Old 03-16-2016, 08:29 AM   #1
tumbla.jr
taicho
tumbla.jr's Avatar
Drives: The rEd Fr-S
Sportronic Racing Turbo kit
Looks like south Africa gots some boosts and horse torx
Anyone ever heard of them before?
Surely someone will snap this up for the price.
http://www.ebay.com/itm/272167297421...%3AMEBIDX%3AIT
http://www.sportronicracing.co.za/#!...rz-turbo/l2sd2
tumbla.jr is offline   Reply With Quote
Old 03-16-2016, 09:23 AM   #2
raven1231
It looks like an altered greedy knock off.
Old 03-16-2016, 09:35 AM   #3
Cole
Not a troll
Cole's Avatar
Same supplier as SBD maybe?
Old 03-16-2016, 09:36 AM   #4
BRZSS
BRZSS's Avatar
Drives: Hyper Blue
Because anyone who runs the intake piping the same is an instant knock off
Well couple points against that notion. The SBD has flex joints on the Headers this one doesn't. It's also not cleanly welded. Looks hand made with off the shelf metal pipe. The passenger side exhaust has a wicked 90 curve it looks like. The wastegate pipe is vastly different. The intercooler is much smaller. The main intake pipe is different also, the Bov looks like it's further away from the TB. No heat shield or turbo blanket. The intake piping is different not just the BOV being mounted further as well. Doesn't look like it comes with a higher bar MAP sensor either.
The Turbo also looks like it just sits on the header flange. I don't see any mounting to support the turbo on the pulley bolts. I don't see any mounting hardware for the intercooler either.
Total Knock off.
I like how on their website it has a pdf for fitment. The Pdf just says "Coming Soon" on one page.
You can only mount a turbo in these cars a few ways in a few places. And if you keep the intake piping short you only really have one way to route it. So your going to have kits that are similar in placement. Now if any of those pipes have "Greddy" stamped to them and badly die grinded off, well that's a different story.
BRZSS is offline   Reply With Quote
The Following User Says Thank You to BRZSS For This Useful Post:
The Racers Line (03-16-2016)
Old 03-16-2016, 09:38 AM   #5
s2d4
s2d4's Avatar
This forum supports knock offs so it'll do probably do well if they pay the fees to be a vendor here.
The Following 2 Users Say Thank You to s2d4 For This Useful Post:
cdrazic93 (03-16-2016), mrk1 (03-16-2016)
Old 03-16-2016, 12:07 PM   #6
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Total Knock off.
Thank you. Apparently any kit that puts the turbo in between the motor and the radiator and has short piping, is a Greddy knock off. The JDL kit must be a Greddy knock off too because it has short piping. Don't forget about Revworks, they clearly copied Greddy... Please.
No one whines about the Hexon turbo kit, which is far more similar to the Greddy than this. This kit appears to use a WRX flanged turbo(many turbo options), a hand made manifold and some spray painted piping. It looks very cheap, but not copied. I would hardly call it a Greddy knock off.
The Racers Line is offline   Reply With Quote
The Following User Says Thank You to The Racers Line For This Useful Post:
raven1231 (03-16-2016)
Old 03-16-2016, 12:20 PM   #7
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Clearly a GReddy knock off. Look at it, it has a turbocharger, couplers AND clamps, as well as a BOV.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
The Following 2 Users Say Thank You to LOLS2K For This Useful Post:
Tectoniic (03-16-2016), The Racers Line (03-16-2016)
Old 03-16-2016, 12:28 PM   #8
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
how some people find these weird, obscure parts for our cars is beyond me.
Like, do you search google and then go to the 9th page of search results?
The Following 6 Users Say Thank You to continuecrushing For This Useful Post:
cdq85 (03-16-2016), cdrazic93 (03-16-2016), COO86L (03-18-2016), raven1231 (03-16-2016), Tectoniic (03-16-2016), tumbla.jr (03-16-2016)
Old 03-16-2016, 01:26 PM   #9
raven1231
Hexon is a knock off and no one wines about it because no one buys it.
Old 03-16-2016, 02:11 PM   #10
BRZSS
BRZSS's Avatar
Drives: Hyper Blue
Anyone who writes a story about a male protagonist going on an adventure is just ripping off Lord of the Rings. Or is it the Hobbit? Or Star Wars? Or Robocop? Maybe their ripping off Lord of the flies. Or hell, Jesus is a male protagonist who goes on an adventure. Every author is just ripping off Jesus!
They say their are only 7 basic plots that can be told. Any story ever made falls into one or a mix of several of those plots. Guess every author from Stephen King to Shakespeare is just ripping off someone else.
Again, you can only route a pipe in this car a few ways. You only have a few spots you can put a turbo. If it goes in the front between the radiator and the engine, then your header can only be shaped a certain way. So now you're starting to look similar to others. Not because your "copying" them but because from an engineering standpoint that's the most efficient design you can get.
Why do you think so many cars are starting to look to like each other? It's not because companies are copying each other. It's because physics dictate that a car can only be so aerodynamic and shapes will universally start to fall into the same style as THATS the most efficient form.
Best example. Did you know Russia was working on a Space shuttle at one time too. If you go look it up you'll find it looks almost identical to the USA shuttle. When Russian scientist were questioned about the design, concern being that the Soviet Union had stolen NASA secrets... they replied no. When making a reusable space capsule your limited in the ways you can return it to the earth. It will need wings to be "flown" in and landed. It will need a certain shape to keep g force stresses to a minimal during take off and re-entry. That "shuttle" shape is just the most effective form for doing that, that we can make at this time.
Greedy did nothing proprietary with their turbo kit. You can't patent charge pipe layouts. And reality is, if Zage stole from Greedy...why have they not been sued? Taiwan has a court system. Greedy is/was a big company. Zage pipes allegedly had Greedy logo's on them but Greedy claimed they had no parternship with Zage. That would mean Zage had gotten ahold of the molds somehow?
Its all very shady.
And seeing people run around and white knight with the "it's another Greedy ripoff" just makes me chuckle. No one knows what really happened or is happening with Greedy/Zage and this banner call for a company that frankly I've seen very few people run "Greedy's" kits on their cars, Is odd to me. If such love for Greedy, why do few people run their kit?
Anyways, enough ranting from me.
Greedy Justice Warriors continue your crusade.
Old 03-16-2016, 03:14 PM   #11
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Y'all arguing with a furry from Florida. Just in case you need a 3rd person perspective.
Jyn is offline   Reply With Quote
The Following 2 Users Say Thank You to Jyn For This Useful Post:
Dream20b (03-19-2016), raven1231 (03-16-2016)
Old 03-16-2016, 03:20 PM   #12
tumbla.jr
taicho
tumbla.jr's Avatar
What. Have. I. Done.
The Following User Says Thank You to tumbla.jr For This Useful Post:
Old 03-16-2016, 03:22 PM   #13
raven1231
Old 03-16-2016, 05:08 PM   #14
Dream20b
Y u do dis?
Can we call it a knock off knock off?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
Turbo XS H34 Racing Bypass / BoV... Uplink Engine, Exhaust, Bolt-Ons 0 03-12-2016 11:46 PM
Ultimate racing turbo kit brzy007 Forced Induction 49 12-17-2015 10:31 PM
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 11:25 AM
91 MR2 Turbo with KO Racing GT35R Turbo Kit Unleashed Cars for Sale/Trade 2 02-21-2013 05:18 PM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
