Old 09-14-2017, 11:30 PM   #1
cf6mech
Drives: FRS Silver LS1 swapped.
Sway bar fix for header interferance.
Just wanted to post that my local shop (Texas Track Works) has made some relocation brackets for my Vorshlag kitted LS1 swap and can have them made for others if needed.....pictures to follow hopefully tomorrow.
cf6mech is offline   Reply With Quote
The Following 4 Users Say Thank You to cf6mech For This Useful Post:
DustinS (09-18-2017), Jonsey (09-15-2017), venturaII (09-15-2017), Zer0 (09-15-2017)
Old 09-15-2017, 10:45 AM   #2
NOHOME
Drives: RAVEN
Find it interesting that Canbus turned out to be an easier nut to crack than swaybar install!
NOHOME is offline   Reply With Quote
The Following 2 Users Say Thank You to NOHOME For This Useful Post:
cf6mech (09-16-2017), wooly35 (09-17-2017)
Old 09-15-2017, 11:02 AM   #3
gtpvette
Drives: 2015 FRS - FFR GTM
Excellent!!! Will it use OEM bar??
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
wutsaiu (09-15-2017)
Old 09-16-2017, 08:01 PM   #4
cf6mech
Yes any bar that will fit OEM application will work, just different end links.
DustinS (09-18-2017), gtpvette (09-18-2017), wooly35 (09-17-2017), wutsaiu (09-16-2017)
Old 09-16-2017, 10:15 PM   #5
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
I want, how much $?
wutsaiu is offline   Reply With Quote
Old 09-18-2017, 11:54 AM   #6
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Bump?
DustinS is offline   Reply With Quote
Old 09-18-2017, 03:46 PM   #7
cf6mech
Sway bar relocate bracket.
The Following 3 Users Say Thank You to cf6mech For This Useful Post:
DustinS (09-18-2017), ILLSMOQ (09-22-2017), wutsaiu (09-20-2017)
Old 09-18-2017, 03:48 PM   #8
DustinS
DustinS's Avatar
Does the ground clearance change?
Old 09-18-2017, 03:59 PM   #9
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
@Tokay444
JBR up in this bitch now? Lol.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-20-2017, 06:08 AM   #10
cf6mech
Ground clearance un-effected, as you can see in the photo the OEM engine shield and the bracket well above it, a much beefier stiffer bracket I might add compared to the stamped steel unit,.........anybody needing this can contact Texas Track Works Fort Worth Texas......Mason or Forrest being the contacts, they assured me they will make this available for others wanting it.
Old 09-20-2017, 06:27 AM   #11
cf6mech
SPL Parts custom made ends links just showed up.
Old 09-22-2017, 01:03 AM   #12
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Looks great!
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
cf6mech (09-22-2017)
WRX rear sway bar: good front sway bar combo? LerpK Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 11-11-2016 06:02 PM
FS: Koni shocks, TRD sway bar & WRX sway bar scirocco78 Brakes, Suspension, Chassis 14 08-31-2015 06:47 AM
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 01:20 PM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
