Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
09-14-2017, 12:02 PM | #1 |
Drives: 2017 Halo 86
Smell on hands after driving?
Is it normal to have some strange burnt smell on your hands after driving a manual car? The smell on my hands is most prominent when the AC has been running and lingers on my hands for hours after driving. I've been driving a new 2017 manual 86 for about 9 months and its been a consistent thing, no matter how hard or gently I drive the car. I drive for 80 miles total or roughly 3 hours each day on commute. Car has about 15k miles.
I've also noticed ever since I've owned the car a brief and faint smell of some kind of heated/hot/lightly-burning of material I can't describe that comes through the AC vents whenever I let the car engine break, or if I let off the throttle while going at speed, or randomly while upshifting between 3-4-5th, depending on how messy the shift was and engine rpms. I believe this is the smell that is absorbed into my hands. The smell is annoying because even if I wash my hands it's still there. Could this be clutch related? Also, and unrelated, about a month ago I've noticed a cricket sound coming from the engine after maybe 20 minutes of driving. It doesn't seem like a belt squeal or squeak, but more like a high pitch cricket that match the speed of each piston. Under the hood, I place my ear over the engine area, the sound is loudest on the right side of the car and directly over the right side intake manifold. The cricket sound goes away at higher rpms, and most noticeable at idle. Is there something wrong? Last edited by Lakitu; 09-14-2017 at 12:13 PM. |
09-14-2017, 12:14 PM | #2 | |
Senior gif poster
Drives: 2013 Asphalt FRS
As for the smell no that's not normal, what I suspect is going on is your HVAC system is on "air from outside" and your getting air from fumes on the highway/what your driving near and that is being sucked into your AC and then applied to your hands. I suggest you first check your cabin filter in the glove box make sure that looks okay or get a new better one than what comes with the car (I'm a fan of that FRAM one with the baking soda). Next if that filter looks ok then try doing your commute with air on "cabin air recirculate" and see if you still get that smell. Also wash your hands. Last edited by DandoX; 09-14-2017 at 01:44 PM. |
09-14-2017, 12:23 PM | #3 |
hmmmm........
First off, maybe the "cricket sound" is the HPFP just doing it's thing, that you hear from time to time. As far as the smell, no, your hands shouldn't smell funny after driving a MT car. Maybe the smell is mildew in the A/C ductwork ......?? If it is, you might reduce the smell by shutting off the A/C (but keep the fan running) a few minutes before you shut down the car. If you wash your hands and the smell is still there ....... unless you have been messing with catfish bait ....... I reckon you need to use a stronger soap ..... A burning clutch smell is very distinctive ........ it smells like ...... well ...... burning clutch. humfrz |
09-14-2017, 12:30 PM | #4 | |||
Drives: 2014 BRZ Limited
You can sometimes get it to go away by using a particular brand of gas, but you'll have to find the one that your car likes. I generally find mine doesn't chirp (or does it with less volume or frequency) if I use Shell or Chevron gas. Sam's Club gas is a virtual guarantee of very loud crickets in my car. I'm convinced it has to do with the additive packages the different brands put in their gasoline. However, keep in mind that even if you find a gas station that provides gas that doesn't chirp in your car, the stations change blends throughout the year with the changes in season, so what works now may not work a few months down the road. Mine generally likes summer gas but chirps on winter gas when they cut it with butane. |
The Following User Says Thank You to extrashaky For This Useful Post: | 8RZ (09-14-2017) |
09-14-2017, 12:40 PM | #5 |
I've heard several people complain about the new material used on the MY17 steering wheels. Not specifically about smell, but I could see that softer material soaking up odors more easily.
People have complained about the new steering wheel tearing/ripping apart IIRC. |
09-14-2017, 12:46 PM | #6 |
I am so happy to hear there's nothing wrong with my brand new car. Thanks a ton guys!
@extrashaky - regarding the smell, I'm 100% certain this is related to the burning smell on my hands. What exactly is the cause of this smell, if you know? I feel like it is just some manufactured layer of clutch plate material or something that is burning off. Or is it something else? Do other manual cars have this feature? Thanks again! |
09-14-2017, 12:55 PM | #7 |
Drives: 17 86
My 17 still smells like a hot slot car after it warms up. As has been said, the cricket is normal but you are the first (I think) to notice a 17 doing that. I get a hint every now and then, but nothing compared to my 13.
Yes, the stock steering wheel material sucks. I don't know who thought a slick material was a good idea. I'll sniff around mine in a bit and let you know. Added: I read somewhere that the refrigerant used these days can cause a smell. |
09-14-2017, 01:13 PM | #8 |
I don't think it could be mildew in the AC ducts, I thought the same a few months ago so I swapped out the cabin air filter with a brand new one, and then sprayed lysol into the vents with the AC off and just the fan running, which is supposed to kill any fungus but that did not resolve the smell issue. And I think in that case it would be a more consistent smell, but the one I have is only when doing certain things, like letting off the throttle and engine braking, or a few seconds after changing a shift. If I'm sitting idle, I never smell anything weird.
09-14-2017, 01:15 PM | #9 |
I suspect it's just the clutch breaking in. Most manual cars have a clutch smell after a clutch replacement. This one seemed to last longer than I would have expected, but all my previous manual cars were bought used and were well broken in before they got to me.
There are a lot of odd things that are actually "normal" for these cars. A few things may have changed with the new model year, but read this thread (especially post 13): Things you should know after buying a BRZ? |
09-14-2017, 01:38 PM | #10 |
Drives: Toyota GT86 Coupe Red (UK)
Exhaust sealant burning?
Green goo burning? (You guys get the green goo don't you?) Both perfectly normal. My 2017 smoked in traffic on the way home from the dealership. Exhaust sealant needs to bake in, it's left uncured from factory. It has a harsh arid smell that "smells like it would sting your eyes". The green goo smells sickly sweet and chemically when it boils on whatever part of the engine bay gets hot enough. I'm not sure why you would smell these from your hands and not from the car though. Does the steering wheel or gear stick smell of anything if you sniff them close up?
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
09-14-2017, 02:00 PM | #11 |
Drives: 2017 86, 2012 Tundra, 1999 Integra
I also drive a 2017 86 manual and have noticed none of these things. No bad smells, or crickets, or scratches, scuffs, rattles or creaks--coming from an 18 year old car to something so clean and new without any flaws is absolutely astounding. It never ceases to amaze me!
Myriad |
The Following User Says Thank You to Myriad For This Useful Post: | Tcoat (09-14-2017) |
09-14-2017, 04:59 PM | #12 |
Drives: 17 86
No smell, OP, but I did pass people like a mofo.
Time for a trip to the dealer just in case some some funk is in your HVAC system. Last edited by PetrolioBenzina; 09-14-2017 at 05:09 PM. |
09-14-2017, 06:29 PM | #13 |
There are so many jokes I could make about smelly hands after touching the stick...
The Following User Says Thank You to Tcoat For This Useful Post: | Cal3000 (09-15-2017) |
09-14-2017, 07:01 PM | #14 |
Similar Threads | ||||
Strange Smell after Driving | ThisGuyRett | Issues | Warranty | Recalls / TSB | 31 | 10-12-2016 05:17 AM |
Does anyone else occasionally smell a burning odor during cold weather driving? | Meanderchap | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 01-10-2016 02:10 AM |
2015 BRZ: Strange smell after shifting and when driving in 1 gear for a while | hosfordbrandon | Issues | Warranty | Recalls / TSB | 46 | 11-02-2015 02:42 AM |
Which car do you think we can get our hands on first? FR-S? or BR-Z? | NWIguy | BRZ First-Gen (2012+) -- General Topics | 10 | 05-01-2012 10:24 AM |
Hands on with a BRZ | markitect | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 03-07-2012 08:26 AM |
