing up when my instructor had me braking harder. Time to look into new pads! |
The Following User Says Thank You to mkodama For This Useful Post: | Tristor (05-01-2018) |
05-01-2018, 11:10 AM | #2 |
The Gunshine State
Drives: '14 BRZ Limited
I always remove the center caps anyway, because weight reduction!
Current DD: M235i |
05-01-2018, 12:25 PM | #3 |
Center caps are always supposed to be removed for track use.
And yes, OEM brake pads are always insufficient. I've posted thousands of times, that with even the most basic instruction, you will not have enough brake pad, Performance Package Brembos or not. Street pads belong on the street. Track pads belong on the track. PM me and lets get you a proper set of brake pads. |
The Following 5 Users Say Thank You to CSG Mike For This Useful Post: | mixxxx (05-01-2018), mkodama (05-02-2018), strat61caster (05-01-2018), Tristor (05-01-2018), Turbowned (07-27-2018) |
05-01-2018, 12:47 PM | #4 |
Drives: 2017 BRZ (Sold), 2023 GR86
You're rocking stock pads after six track days?!
I'm amazed that thing slows down at all at this point. Good to know though. I'll remove my caps next month. |
The Following 3 Users Say Thank You to mistople For This Useful Post: |
05-01-2018, 07:24 PM | #5 |
Drives: BRZ 2017 Pure Red, MT
Losing center caps is not specific to the brz. I lost both front caps on my previous car (rsx).
The front wheels were too hot to touch. I came to the same conclusion: The plastic get so hot that the tabs gets soft. Last edited by nico_rsx; 05-01-2018 at 10:59 PM. |
The Following User Says Thank You to nico_rsx For This Useful Post: | mkodama (05-02-2018) |
05-02-2018, 01:56 AM | #6 | ||
86Drive Challenge
Drives: 2017 BRZ PP
05-02-2018, 09:41 AM | #7 |
Drives: 987S, e46, mkv, frs
Some clubs make you remove the center caps. It is not because of the heat, the wheels actually deform enough due to forces on them during track days and make the center caps pop out.
The Following User Says Thank You to Lex_K For This Useful Post: | nikitopo (07-28-2018) |
05-02-2018, 09:42 AM | #8 |
The Gunshine State
Wouldn't you say the heat contributes to the deformation? Also could depend on alloy of the wheel.
Current DD: M235i |
05-02-2018, 09:53 AM | #9 | |
Drives: 2014 Subaru BRZ
Just think about how tough welding aluminum is, getting heat to stay in the metal is a pain thanks to its ridiculously high rate of heat transfer (silver and gold are about the only materials better than aluminum at moving heat energy). I have partially melted center caps at the track, the thin plastic doesn't hold up to the heat well. |
05-02-2018, 09:54 AM | #10 |
The Gunshine State
Makes sense, aluminum cools rather quickly as well.
Current DD: M235i |
05-02-2018, 11:27 AM | #11 |
I have those brakes. I smeared the pads after one day. More power to you!
05-02-2018, 12:28 PM | #12 |
Drives: 2017 DGM BRZ PP
I have a performance package BRZ I just took out for its first track day yesterday at Sonoma. Winmax W6 pads worked fantastic, easily out-braking the stock tires. I didn't have time to flush the brake lines so I was using stock fluid and I didn't get much pedal mush at all after 7 sessions, so the brake kit is managing heat pretty well. Also had the Jackson DR/OC and temps maxed at 230 F which I was very happy with.
I also didn't remove my caps and didn't even notice if they were still on, I'll have to check LOL. |
The Following User Says Thank You to Horrid_Funk For This Useful Post: | CSG Mike (05-02-2018) |
05-02-2018, 01:27 PM | #13 | |
Carefully put your hand close to a wheel next time you come off track! |
05-02-2018, 02:17 PM | #14 | |
The thermal camera videos of brake cooling tests show the rotor behind the wheels glowing hot and the wheels in front dark and cool but the scale could be too high to read the wheel temps. I'll have to take some temperature readings next time, I'm not nearly as sure the wheels don't get that hot anymore. I know they could very quickly because I've changed wheels in between sessions and while the tires were warm the wheels weren't. Sent from my SM-G935V using Tapatalk |
Similar Threads | ||||
2017 BRZ Performance Package DD Build | mjanmohammad | Member's Car Journals | 230 | 11-01-2023 12:31 PM |
Looking for Brz OEM 17 wheel for performance package | khcho19 | Want-To-Buy Requests | 1 | 04-27-2018 11:09 AM |
WTB: BRZ Performance Package wheels | funwheeldrive | Want-To-Buy Requests | 2 | 01-14-2018 02:29 PM |
Performance Package 86? | masahiro | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 11-01-2017 05:29 PM |
To get the Performance Package or Not? Thread | Zaku | BRZ First-Gen (2012+) -- General Topics | 141 | 12-06-2016 10:04 PM |
