Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-10-2018, 09:10 PM | #1 |
Engine Tune Needed for Track Day?
So I have a 2013 FR-S with only 26K miles on the engine. Finally going to take her to the track this summer, but I've read a few things stating the '13 could have latent engine issue that would cause major issues: https://www.reddit.com/r/ft86/commen...k_reliability/
Do I need to a tune before the track? I am planning on an Oil cooler, but I am concerned right now based on that post. |
04-10-2018, 09:54 PM | #2 | |
Drives: '13 BRZ Limited
When I replied July '13, he said I shoudl be OK -- March '13 was when they corrected the ECU tune for production. If the ECU software is updated, Mike told me he didn't consider anything other than an oil cooler necessary, past the normal fluids/pads... Good luck... |
The Following 2 Users Say Thank You to 86league For This Useful Post: | CSG Mike (04-11-2018), strat61caster (04-11-2018) |
04-10-2018, 10:12 PM | #3 |
Custom User Title
Drives: Asphalt FR-S MT
My car was built in Dec 2012. It has seen plenty of track, autocross, and mountain time. Most of which is between 4k and max rpm at damn near full load. I have 70k miles on my car now. Aside from a throw out bearing and one coil pack that occasionally says "change me, eh never mind I'm good," I haven't had a single drivetrain issue.
The Following 3 Users Say Thank You to boredom.is.me For This Useful Post: |
04-10-2018, 11:15 PM | #4 | |
Drives: Crapcan
04-11-2018, 11:39 AM | #5 | |
04-11-2018, 11:52 AM | #6 | |
04-11-2018, 12:51 PM | #7 |
I don't recall if OBD2 reads the tune info, there's some info out there about the tune ID pre- and post- retard timing fix. The dealer can certainly tell you the tune if they're cooperative, there should be a sticker on the hood if it has been reflashed, but they don't always
As above, I also have a 12/12 build date, pretty sure I had the 'bad' tune, as a casual I put 60k miles on before picking up a tune for the car without issue, 67k now, a couple track days, a couple autox's before the tune. 'Need'? imo no, depends on the skill level though, if you're capable of beating it to 10/10ths as above you probably have a time bomb, if you're a casual dude like most of us, a couple seconds away from that perfect lap, you'll probably be fine (you're not nailing those fast shifts that cause knock, either because of skill or conscious decision). But a $500 tune or even cheaper a reflash of the updated tune with tactrix is cheap insurance against replacing injector seals or a whole engine. |
The Following User Says Thank You to strat61caster For This Useful Post: | Teseo (04-11-2018) |
04-11-2018, 02:55 PM | #8 |
You can check for free with any borrowed Ecutek cable.
04-11-2018, 02:55 PM | #9 | |
The problem arises from rapid transient throttle position changes. |
04-11-2018, 02:56 PM | #10 | |
The ecu updates that exist are drivability or emissions in nature. You'd need a tune to eliminate the issue. The tune doesnt fix or eliminate any latent damage; any damage already done will remain, and can potentially cause DI seal failure in the future, but replacing the seals post-tune permanently fixes the problem. Seals are like $3-4 each. |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Faulkner (04-11-2018), strat61caster (04-11-2018) |
04-11-2018, 06:13 PM | #11 |
Thanks Mike. My build date is: 06/13 on the black driver's side sticker. Is this a clean point? Mine is an AT
I want to track this car and track it often. I guess my options are new seals and a tune or just sell it and move up? I love the car but I don't want to put more money in it. I'd rather save that for the next adventure entirely Would a tune like this cover the issue? For the cost a may as well get an added benefit http://www.ft86speedfactory.com/ecut...B#.Ws6jaGaZOT9 Last edited by Faulkner; 04-11-2018 at 09:58 PM. |
04-11-2018, 08:25 PM | #12 | |
Drives: 2013 FR-S in Asphalt
http://www.ft86club.com/forums/showp...3&postcount=12 |
The Following User Says Thank You to Qadthane For This Useful Post: | strat61caster (04-11-2018) |
04-11-2018, 08:49 PM | #13 | |
http://shop.amrperformance.com/produ...includes-tune/ |
04-11-2018, 08:58 PM | #14 |
No, I didn't need to update to get there. I have the OpenFlash tablet for ECU flashing. I really like it.
Tags |
engine, hdpe, reliability, track |
Similar Threads | ||||
Is a tune needed for a new exhaust?! | Molina30 | Engine, Exhaust, Transmission | 9 | 12-05-2016 07:31 PM |
Unichip tune software needed | almeshtaq | Software Tuning | 0 | 06-24-2016 01:58 AM |
OFT300 (Vortech/OFT) help needed (tune issue) | sirsol66 | Software Tuning | 7 | 12-09-2015 12:17 PM |
high octane fuel + FI, tune not needed? | BRZPDX | Forced Induction | 6 | 09-30-2014 12:41 AM |
If just want to add front pipe and overpipe, tune needed to avoid cel? | OICU812 | Engine, Exhaust, Transmission | 3 | 07-26-2013 09:43 AM |
