Old 11-11-2016, 10:55 PM   #1
markitect
Drives: Scion FRS
Heated Mirror DIY
Here is the DIY for installing heated mirrors. I used aftermarket mirror glass, but you can adapt these to use if you buy complete mirror assemblies to. It took about 2 hours to do the second side.
I am not responsible for any damage you cause doing this.
Name:  wiring diagram.png
Parts(for both sides):
Rexpeed or other mirrors(Rexpeed did not sponsor this)
6 x Sumitomo 8240-4422 090-3 multilock terminal unsealed (I think AMP 368084-1 090-3 receptical will work)
2 x AMP 353537-2 040-3 tab
4 x AMP 316836-1 040-3 receptical
Wire: I used 18 awg high abrasion resistance going to the door because it is exposed. I think 22 awg is what the existing harness is
Heat shrink
electrical tape.
Subaru Relay 82501AG041
Tools
flat head screw drivers.
swedge or trip removal tools.
#3 phillips screw driver or socket
Wire Stripper
Crimper
Fish Tape
Directions
  1. Roll down the window and disconnect the battery.
  2. Remove Mirror Bolt Cover: with flat screw driver pull out from the top.Name:  bolt cover.jpg
  3. Remove Handle Silver Trip: Pry up with screw driver(there is a whole underneath, then fold up.
    Name:  door handle.jpg
Size:  187.2 KBName:  door handle 2.jpg
  4. Remove Footwell Wire Cover: remove 1 plastic pop rivet, then pull up the rocker cover and pull cover towards rear of the car to unlock it. Put the rocker cover back.
Size:  191.1 KBName:  rocker.jpg
  5. Open the screw cover by the lock
  6. Remove Screw in Door handle and, and by the lock (3 total), and the plastic rivet at the top right of the panel.
  7. Starting near the hinge and working down and around: Pull the door card out. You will hear pops as you move around, stop when the door can pivot at the top.
  8. Swing the panel out,and then slide up.
  9. Hold mid air and remove the door latch and lock cable. Pull out the plastic, then move the ball up.
    Name:  lock cable.jpg
  10. Disconnect the electrical connectors, they have a latch that needs to be pushed down with a screw driver.
    Name:  elecrical connectors.jpg
  11. Go put the door card somewhere, check to see if any black rings were left on the door, if so take them off and put them on the door card white rivets so you don't loose them.
  12. Disconnect the mirror electrical connector (above the speaker)
    Name:  mirror connector.jpg
  13. Pull the plastic back and unclip the mirror cable.
    Name:  plastic removed.jpg
  14. Remove the 3 mirror screws. The rubber pins will hold it in place.
  15. Pull the mirror assembly off and pull the cable through. This is tricky.
  16. Set the mirror aside.
  17. Disconnect the two white connectors in the footwell above the passageway. They have latches, but don't need a screwdriver.
    Name:  footwell disconnected.jpg
  18. In the door, behind the plastic carefully cut the electrical tape holding the rubber cable way to the white bracket the mirror cable went through (be very careful not to damage the cable way or wires.
    Name:  harness detached.jpg
  19. Pry out the plastic piece. I used a tiny screw driver from the front.
    Name:  harness holder.jpg
  20. Carefully cut /unwrap the cable way until you get to the wires.
  21. Inside the door push the boot of the cable way out.Name:  dislodge boot.jpg
  22. Feed the fish tape from the footwell. You can use some dry lubricant(talc, etc) to make it easier.
  23. When properly inserted it will bulge out the rubber cable way between the body and the door. Don't force it, use you hand to give it a straight path.
  24. When you can feel it past the boot, put it back in the door.
  25. When it emerges put the wire through the eye. You can run additional wires for turn signals if your new mirrors have them.
Size:  116.7 KBName:  fish 4.jpg
  26. Pull the fish tape back out from the footwell.
  27. Cut off the wire at the eye(it is bent and useless).
  28. Use a small flathead to take the latch off the door harness to mirror connector.
  29. It slides back then comes off.
  30. Strip back some of the heater wire.
  31. Crimp a 040 pin on the end of the new heater wire. I had to pull a few stands off the 18 awg wire and take off extra casing because the pin would not fit around the extra thick casing. The wire should go past the wire crimp point.
  32. Insert the pin with the crimps facing out into pin 4(double check this if you get a mirror assembly. You may need to give the casing crimp an extra pinch to get it in.
  33. Put the clip back on the connector, using it to push the pin the rest of the way in.
  34. You could cut electrical tap and run the wire in the plastic, but I used abrasion resistant so I just taped it along the way, pulling excess to the footwell.
  35. Tape the rubber cable way up completely, then tape it to the cable holder.
  36. Make sure the rubber boot is in the door.
  37. Clip on the cable retainer.
  38. If you bought a new mirror assembly skip to installing it.
  39. Pull the mirror glass off from the bottom.
  40. Carefully remove the mirror cover. Good luck I cracked one.
Size:  142.8 KBName:  cover 2.jpg
  41. Untape the mirror cable at the end and at the boot.
Size:  76.5 KBName:  untape 2.jpg
  42. Slide the boot down and the the cable way up.Name:  cover 3.jpg
  43. Untape the top of the cable.
  44. Feed 2 new wires through the cable way, I just slid them through. You may want to use different colors so you know what is ground if you make any more mods.
Size:  63.3 KBName:  feed 2.jpg
  45. Crimp a 040-3 receptical on each wire, open both sides of the connector like before and insert them. Pin 4 is power and pin 10 is ground (opposite sides, but the same column)
  46. Put the clips back on.
  47. Tape by the connector, and inside the mirror housing.
Size:  53.1 KBName:  tape2.jpg
  48. Run the wires behind the moving mechanism, and through a handy clip above the mechanism. ,I'm guessing it is for these.Name:  route1.jpg
Size:  110.9 KBName:  route2.jpg
  49. Add them to the clip inside the housing.
  50. Rout them to the side, and cut to length.
  51. Clip 090-3 receipticals to the wires, they at least fit on rexpeed mirros.
  52. Heat shrink the recepticals for safety.
  53. Attach them to the mirror tabs, it doesn't matter which way.
  54. Install the mirror.
  55. Set the cableway so it barely peaks into the housing, and visually check the mirror clip.
  56. Move the boot into place, and take it to the cable way, then put the cover on.
  57. Install the mirror: Feed the cable in, then insert the pins.
  58. Put the screws in and tighten them down.
  59. Put the lower cover on.
  60. Put the mirror cable through the cable bracket, and through the plastic.
  61. Plug it in.
  62. Re-stick the pastic to the door.
  63. Attach the electrical connector and lock cables to the door card.
  64. Slide the card over the top.
  65. Press down around it to secure the clips.
  66. Put the 3 screws in, then the plastic rivet, and install the handle.
  67. Cut the wire in the Footwell to length, and Crimp on a 090-3 Receptical.
    Name:  footwell crimp.jpg
  68. Simply slide the wire into the back of the connector, Pin 8.
  69. Connect the connectors in the footwell
  70. Reinstall the footwell cover, and install the relay under the hood.
  71. In the fuse box under the hood install the relay
  72. Connect the batter and enjoy.
markitect is offline   Reply With Quote
The Following 8 Users Say Thank You to markitect For This Useful Post:
BWilky (11-17-2016), Dadhawk (11-16-2016), DIE1000DEATHS (11-18-2016), emutcfut (12-15-2016), NahumCC (11-17-2016), thatfilipinoguy (11-16-2016), Trap63 (11-12-2016), Ultramaroon (11-11-2016)
Old 11-16-2016, 01:03 PM   #2
markitect
Drives: Scion FRS
I think this should cover it pretty well, if you guys have any questions let me know.
The Following 2 Users Say Thank You to markitect For This Useful Post:
Dadhawk (11-16-2016), thatfilipinoguy (11-16-2016)
Old 11-17-2016, 07:25 AM   #3
NahumCC
Drives: 2013 FR-S 10 Series
Good write up for the non keyless entry FR-S. Thank you for taking what I started with on my 10 series and making it easy for everyone else.
Sent from my SAMSUNG-SM-G891A using Tapatalk
NahumCC is offline   Reply With Quote
Old 04-16-2018, 01:12 AM   #4
Sc629
Drives: 2017 86 Asphalt
might be a stupid question, but could i just buy the door wiring harness from the models equipped with the heated mirrors and just replace the one in my door right now? it seems that the heated mirror wiring goes all the way to the harness already and just needs connecting?
Sc629 is offline   Reply With Quote
Old 04-16-2018, 08:17 AM   #5
markitect
Drives: Scion FRS
You might be able to find a junk yard harness, but it seemed like more work to pull it through. You might even need to remove the door, when I was looking at the best way to run the wire I concluded that the harness is installed in the footwell, going outside before the door gets put on.
Old 10-26-2018, 05:37 PM   #6
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
Thanks for the great DIY! I'm planning to install my heated Rexpeed mirrors this weekend and I haven't had a look at the passenger side yet, but I assume the process for adding the wiring is the same or at least very similar?
Face_Plant is offline   Reply With Quote
FS: Passenger Side Mirror Housing(non heated) OmarGC Exterior Parts (Aero, Lighting, Etc.) 1 10-13-2016 11:53 AM
FS: Brand New Blue convex mirror (heated element, led turn signal option) ucsmfu Exterior Parts (Aero, Lighting, Etc.) 8 08-20-2016 02:48 PM
FS: Brand New Blue convex mirror (heated element, led turn signal option) ucsmfu Canada Classifieds 4 08-19-2016 03:26 AM
FS: Like new BRZ/FRS Rexpeed blue wide angle mirror non heated Mint86 Exterior Parts (Aero, Lighting, Etc.) 2 06-04-2016 10:20 PM
DIY Request: heated mirror install 1Cor10:23 DIY (Do-It-Yourself) Guides 16 02-13-2015 05:17 PM
