Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-13-2017, 05:51 PM | #1 |
Drives: Toyota 86 GT Manual
Roll Center
Has anyone actually measured the roll center and CG heights (either stock or lowered)?
Thought it might be worth checking before I go measure myself. |
07-13-2017, 06:14 PM | #2 |
Drives: Subaru BRZ Limited
I assume roll center is the balance point of the car from the front to the back and the CG is the center of gravity from the ground to the roof. is that correct?
How would you go about measuring either of those? |
07-13-2017, 06:40 PM | #3 |
Drives: 2019 Mazda Miata RF
The Following 2 Users Say Thank You to Gunman For This Useful Post: | JoeC (07-13-2017), strat61caster (07-13-2017) |
07-13-2017, 07:12 PM | #4 | |
07-13-2017, 07:34 PM | #5 | |
But I think it's worth checking yourself. |
The Following User Says Thank You to strat61caster For This Useful Post: | bju90 (07-13-2017) |
07-13-2017, 07:54 PM | #6 | |
Simply put, it is the point, or axis, that the car rolls around, when cornering. It gets more complicated, once you put dynamics into it, and the roll center starts to migrate. Some suspension engineers design around it, others nearly ignore it. I've worked with both. |
The Following User Says Thank You to Gunman For This Useful Post: | strat61caster (07-13-2017) |
07-13-2017, 09:30 PM | #7 |
Drives: Grrrr
Similar Threads | ||||
PArt Shop Max Roll center knuckles. | laextreme5 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 03-14-2017 09:07 PM |
Roll Center Adjusters, Tie bar, BNIB | nickmerronesucks | Brakes, Suspension, Chassis | 20 | 05-06-2016 09:37 AM |
Roll Center correction | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-14-2016 03:22 PM |
Whiteline Front Roll Center Kit - Anyone have and can review? | stockysnail | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 08-17-2015 03:36 PM |
Roll center location? :iono: | BRZranger | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 54 | 09-05-2014 09:20 AM |
