Old 11-01-2016, 05:55 AM   #1
Aboodilatif
Aboodilatif's Avatar
Drives: '14 Red Toyota GT86 RocketBunny
2JZ Radiator?
Just a quick question for you guys, anyone know of an off the shelf solution for a radiator that would fit a 2jz swap'd 86? any info on this would be greatly appreciated. I just need to be sure of what solution I end up going for since I live in the Middle East and its just a hassle to order something and get it wrong.
plus I need to hustle up and get this dealt with as soon as possible since everything is already installed and i'm just stuck with what rad to use.
I also seem to recall of a thread that was posted a while back of someone either trimming the rad fans or removing one of them due to space restrictions but cannot find it at all, if anyone can link it here i would greatly appreciate it also,
EDIT: the solution does not have to be plug and play, I can make custom mounts and hardware. just need ideas thrown my way
regards
'14 Toyota GT86 - 2JZ GTE - R154 - GTX3582R 1.06 - Motec M130 PNP - RocketBunny v1
'09 Audi RS6 C6 - MTM 850HP
Aboodilatif is offline   Reply With Quote
Old 11-01-2016, 06:41 PM   #2
Apex-Apex
Apex-Apex's Avatar
R34 GTR fits pretty well but if custom mount isn't an issue, you should just make your own.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 11-05-2016, 09:45 PM   #3
ZRB
ZRB's Avatar
Drives: ZRB
I can't recommend what you would be able to do since I'm not sure how you mounted the engine, you want an off the shelf but again you mention that it has to be a sure fit yet again you do not mind a custom fit and want that as soon as possible.
It all comes down to how you mounted the engine. what is the 2jz setup like since even with the weather right now if the proper radiator is not installed you'll have a problematic and endless heat issues.
ZRB is offline   Reply With Quote
Old 11-07-2016, 06:32 AM   #4
Aboodilatif
2jz GTE mounted w cxracing engine mounts
r154
gtx4088r
custom 3.5" intercooler
I'm probably gonna go for a Mishimoto BRZ radiator w the slim fan shroud and work around that.
thanks for the replies btw
ill keep this topic updated with what happens.
Old 11-20-2016, 08:34 PM   #5
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Fit your engine.
Measure.
Buy appropriate radiator.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
2jz, radiator, swap
WTB: OEM Radiator, Radiator Fan Assembly, Airbox, Condenser, Washer Reservoir, Winjet Xanatos Want-To-Buy Requests 1 01-05-2016 02:24 PM
OEM Radiator bjun Engine, Exhaust, Bolt-Ons 0 04-29-2015 05:57 PM
WTB OEM Radiator Philly758 Want-To-Buy Requests 0 03-16-2015 07:20 AM
FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) Sportsguy83 Engine, Exhaust, Bolt-Ons 15 05-27-2014 12:18 PM
Mishimoto Radiator & Mishimoto Radiator Hose Kit tlinspired830 Engine, Exhaust, Bolt-Ons 5 01-08-2014 08:44 AM
