Old 11-10-2016, 12:57 PM   #1
KDad2
KDad2's Avatar
Drives: 2013 Raven
DIY - Tire Rack
This is my first DIY and hopefully the directions and diagrams make sense. I didn't take photos while I was building the project due to a trial and error. I've also provided a PDF of the instructions to download.
File Type: pdf Tire Rack Installation instructions.pdf (675.3 KB, 6083 views)
KDad2 is offline   Reply With Quote
The Following 3 Users Say Thank You to KDad2 For This Useful Post:
BWilky (11-11-2016), MJones_RB (11-10-2016), Uplink (11-11-2016)
Old 11-10-2016, 01:42 PM   #2
KDad2
KDad2's Avatar
Drives: 2013 Raven
DIY - Tire Rack
DIY - TIRE RACK
Tools Used:
  • Miter Saw
  • Speed Square
  • Level
  • Impact Driver
  • Variable Speed Drill
  • T20 Star Bit
  • 5/16” Hex Nut Driver
  • 7/64” Pilot w/ 3/8” Countersink Bit
  • 7/64” x 6” Drill Bit
  • 5/16“ Drill Bit
  • Kreg Pocket Hole Jig Kit
  • 12” Clamps
Materials List:
  • 3 each of 2”x4”x8’ Premium Pine Boards
  • 6 each of 3-5/8“ Ledger Board Fasteners (Lag Bolts)
  • 10 x 3” Exterior Wood Screws
  • 8 x 2-1/2” Cabinet Screws
Some of the tools and hardware
I had some left over fasteners and wood screws from another project
The cabinet screws for the pocket holes
Assembly Instructions:
  • This tire rack is for the OEM sized tires. I used a total of three 2”x4”x8’ boards. If you are
    running 18” or larger diameter, and/or wider width wheels, then you will need to increase the
    length of the boards and will probably need a fourth 2”x4”x8’ board. In the schematic, I added
    a diagram going back to the algebra days. Yeah, we all remember a 45-degree right triangle.
  • If you plan your cuts carefully and don’t make any mistakes you can get two 36” and one
    22-3/8” out of one board, the two 31-5/8” with a 45-degree cuts and the other 22-3/8” section
    out of the second board. That leaves a 39” and the remaining 36” cut out of the third board.
  • Before beginning the cuts, trim off a sliver from one end of each board to make sure there is a
    nice clean edge.
  • Measure twice and cut all boards to length.
  • I also trimmed flush the bottom of the diagonal braces for aesthetics and also so I wouldn’t hit
    my head on the sharp corners and have my neighbors hear me cuss up a storm. It wouldn’t be
    the first time, but it also won’t be because of the tire rack.
  • Next, use the Kreg pocket-hole jig to drill two holes in each of the horizontal boards. I love this
    tool and use it for various projects. Set the depth of the jig and drill bit collar according to the
    manual for 1-1/2” thickness and a 2-1/2” cabinet screw. If you don’t have a pocket-hole jig,
    then you can insert the screws from the outside boards. Substitute a 4” wood screw for the
    2-1/2” cabinet screw where appropriate. Just predrill first and attach the diagonal braces last.
    If you have a countersink bit, use that too, as it will insure that all your screw heads sit flush
    and also that the diagonal braces are flush with the extension boards.
  • To assemble the boards, it isn’t necessary to use wood glue, but if you want to increase the
    strength of the tire rack, then go for it. If you have a speed square, use this to align the
    diagonal 45-degree braces when you attach to the 22-3/8” boards that make up the bottom of
    the rack that extend from the wall. Predrill the 3 holes with the countersink pilot bit at the
    bottom of each diagonal brace. Offset the holes so that they were not on the same parallel
    plane as the board.
  • Next, clamp the boards together and re-drill the pilot holes with a longer 7/64” drill bit to a
    depth of 2-1/2”. This is to prevent splitting the wood. Then, drive in the 3” wood screws into
    the predrilled holes.
  • Once you have your two diagonal braces attached to the extension boards, place them on the
    ground back to back to form a large triangle. Make sure that the top and bottom edges meet
    and there aren’t any gaps.
  • Now, you will attach the side frames to the rear bottom horizontal board that goes against the
    wall. Grab either side frame and attach first one end to the horizontal board and then attach
    the other side frame using 2-1/2” cabinet screws inserted into the pocket holes. The pocket
    hole jig really makes attaching the boards a breeze. Use your speed square to make sure the
    horizontal boards are at 90-degrees to the side frames.
  • Next attach the top horizontal board to the top of the diagonal braces. Again, using 2-1/2”
    cabinet screws inserted into the pocket holes. Don’t forget your speed square.
  • Now, you will attach the front angled horizontal board that the wheels rest on. This board is
    also at a 45-degree angle. Yep, you guessed it, use 2-1/2” cabinet screws inserted into the
    pocket holes.
  • Don’t attach the rear angled board the wheels rest on until you mount the rack to the wall.
    You will not have enough room to drive the fasteners into the wall if you attach this board.
  • At this point, the tire rack is pretty much assembled and it will be very sturdy.
  • One last step before installing the rack is to measure and mark 4-3/4” from the back of the rack
    along the bottom boards that extend from the rear of the rack. Then, with your speed square
    draw a 45-degree line starting at this mark. This is for when you install the rear angled board
Installation instructions:
  • First, find your center wall stud and place a mark on the wall. Hopefully, you can span 3 studs
    to distribute the load. If not, and only have 2 wall studs to work with, you can still follow the
    instructions, but with a slight modification.
  • Next, find and mark the studs to the left and right of the center stud. For an 8’ ceiling,
    measure down from the ceiling 29” along your center wall stud and place a mark on the wall. If
    you have a taller ceiling, then place the mark where either you have enough head clearance,
    or at a comfortable, safe height.
  • Next grab your level and draw a horizontal line at the 29” mark. This is the bottom of the tire
    rack.
  • Using your level secure a short piece of scrap 2”x4” to the wall using two 3” wood screws, one
    on top of the other, so it doesn’t spin on you. I started the screws on this scrap board first
    before trying to mount it to the wall. The top of the scrap board will line up with the horizontal
    line you drew on the wall. This board will serve as a temporary rest for mounting the tire rack.
  • At this point, you want to grab a buddy, significant other, or whoever to assist with the
    installation.
  • Place the tire rack on top of the scrap board and using your center mark on the wall as a guide,
    predrill and then drive the ledger board fastener into the top board of the tire rack. The
    fasteners that I used say no predrilling required, but I found it easier to predrill.
  • Again, check your level to make sure you are good to go. Then predrill and secure the bottom
    board to the wall with the fasteners.
  • At this point, your partner can let go of the tire rack and hand you tools and hardware as
    needed.
  • Predrill and drive the remaining fasteners.
  • Don’t forget to install the other diagonal board that the tires rest on. You left this off when
    assembling so you would have enough room to drive the fasteners into the bottom of the
    rack.
bcj (11-10-2016), Crazypinoy9 (11-10-2016), Uplink (11-11-2016)
Old 11-10-2016, 02:00 PM   #3
MJones_RB
MJones_RB's Avatar
Wow! Great job! Thanks for this.
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
KDad2 (11-10-2016)
Old 11-10-2016, 02:37 PM   #4
86Boyz
Drives: on the highway to hell
That is really cool actually. Nice job!
86Boyz is offline   Reply With Quote
The Following User Says Thank You to 86Boyz For This Useful Post:
KDad2 (11-10-2016)
Old 11-10-2016, 02:41 PM   #5
KDad2
KDad2's Avatar
Drives: 2013 Raven
I plan on painting it after I finish another overhead shelf in my garage. The walls need a fresh coat of durable paint too! But, I have too many projects, so it might be a while. Anyways, I'll post final pictures when I'm done.
Old 11-10-2016, 02:42 PM   #6
i heart ricers
Drives: g37 - 370z
so dumb
they are $100 jegs
i heart ricers is offline   Reply With Quote
Old 11-11-2016, 08:52 AM   #7
KDad2
KDad2's Avatar
Drives: 2013 Raven
Originally Posted by i heart ricers View Post
so dumb
they are $100 jegs
Thanks for the advice. I now have a paint scheme for my custom built tire rack that matches all my custom made shelves in my garage.
The Following User Says Thank You to KDad2 For This Useful Post:
MJones_RB (11-21-2016)
Old 11-11-2016, 11:12 AM   #8
i heart ricers
Drives: g37 - 370z
Old 11-11-2016, 11:22 AM   #9
JoeC
Drives: Subaru BRZ Limited
I'm not so sure I would trust the shear strength of the pocket screws considering the amount of leverage on the top ones. Maybe just run a larger lag bolt from the outside. I like the idea though!
JoeC is offline   Reply With Quote
Old 11-11-2016, 11:34 AM   #10
KDad2
KDad2's Avatar
Drives: 2013 Raven
Good idea. When I built the shelves, I added extra screws from the outside along with the pocket holes. Perhaps I'll go back and add them to the rack.
Old 11-11-2016, 11:41 AM   #11
i heart ricers
Drives: g37 - 370z
http://www.ebay.com/itm/JEGS-80385-A...9XDVIA&vxp=mtr
Old 11-11-2016, 12:05 PM   #12
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
Look ma, a link.... I can do it too.
http://www.menards.com/main/building...19922370754321
I know you'll need a few but in the end I'm sure it's WAYYYYYY less than $100.
OP, way to go. It looks awesome. I would have no worries of the sheer strength of the screws for the 120lbs that are up there. I would have turned the top board around so that the screws were going in to the meatier part of the 2x4 instead of the end though.
iamjacob is offline   Reply With Quote
The Following 2 Users Say Thank You to iamjacob For This Useful Post:
KDad2 (11-11-2016), Taco Man in HD (11-18-2016)
Old 11-11-2016, 12:09 PM   #13
KDad2
KDad2's Avatar
Drives: 2013 Raven
Thanks for the link. Tirerack.com has a similar rack and I considered it for a while. I just didn't like the sharp metal corners. With my low garage ceiling, I felt for sure that I would hit my head on it and it would just piss me off. So, I decided to be creative and build my own while enjoying a nice fall day outside.
Deep Six (11-11-2016)
Old 11-11-2016, 01:30 PM   #14
i heart ricers
Drives: g37 - 370z
Set of New Staggered 18's Closeout $356 at Tire Rack While They Last FRS Dad Scion FR-S / Toyota 86 GT86 General Forum 9 09-25-2014 06:23 PM
Tire Rack tpms sensors TimR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-27-2013 12:12 PM
Eibach Pro-kit from tire-rack Z86 AUSTRALIA 0 07-13-2012 06:14 PM
Brz limited on the rack at tire rack Nate219BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 07-06-2012 03:01 PM
Tire Rack still needs a BRZ! Lonewolf Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-12-2012 02:35 PM
