Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-25-2016, 06:20 PM | #1 |
Drives: frs
Whiteline springs
11-25-2016, 07:35 PM | #2 |
Since they don't publish spring rates all I can say is: ¯\_(ツ)_/¯
- Andrew |
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
10-19-2020, 04:37 AM | #3 |
Enigmeerkat
Drives: 2015 Toyota 86 GTS
Thread revival. Just bought a set of these (kit includes the sways), anyone have any experience?
2015 Toyota 86 GTS - Ecutek w/ Flex Fuel, Xtreme Stage 1 Organic Clutch - PSR UEL Header, Invidia R400 Catback - Whiteline Swaybars, 18" ROH Blue Evo R |
10-20-2020, 10:38 PM | #4 |
The Following User Says Thank You to norcalpb For This Useful Post: | JohnJuan (10-22-2020) |
12-11-2020, 02:00 PM | #5 |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
So uhhh... Hows it going, or should I ask How are they going?
Instagram: 86_Maul |
12-13-2020, 07:22 PM | #6 |
Enigmeerkat
Love the look, and love the lower centre of gravity for handling, gotta be a bit more careful with potholes (etc.) than before.
However they've exposed an issue in the struts where now they are leaking, and knocking, and need to be replaced. Basically at this stage I am weighing up cost of getting some new/used struts to replace the existing ones, vs. moving to coilovers.
12-13-2020, 11:44 PM | #7 | |
2013 Series 10 FRS #553
12-14-2020, 03:37 AM | #8 |
Drives: 2020 BRZ tS
I saw Springs Rates on their website.
12-26-2020, 03:11 PM | #9 |
Drives: Corolla GT
Whiteline Springs deliver improved vehicle performance whilst maintaining safety and ride quality characteristics. This kit contains 3.0kg/mm (168lb/in) front rated springs that provide a 25mm drop while the 4.1kg/mm (229lb/in) rated rears deliver a desirable 25mm to the vehicle.
Copied from the whiteline site. |
Similar Threads | ||||
| Exxel Distributions | Whiteline Lowering Springs Special!!! | ExxelDistributions | Brakes, Suspension, Chassis | 31 | 01-05-2017 07:45 PM |
FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus | neilvosko | Brakes, Suspension, Chassis | 1 | 11-21-2016 02:44 PM |
SOLD: Whiteline Rear Lower Control Arms + RCE Yellow Springs | septiq | Brakes, Suspension, Chassis | 3 | 11-01-2015 12:07 PM |
***MEGA THREAD*** Tein & Eibach Springs | Cusco | KW | Whiteline | DBA | Stoptech | | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 59 | 11-07-2012 09:10 PM |
