Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
09-13-2017, 01:41 AM | #1 |
Drives: Whiteout FRS
Car pulling to the left when steering wheel is centered
Hey guys, I'm having trouble with my car pulling to the left when the wheel is center. I had probably 4-5 alignments done within 10 months. All alignments had about 2.5-3.0 negative camber in front with 0 toe with the rears being close to 2-2.5 negative camber with ~1/16 toe in (each side and total). Had one done few hours ago and it looked fine on paper, just when I started driving it goes pulling to the left with wheel in the center. Had one done last Friday and same results. Had the other 2-3 done earlier this year and noticed the same results as well. The steering wheel is centered when doing it. I did both the last alignments while the first couple was done by a known reputable shop. What I also noticed is that if I do turn the steering wheel a little bit to the right (off center), it does drive straight.
Side notes: -One of the washers on the rear toe bolts was damaged from improper adjustment which I'm pretty sure it's causing my rear toe to slip out so I opted to replaced it with spc toe arms recently (if I'm correct, it was damage about 2 years ago from a new mechanic at a different shop who did my alignment, never went back). -I also did have my passenger rear tire replaced on the same Friday. |
09-13-2017, 01:56 AM | #2 | |
[insert cool phrase here]
Drives: BRZ Premium
One thing you could do is swap the rear tires to the front. If the problem goes away, then you'll need the matching pair. Another thing check tire pressures make sure they are the same.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
09-13-2017, 02:29 AM | #3 | |
09-13-2017, 05:21 AM | #4 |
Huge E85 fan!
Drives: 2016 Scion FRS
You should not have mismatched tires on the drive axle. If you replace one, you have to replace both unless the other is really new. Even slightly different wear will eventually damage the diff
When you get an alignment get .10 of toe in up front. That will help the car track straight. |
The Following User Says Thank You to guybo For This Useful Post: | Bach415 (09-14-2017) |
09-13-2017, 06:39 AM | #5 |
Because compromise ®
Drives: Red Herring
I'm not sure about that. It is often suggested on these forums to have zero toe at the front and and small toe at the rear.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post: | wparsons (09-13-2017), x808drifter (09-13-2017) |
09-13-2017, 02:52 PM | #6 |
Does this happen on every road, or just sometimes? Find a nice flat smooth parking lot and try again to see if it's related to the roads, or actually a problem.
I have a few nearby roads that pull my car around, but it's fine 99% of the time.
The Following 2 Users Say Thank You to wparsons For This Useful Post: | Bach415 (09-14-2017), strat61caster (09-13-2017) |
09-13-2017, 05:43 PM | #7 | |
With regards to the OP, presuming it's not road dependant, either the shop is lazy and not centering your steering wheel, or they typically put some offset into the toe angles so the car tracks straight on freeways or crowned roads intentionally, reasonable for a commuter on those kinds of roads, annoying for a sports car. Loose parts would be inconsistent, bent parts would be compensated for and only come up as being problematic dynamically, not on a straight flat road. Explicitly tell the shop what you want next time you drop it off, whether it's this one or a different one. They won't make a note of it and have the tech do anything different unless you explicitly point out the problem, especially if you return to this shop again. |
09-13-2017, 06:58 PM | #8 |
Drives: 2013 Audi Allroad, 2017 Subaru BRZ
Yes, they do. Prior to retiring my dad was a mechanic at a Pontiac dealer, specializing in front end work (including alignments). This is one of the things he always did.
09-14-2017, 12:43 AM | #9 | |||
Similar Threads | ||||
Aggressively pulling to the left on acceleration | sero901 | Issues | Warranty | Recalls / TSB | 39 | 01-12-2021 05:39 PM |
Steering wheel not aligned/centered properly | alamez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 07-11-2016 05:03 PM |
Weird Sound After Coilover Install (when moving steering wheel left and right) | taimysho0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 07-20-2013 01:18 AM |
Steering wheel not centered... | jeebus | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 04-09-2013 07:23 PM |
Steering Wheel Off-Centered | dco107 | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 03-22-2013 04:51 AM |
