Software Tuning Discuss all software tuning topics. |
08-28-2017, 10:35 AM | #1 |
VSC - where is the firmware for it?
Probably a huge long shot, but the root of this is wondering if it's possible to get the 2017+ track mode programming to an earlier ECU? I know it would be really handy for new people to get out of shape (since sport mode is way too restrictive) without running without any safeguards at all.
I haven't found if it's even on the main ECU, or a secondary one... but I haven't dug *that* hard yet.
08-28-2017, 12:11 PM | #2 |
Drives: 15 BRZ LTD, 05 FXT
It would be nice if we could get updated maps for this. I'd love to have my sport mode halfway between current sport and 'off'.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
The Following User Says Thank You to JazzleSAURUS For This Useful Post: | chaoskaze (08-28-2017) |
08-28-2017, 01:01 PM | #3 |
Drives: 2014 GT86
Wider allowed slip angle would be nice .. but imho even better for MY2017 track mode is way it engages, way less abrupt/annoying.
Being pessimistic (i call it pragmatic/realistic) imho to sell better new ones Toyota will never port it for older cars, and it may very probably result in too difficult to hack/port by community themselves. So i put 95% on chance to never see newer VSC/track-mode on mine, even though i'd be ready to shell out for that eg. 1K$ if it had been possible. |
The Following User Says Thank You to churchx For This Useful Post: | wparsons (08-28-2017) |
08-28-2017, 01:35 PM | #4 | |
08-28-2017, 04:14 PM | #5 |
Unless you can just plug in the 2017 VSC computer into an older car and it runs :-) unlikely but possible.
Unlikely that anyone is going to reverse engineer the vsc computer 1. it may not be flash programmable 2. Legal minefield Your current option is ecutek , you can disable the cars VSC/Traction with the long button push. then you can use ecutek to program in your own traction control (not stability) inputs are 4 wheel speed sensors and steering angle , you can control throttle and engine torque as outputs. moto East currently have this available in their tunes an option 2012-2017 cars. they call it Transition control |
The Following User Says Thank You to steve99 For This Useful Post: | chaoskaze (08-28-2017) |
08-28-2017, 04:36 PM | #6 |
Drives: 2014 GT86
Still, would be interesting if someone would try. WHAT IF?
If that would work, i'm sure 2. won't matter to many around, as many use even much easier to detect mods "for offroad use only". So we just need more totalled 2017 to roll in breaker yards (bring squad of users shouting "totalled!" back!) |
The Following User Says Thank You to churchx For This Useful Post: | chaoskaze (08-28-2017) |
08-28-2017, 04:47 PM | #7 | |
The Fail Boat
Drives: CWP S.B.
Interesting to know, Thank you! |
09-04-2017, 08:00 PM | #8 |
Is VSC definitely on a separate computer, or is it a different section of firmware on the main ECU?
09-04-2017, 08:34 PM | #9 |
chicken tonight
It's definitely all in the brake actuator. Just looked it up in the manual. Even the gyros and accelerometers are all in there. I had no idea.
09-04-2017, 09:56 PM | #10 |
Drives: 2014 GT86
.. so ... if it gets replaced with new one?
The Following 2 Users Say Thank You to churchx For This Useful Post: | bhmax (09-04-2017), Ultramaroon (09-04-2017) |
09-04-2017, 10:43 PM | #11 |
chicken tonight
...and by some miracle, the new one is backward compatible?
09-05-2017, 02:17 AM | #12 |
Drives: 2014 GT86
Yeah, and uses same wiring, and for toyota to not had gone for extra safeguards to prevent switch (such as physically different wiring/connectors (that might be possible to workaround though), check up in electronics for other installed chips & their versions (eg. expecting also MY2017 ecu & it's tune), that would mean much-much harder to workaround) and for it to get triggered in same way as VSC in older ones (are buttons on mid-console directly wired to it? or rather signals are passed via other stages, eg. main ECU, that may change how/when it works and interpret signals from elsewhere too (eg. parking brake / main brake / engine temperature sensors that are used in pedal-dance)). - After all, if it will work with drop-in replacement in default all-nannies-on mode, it's not exactly fully-functional replacement, unless one can with new one also switch to that track mode, or TRC long press off, or completely off with pedal dance.
I hope though for Toyota to keep things simple and to not have designed in incompatible changes, rather reusing as is what had worked including other controls/sensors/chips/tune intercommunication and wiring. We still need guinea pig & totalled MY2017 for parts donor |
The Following User Says Thank You to churchx For This Useful Post: | Ultramaroon (09-05-2017) |
09-05-2017, 03:09 AM | #13 |
chicken tonight
Agreed.
The Following User Says Thank You to Ultramaroon For This Useful Post: | wparsons (09-05-2017) |
Similar Threads | ||||
BRZ Radio Firmware Update | coloradobrz | BRZ First-Gen (2012+) -- General Topics | 26 | 06-18-2016 03:02 PM |
OFT Firmware Changelog? | Semprini | Software Tuning | 13 | 05-31-2016 10:52 PM |
OFT: New firmware and new user software | Shiv@Openflash | Software Tuning | 9 | 10-15-2014 02:45 PM |
BRZ HEADUNIT FIRMWARE | beagoodruslan | Electronics | Audio | NAV | Infotainment | 7 | 07-27-2014 07:31 PM |
BRZ Nav Unit Firmware | michaelahess | Electronics | Audio | NAV | Infotainment | 5 | 05-09-2013 08:55 PM |
