Old 04-23-2017, 03:13 PM   #1
BlueLine
Drives: 2013 Rally Blue w/Bronze wheels MT
2UR-GSE discussion thread
I am currently thinking of an engine swap. At first I was just going to turbo the FA20, however after looking into it a bit further I want to explore this route.
My current thoughts are getting the 2UR from a used ISF mating it to a 6 speed V161/v160 transmission.
Run a motec m150 and upgrade the rear diff to a non slip.
I will most likely need to make a drysump for clearance issues.
Start shooting ideas good or bad now
BlueLine is offline   Reply With Quote
Old 04-23-2017, 03:49 PM   #2
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
The only bad is cost lol. It would be an awesome setup no doubt. Using an m150 should be no problem for the engine and frs/Brz body control
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 04-23-2017, 06:49 PM   #3
BlueLine
Engine is 6-7,000
Transmission 3,000
Motec 5,000 (including all the extra bits)
Plus tune time
Clutch 300 (dual sprung ceramic puck)
Dry Sump ?
Old 04-23-2017, 09:53 PM   #4
spitfire481
Drives: 2JZ FRS
I'll take every working v160 you can get me for 3k each lol. Are you going to build the engine harness, body side harness, write the motec firmware, etc? Not trying to doubt, but it adds up very fast. I know how much we have invested in just getting the oem features working with custom m1 firmware.
MoTeC
Build Thread
@spitfire481
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
CxG (05-16-2017), Manji (04-25-2017), wparsons (05-09-2017)
Old 04-23-2017, 10:18 PM   #5
BlueLine
Sent you a PM. I will build my integration harness based off of their unit. I have a network of people I have met in the years working on cars that all off specialized skills or knowledge in these areas. I'm not going to write the firmware however my friend will.
"Speed cost money how fast can you afford to go" I believe is the quote.
Old 04-25-2017, 10:15 PM   #6
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Box will be more like 7000
You also need a custom bell and fly
Clutch is light
Box shifter won't reach hole, will need to extend
Driveshaft
Motor will need ds and new intake mani
Headers
Consideration to coolant flow path
Rad will be fine but may need adjustment as crank pulley will be very close or touching
Your ecu budget I would double.
I would love to see it done but seeing as you're us based I would go LS
Manji is offline   Reply With Quote
The Following 2 Users Say Thank You to Manji For This Useful Post:
CxG (05-16-2017), wparsons (05-09-2017)
Old 05-01-2017, 10:28 PM   #7
BlueLine
Don't know why my emails are not coming through even though I turn on the instant notification.
MANJI I was looking to talk with you on FB messenger,KIK OR another app about your build.
I can get the front clip from a MKIV Supra for about 15k or less.
ECU budget doesn't include dyno time that's just raw cost
Headers I will have to sort once the engine is in place. However that will be a complete exhaust build
Thought about the LS but really want this engine
I have a tig welder extending stuffcamd making mock up pieces not a world ending
Drive shaft I was gone to have cut down and rebalanced or have custom one made once engine is in.
I can get custom clutches fairly cheap from one supplier I have.
My budget for the parts realistically will be 20-30k labor will be mostly free. I was trying to start getting a rough price list going in post #3
So keep on shooting me idea or areas to be concerned over planning is 90% of the build process
Old 05-07-2017, 02:16 PM   #8
BlueLine
So I'm buying a spare chassis that I will use as a jig. This will allow me to experiment with out taking down my daily driver. Now to find a good cheap car that the front hasn't been whacked before
Old 05-09-2017, 11:56 AM   #9
wparsons
wparsons's Avatar
Non-slip diff? You mean limited slip, like that stock diffs we already have?
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Jaden (06-28-2017)
Old 05-14-2017, 09:31 PM   #10
BlueLine
Yes
Limited slip
Old 05-15-2017, 08:59 AM   #11
wparsons
wparsons's Avatar
Originally Posted by BlueLine View Post
Yes
Limited slip
The stock diff is already a good Torsen limited slip...
flickr
Old 05-15-2017, 10:50 AM   #12
BlueLine
Mine is not , or it's worn out from the previous owner
However, I think I'll wait to do this and build my 2GRFSE swap first, I will still do this later.
Watch for that build thread this summer...
Old 05-15-2017, 11:33 AM   #13
wparsons
wparsons's Avatar
Torsen's are gear based, and don't wear out. If it's broken, you would be hearing gears crunching/rattling all the time.
Why do you think it's not working?
flickr
Old 05-15-2017, 01:14 PM   #14
BlueLine
Which ever tire has the least amount of traction spins the one on the solid surface ground will not move. The car does not have one or it's not working and or the PO removed it. I bought the car from a used car dealer and have found several little things not quite right.
Anyhow thanks for the replies. Like I said this project will be placed on hold for the time being please stay tuned for updates about another build.
Anime Discussion Thread ERA Off-Topic Lounge [WARNING: NO POLITICS] 2701 02-14-2024 11:55 PM
Forgestar F14 Discussion Thread Mikeez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 12-30-2014 06:09 PM
Brake Pad Discussion Thread CSG David Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 06-26-2014 05:59 PM
Another Coilover discussion thread... nobody__ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-04-2014 10:49 AM
Forza 3 vs. GT5 Discussion Thread Snaps Off-Topic Lounge [WARNING: NO POLITICS] 386 03-06-2011 12:10 AM
