Old 05-08-2017, 10:31 AM   #1
Andreasbrz14
Drives: subaru brz
will this wheel and tire combo fit with stock suspension without rubbing?
hello guys i was looking to get some new rims and tires and i was wondering if this combo would work with stock suspension
18x9.5 +35
245/45r18
if anyone knows please let me know
thanks
Andreasbrz14 is offline   Reply With Quote
Old 05-08-2017, 10:49 AM   #2
dattran86
Driver
Drives: 2013 Whiteout FRS
u have to go with 245/35. it will fit without any issue. but it will poke out pass the fender in the front. unless you dial in negative camber with camber bolts
dattran86 is offline   Reply With Quote
Old 05-08-2017, 10:50 AM   #3
Dialkyl
Drives: Silver 2013 Subaru BRZ
http://www.ft86club.com/forums/showthread.php?t=7535
Check this.
Dialkyl is offline   Reply With Quote
Old 05-08-2017, 01:48 PM   #4
tyler_win_photo
tyler_win_photo's Avatar
Probably shouldn't mess with camber too much with this setup, as you'll likely rub the spring.
tyler_win_photo is offline   Reply With Quote
Old 05-08-2017, 01:54 PM   #5
dattran86
Driver
yup, will probably rub the spring perch with more neg camber
Old 05-11-2017, 11:03 AM   #6
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
You could run camber plates instead of gaining camber at the bottom of the strut. There are HVT non-raising plates for sale in the classifieds right now.
trippinbillies40 is offline   Reply With Quote
Old 05-11-2017, 07:09 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Camberplates often come with noticeable NVH issues. For me with stock shocks at high enough level to revert to stock (actually to group-n) top mounts. Though probably not an issue for someone in country with public roads of better state.
Old 05-17-2017, 05:08 PM   #8
C11GEN
C11GEN's Avatar
Drives: 2016 Scion FRS
I'm running 8.5 same offset and there isnt even 2 fingers between rim and stock spring in the front. You could prob get away with it. I'm also running 255 rears without any issues, but only 225 in the front.
Sent from my LG-H831 using Tapatalk
C11GEN is offline   Reply With Quote
Old 05-17-2017, 05:10 PM   #9
C11GEN
C11GEN's Avatar
Very similar specs to what you want http://www.ft86club.com/forums/showthread.php?t=118306
Old 05-23-2017, 04:25 PM   #10
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
https://tiresize.com/comparison/
If you run a 245/45/18 that's almost 10% more overall diameter compared to stock, which will quite noticeably hurt your acceleration.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
fitment, rims, stock, stock suspension, tires and wheels
wheel and tire combo for newbie track driver MoreBRZMoreCHRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-16-2015 10:25 AM
19" gram lift 57extreme wheel and tire combo frojas1985 Wheels and Tires 13 09-18-2013 01:15 AM
Anybody taken their wheel/tire combo off their FR-S and... cfordart Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-05-2013 01:47 PM
Winter Wheel/Tire Combo... Wes B. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-10-2012 08:33 AM
