Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-26-2016, 06:49 PM | #1 |
Drives: car
Would you rebuild your gearbox or buy another?
So say your syncros are worn or a tooth on 2nd gets chipped, I'm sure its happened to many a gearbox. When it comes time, what do you do: buy a brand new one, get a donor, or rebuild?
08-26-2016, 08:02 PM | #2 |
Drives: 2014 GT86
No one clear cut answer fitting for everybody. Too many unknown / undefined variables that may differ a lot for ones answering and where they are located. For example if car is still under warranty, how much gearbox costs new, how much costs donor gearbox, how much just worn parts, how much local shops charge for rebuild and how much for drop in replacement.
08-26-2016, 08:41 PM | #3 |
Drives: Late 2014 Subaru BRZ
Factory gearbox sucks, its a made out toilet paper.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
The Following User Says Thank You to GsxrMe For This Useful Post: | Sportsguy83 (09-30-2016) |
08-26-2016, 08:48 PM | #4 |
Drives: 2005 Toyota Camry
yes.
08-26-2016, 09:05 PM | #5 | |
Went to the junkyard, pulled out 3 transmissions, took them all apart, laid out the pieces in order, put all the best pieces back in the best case, put the rest of them back together, returned them to the junk yard ...... told them none of them fit. (sorry, times were tough .... we were poor......) Now, if I had transmission problems, I'd use that as justification to get a new car ...... humfrz |
The Following 4 Users Say Thank You to humfrz For This Useful Post: |
08-26-2016, 09:43 PM | #6 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
No.
08-26-2016, 10:06 PM | #7 | |
This^ This^ And especially this ^^^^^^^
08-26-2016, 11:51 PM | #8 |
Drives: Full race 4cyl boxer
Here's a clue: I just rebuilt a trans on my other car.
Working used trans ~350 ONE (used but mostly new) gear for the rebuild ~350. You do the math
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
08-31-2016, 11:22 PM | #9 |
Drives: 2013 Scion FR-S 6MT FA20
Factory gearbox with low mileage on eBay shipped for around 750
09-01-2016, 04:16 AM | #10 |
Junior
Drives: a car
Get the upgraded gearset (PAR?) then use that as an excuse to get a turbo!
09-28-2016, 12:14 PM | #11 |
Drives: Scion FRS - "FRSKY"
If you've got a few worn synchros, maybe a fork and synchro sleeve that needs to be replaced, then a rebuild is a good option, especially if you'll be getting back a trans that is massaged to shift better than OEM.
If you have broken a tooth on a gear then it gets a little more expensive, but frankly, the gears in this version of the AZ6 are not horribly expensive. Retail on the synchro gears is between $80-120. That being said, if 3rd or 4th is broken, then there's a high probability that the mating gear on the countershaft has sustained some damage. That shaft is almost the cost of a good used core, so that makes the decision a lot easier to make! |
The Following User Says Thank You to JacksTrans For This Useful Post: | radroach (03-09-2018) |
09-28-2016, 12:29 PM | #13 |
Drives: '05 Elise
[ame="https://www.youtube.com/watch?v=bbKGRESi6ME"]Sequential 6spd Toyota 86 by Holinger - YouTube[/ame]
'05 Lotus Elise
'19 BMW M2C '22 Subaru WRX ex '15 Scion FR-S |
09-28-2016, 12:49 PM | #14 |
Drives: 2014 GT86
DO WANT!! and probably will never afford
Similar Threads | ||||
gearbox issues | blown | Engine, Exhaust, Transmission | 4 | 10-13-2014 02:22 PM |
built gearbox? | Rocket.BRZ | Engine, Exhaust, Transmission | 2 | 09-07-2014 01:28 PM |
Gearbox Bushing Kit - BEST OFFER | HORSEPOWER DIRECT | Transmission and Driveline | 2 | 01-08-2014 09:35 PM |
Gearbox Stiffness? | pevangelista | Issues | Warranty | Recalls / TSB | 3 | 05-08-2013 01:00 AM |
Gearbox Oil | os86 | Engine, Exhaust, Transmission | 1 | 07-18-2012 02:37 PM |
