Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
05-08-2016, 02:51 AM | #1 |
Drives: 2015 Firestorm Fr-s
Running rough on e85
I seem to have the opposite problem as everyone else who switches to e85 for the first time. I switched tonight, followed the exact instructions. I left my 91 uel tune until fuel trims went way high. Then I re flashed to e85 uel tune. Seems simple enough but after giving the ecu time to learn the new trims and getting the long term fuel trim to level out around -3%, the car is running really rough. It feels like it did when I had the uel without a tune. Felt great on 91 uel tune with oft, but now rough on e85. Also, I never had crickets until I switched to e85. Good lord those things chirp loud.
Sorry for the long post! TL;DR: switched to e85 with oft, got crickets and runs rough. |
05-08-2016, 05:45 AM | #2 |
Drives: Panda FR-S
Before you switched to the E85 tune, how much 91 did you have in your tank?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
05-08-2016, 05:54 AM | #3 |
Drives: FR-S 10 Series
Total'd.
But seriously, a pump may be advertised as "E85" but the ethanol level will be much lower. Be aware of what you're actually putting in your car. |
The Following User Says Thank You to saj For This Useful Post: | 86kahl (05-08-2016) |
05-08-2016, 12:11 PM | #4 | |
Also, the gas needle was on the red so I assumed I was about to run out but I put in exactly 11.5 gallons of e85 so there must have been two more of 91 in there. |
05-08-2016, 12:32 PM | #5 | |
If your LTFT are only around -3% then the ethanol content is fine. If it was low ethanol content your LTFT would be -10 or less If ethanol content was high like 90% then your trims will be positive +5% or more. Are the fuel trims around 3% over the entire rpm range ? Take some logs look for IAM =1 LTFT less than say 7% or so +/- look at Commanded AFR and AFR(measured) some cars run pretty rich on E85 on oft tunes. |
05-09-2016, 12:55 PM | #6 |
FR-S Newb
The OFT is supposed to be able to run anywhere from E60-E90, which is the tolerance range that is regulated for E85 fuels. If you drive normally without pushing it for maybe 5-6miles after fill ups it should learn itself. I ran it for a couple months and could tell small differences between fill ups.
As for the crickets.... It's long since been determined that the ethanol in fuel caused the crickets... What did you think running 85% ethanol was gonna do... Haha. Learn to love the crickets, they are like your pets now.
"Driving is the synchronization of vision, analysis, and movement. It is an art form." -Unknown
The Following User Says Thank You to JSanders For This Useful Post: | Tcoat (05-09-2016) |
05-09-2016, 02:25 PM | #7 |
Drives: 2013 Raven FR-S
I used to think ethanol caused the crickets, but when I'm on E85 I don't get them. It's only when I'm running E10 that the crickets tend to appear. I honestly think it may have more to do with lubricants in the fuel than anything else.
05-09-2016, 02:26 PM | #8 |
I am convinced it is the ethanol but only in the smaller percentages.
05-09-2016, 02:28 PM | #9 |
FR-S Newb
I had bad crickets on E85... I switched back to 93 last fill up cause I'm selling the car . Maybe it's because I already had crickets before so it just made it worse. Who knows haha
Sent from my XT1254 using Tapatalk
Tags |
crickets, e85, idle dip, rough idle |
Similar Threads | ||||
Rough day for my 86 | KiddCoast | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 33 | 03-23-2015 03:30 AM |
ROUGH AROUND 2K RPM | COLGATE | Issues | Warranty | Recalls / TSB | 25 | 02-28-2015 03:50 PM |
'14 BRZ Ltd. - Rough Idle | leicaboss | BRZ First-Gen (2012+) -- General Topics | 20 | 05-22-2014 06:40 PM |
Rough Downshift (bog?) from 3rd to 2nd... | enwave | Issues | Warranty | Recalls / TSB | 8 | 08-29-2013 12:01 PM |
sema rough | nixeighty6 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 0 | 11-01-2012 04:30 AM |
