Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
08-22-2017, 06:06 PM | #1 |
High Pressure Fuel Pump and Aftermarket Headers
I'm having the fuel pump replaced under warranty, as I figured I might as well take advantage of the warranty and try to get rid of the crickets at least once. I also am going to have headers installed soon. My question is:
Do you think the dealer will care that I have aftermarket headers and a tune from open flash tablet on the car? I have no idea |
08-22-2017, 10:58 PM | #2 |
Drives: 2015 FR-S
Probably would depend on the dealer. I have a header and tune and they didn't give me any problems about getting the new fuel pump in.
If you don't have the header/tune in yet, just wait until after the pump is changed out. |
The Following User Says Thank You to Impureclient For This Useful Post: | humfrz (08-23-2017) |
08-23-2017, 12:53 AM | #3 |
Alright, I'll just wait. I'm just anxious. Finally doing more to my car than just rice
05-12-2019, 06:50 PM | #4 |
Huge E85 fan!
Drives: 2016 Scion FRS
Sorry to necropost, but here I am.
Is there an aftermarket low pressure and high pressure fuel pump for the twins? I'm looking to upgrade the whole system and go FF |
06-14-2019, 04:15 PM | #5 |
FF? There's tons of low pressure pump options, just depends on how much flow you need. If you're staying N/A, there's no need to replace any of them at all. If you're going boosted then you just need to upgrade the low pressure pump and port injectors at most. Leave the HPFP and DI alone.
03-28-2021, 01:18 PM | #6 |
Drives: Scion FRS 2013
So was anyone able to swap the HPFP and remove the crickets with one of these, or something else.
https://www.ftspeed.com/search?q=fue...BRZ%20%2F%2086 |
03-28-2021, 01:27 PM | #7 | |
Drives: Crapcan
Those are in tank pumps. The pump that causes the crickets is the HP pump bolted to the driver side head. Again, there is no aftermarket replacement. Sent from my iPhone using Tapatalk
The Following User Says Thank You to NoHaveMSG For This Useful Post: | DarkPira7e (03-28-2021) |
03-28-2021, 03:15 PM | #8 |
Rust bucket enthusiast
Can the 17+ MY pump be swapped onto the earlier heads? Asking for a friend....
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
03-28-2021, 03:23 PM | #9 | |
Drives: Crapcan
Yes. I think the old Pump part number will supersede to the newest. Not 100% though. Edit: checked and all years show compatible with the newest pump. Looks like it has been superseded a few times. Only 1 part number available for all years mt or auto. Sent from my iPhone using Tapatalk
Similar Threads | ||||
So chirping noise from high pressure fuel pump | Nefarious | Issues | Warranty | Recalls / TSB | 19 | 03-12-2017 10:49 PM |
OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu | ndreim | Engine, Exhaust, Bolt-Ons | 5 | 11-23-2016 11:36 PM |
high pressure fuel pump = 5 years / 100 000 km ? | jefars | Issues | Warranty | Recalls / TSB | 7 | 09-16-2016 01:26 PM |
High Pressure Fuel Pump Thread | crazyfrenchbiker | Engine, Exhaust, Transmission | 10 | 09-09-2015 01:32 AM |
High Pressure Fuel Pump Difference? Toyota vs. Subaru | 86_ZN6 | Engine, Exhaust, Transmission | 18 | 06-03-2013 06:48 AM |
