Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Subaru BRZ Limited - Supercharged 285hp, 2 way coilovers, and more!
Subaru BRZ Limited - Supercharged 285crank hp / 250wheel hp, 2 way coilovers, and loads more!
2013 ~68kmiles Nothing mechanically wrong and in great working order. Clean title in hand in the Portland Oregon area. I'm the original/only owner. I ran a VIN check and can send it to you as well showing all clear. It has come time for me to part with my Subaru BRZ. I'm the original owner. The car is in great mechanical condition and has been super reliable. Below is a list of all the upgrades I've done to the car (over $20k in parts alone) over the 5 years I've had it. You'll never drive a better BRZ than mine. The power, handling, responsiveness, feel, and performance is much better than stock. You won't need to do anything to this car as it's amazing. Clean title, no accidents, always garaged, adult driver and never ticketed and it's a red car. This isn't a show car as I've louvered the hood and there are some small scratches in the paint. The interior is in great condition and has multiple upgrades as well. I can send you a link to my Youtube page that has some videos of my car. I can meet in Beaverton on weekends and weeknights. I can meet in NW downtown during weekdays as well. Upgrade parts Wheels & Tires Greddy Short Lug Nuts - Red Open Ended 1.25mm XXR 527 17x8.25 et35 Bridgestone RE-71a 245/40R17 Autobot 55mm decal (for xxr wheel centercap) Aluminum hubcentric rings 73.1mm OD to 56.1mm ID Suspension Whiteline KCA416 Front Camber adjusting bolt 16mm Whiteline Rear Control arm - upper inner bushing (camber correction) KCA326 Whiteline Front Control arm - lower inner front Anti-Dive / Caster Correction Kit KCA434 Whiteline Front Control arm - lower inner rear bushing W0509 WhiteLine Rear Crossmember Mount Bushings KDT922 Positive Traction Kit Whiteline Front Sway Bar with bushings Front 20mm Fixed BSF45 Whiteline Rear Sway Bar with bushings 16mm Adjustable BSR53Z Whiteline Front Steering - rack & pinion mount bushing KSR210 Whiteline Rear Trailing arm - lower front bushing W63414 Perrin Poly Rear End Links Front strut tower bar Perrin front control arm brace Subaru Impreza OEM Conical Washers (Subaru P.N # 20326AA000) RCE TARMAC 2 COILOVERS Interior Leather w/ red stitch knee area to replace plastic Red led dome light, door light, and trunk light Red led light strip (I put in foot area) Alcantara w/ red stitch gauge cluster hood Flossy Red Griptape Shorty with custom autobot emblem ScanGaugeII Alcantara w/ red stitch radio and air bag surround Sound deadening 50 Sq Ft Rattle Trap FatMat 80 mil Prova Wide-View Rear View Mirror Yellow Center Console Trim heated seat button surround Ensolite sound deadening 53sqft + 2 yrds and raammat 8 squares BRZ Cupholder Plates Red/Black Car door laser projector Autobot Sun visors black Alcantara wrapped with red stitching Club4AG gauge cluster overlay white with red ATI 60mm vent gauge pod Shadow Pro Gauge 2 Perrin oil pressure gauge SRP wide gas pedal Red ebrake button trd momo steering wheel 360mm diameter Exterior GrimmSpeed License Plate Relocation Kit Window Tint Lamin-X Foglight Covers Yellow Grimmspeed Carbon Fiber Hood Dampers Debadge rear Vinyl wrap hood black Rear fog light kit 2 Lamin-X Headlight Covers Yellow w/ foglight covers Prova Yellow Wide-View Door Mirrors Driveway Labs Rear diffuser Type 1 Subaru Fender Trim GrillCraft Front Lower Grill Silver (painted gold) SUBARU BRZ Aluminum LICENSE PLATE FRAME Thicker tail light gaskets Diode Dynamics front led turn signals and side markers RokBloks mud guards Louvered hood Transmission/clutch Whiteline Gearbox Positive Shift Kit KDT926 Perrin Rear Shifter Bushing Whiteline KDT925 Rear Diff - mount in cradle & support outrigger insert bushing MTEC Shift Spring Kit Chase Bays stainless steel clutch line Autozone slave cylinder (smaller than stock) Engine Nameless ac, and alternator covers red Perrin Oil Cooler Perrin Radiator Hose Set Red Raceseng Cam Plate Innovate Supercharger Raceseng 70mm Innovate supercharger pulley Radium Engineering Catch Can kit for FR-S/BRZ Innovate intercooler kit Moto-East Ecutek license and tune for supercharger Perrin Engine Mounts Gates belt (for supercharger) K061015RB Perrin Cam Solenoid covers Shorai 3lb Battery LFX36L3-BS-12 and Kinetic Machine Lightweight Battery Tray w/ charger Lubricants and Fluids Qwik Valve Fumoto Oil Drain Valve F108S 16mm-1.5 Mobil 1 advanced fuel economy fully synthetic 0w20 10q Pentosin 3 Liter; 75W-80 Trans Oil Motul Gear 300 75W90 Gear Oil 2QT for Diff Subaru blue coolant Motul 600 racing brake fluid Intake Perrin 2.75" Intake System Nameless supercharger intake tube double ceramic coated with meth bung Exhaust Nameless Performance High Flow Cat (Replaces Overpipe) Helmholtz Resonator JDL UEL header Grimmspeed Header Gasket o2 sensor spacer Invidia Q300 catback resonated with stainless tips Brakes 2 extra sets of oem rear rotors and pads, 1 extra set of front OEM pads Speed bleeders SB1010-SS Radium Engineering Brake Master Cylinder Brace MTEC Industries SS Brake Lines - Red Carbotech XP12 front and rear (oem pads on car currently) Centric premium front and rear rotors New never used Raybestos ST 47 front ST45 rear (oem pads on car currently)
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() Last edited by stockysnail; 05-11-2018 at 06:11 PM. |
| The Following User Says Thank You to stockysnail For This Useful Post: | CarzCarzCarz (11-28-2017) |
Drives: 2014 WRB BRZ
Good luck with the sale. Tempting to see all that work done and for good price. Free bump
| The Following User Says Thank You to CarzCarzCarz For This Useful Post: | stockysnail (11-29-2017) |
Drives: 2013 Subaru BRZ
Still for sale? Im on the east coast but will be in Portland, OR for work in ~1 month.
Just the tip
Yes still for sale
Past (sold): Click here to see previous cars and bikes ![]() |
Just the tip
Tired of the low ball offers of $12k so I'm just going to keep the car. Sorry to all the Californian buyers that were interested but couldn't since it would not be CARB legal because the aftermarket headers not having a CAT and non-CARB legal tune. It does pass Oregon though.
Drives: 2017 86 6MT
12k yeah I wouldn't be happy either with those offers.
| Shiumai's DGM BRZ Limited - E-force Supercharged | shiumai | Member's Car Journals | 80 | 01-01-2020 01:29 PM |
| WTB BRZ Limited CWP/SWP Supercharged | Merkic | Want-To-Buy Requests | 4 | 10-25-2016 11:10 AM |
| Swift's Supercharged Black Limited BRZ | swift996 | Member's Car Journals | 583 | 06-13-2016 09:38 AM |
| Subaru BRZ Limited Supercharged, track and daily driver friendly - $29000 | stockysnail | Cars for Sale/Trade | 2 | 05-31-2015 01:53 AM |
