Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
09-25-2017, 10:21 PM | #1 |
Drives: 2017 Brz
kicker hideaway
https://www.google.com/url?sa=t&rct=...-coGOLC-SdLlPQ
Does this little box match the factory trunk subwoofer output? sound quality? Easier to install? I hate the idea of having to put out $700 for OEM. |
09-30-2017, 06:07 PM | #2 |
Drives: 2016 Subaru BRZ Limited
It probably won't match the sound since you're comparing an 8" to a 10" and the factory is powered by just a 100W amp vs the 150W of the 8". Other things to consider are the size of the box and the position of the compact one. The trunk can act like a sound chamber for the trunk sub making it sound much larger than having a compact sub under a seat.
10-03-2017, 10:43 AM | #3 |
Drives: 2017 Brz
Wasn't thinking of putting it under the seat since not even a shoe fits under there...trunk mounted was the idea. Maybe even bolted to the rear seat back to keep all the trunk room intact.
10-08-2017, 11:15 PM | #4 |
Drives: Car Collector
I thought it fell short
I listened to it in a car audio demo room and was not impressed. I compared it back and forth to small monoblock amps and single 8 sub box set ups and they sounded much better despite costing less.
I am going with an extremely small NVX MVPA1 amp which can mount under the dash so that I only need to run speaker wires to the back. Hard to believe something so small not only makes the promoted power claims, it exceeds it. [ame="https://www.youtube.com/watch?v=o3U7ct8hcu0&t=24s"]https://www.youtube.com/watch?v=o3U7ct8hcu0&t=24s[/ame] The dual 8" sub enclosure I will be utilizing can be easily removed if I should ever need every bit of the trunk space. |
The Following User Says Thank You to CraigVM For This Useful Post: | Chimera (10-09-2017) |
Similar Threads | ||||
OEM Kicker Sub | IAmJustARaptor | Audio/Visual, Electronics, Infotainment, NAV | 1 | 08-16-2017 11:12 PM |
OE sub (Kicker) | peaches | Audio/Visual, Electronics, Infotainment, NAV | 2 | 04-05-2017 11:51 AM |
WTB: Kicker Subwoofer | doctor_driver | Want-To-Buy Requests | 0 | 03-14-2017 10:36 AM |
FS: Pa Car audio kicker comps, pioneer comps, kicker coaxials, 2 alpine amps, polk et | SterlingBrz | Audio/Visual, Electronics, Infotainment, NAV | 2 | 04-27-2015 11:45 PM |
FS: Kicker PX200.1 amp, Kicker CompRT81 sub, BNIB | gramicci101 | Audio/Visual, Electronics, Infotainment, NAV | 3 | 03-23-2015 10:35 AM |
