Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
02-19-2016, 06:19 PM | #1 |
Kouki-Monster
What oil weight are you running in your supercharged FR-SÉ
And why do we not have a sticky for this?
Please state the conditions you typically drive in and climate etc
Rich Anderson
EMPOWER AUTO |
02-19-2016, 09:02 PM | #2 |
Sarcastic SOB
Mobil 1 0W40. Rarely driven in winter, except a few local pleasure drives when its mild and dry. Have an oil cooler, non thermostatic. HKS recommends an oil cooler and minimum 40 weight in the supercharger install manual. Actually, they recommend 42 weight or similar but I think that is a typo.
Got a deal on the Mobil 1 from a guy off Kijiji. I know, the Subaru turbo guys from NASIOC says its the devil's nectar for the EJ engines, but the FA doesn't seem to burn it. I plan to track the car a few times this year.
02-19-2016, 11:47 PM | #3 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I run Mobil 1 5w-30 oil since I'm supercharged
02-21-2016, 02:14 AM | #4 |
hey you, yeah you <3
Drives: 2014 37J FR-S
0w20 most temps go from 50-110F
02-21-2016, 05:40 PM | #5 |
Drives: 2015 Scion FRS - Raven
Motul 5w-40 or Eneos 0w-50. My car is stored in the winter and sees only limited street use. I also have a non thermostatic oil cooler as well, I'm not supercharged but I would use the same if I was. 5w-20 is really just for fuel economy and emissions not for beating on it.
02-22-2016, 06:48 PM | #6 | |
Kouki-Monster
Just ordered a bunch of this. Exactly what I was thinking. I ran 0W-40 Mobil last year but for the use it's seeing this year ... 5W40 Motul + RS*R Ran Up
Rich Anderson
EMPOWER AUTO |
02-25-2016, 01:04 AM | #7 |
Drives: Scion FR-S Kraftwerks
0w20 ENEOS for me, I would try 0w30 soon
02-25-2016, 05:38 AM | #8 |
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
we are using the HKS HR 0W42
02-25-2016, 08:31 AM | #9 |
Sarcastic SOB
I thought the 42 was a typo. Guess not.
02-25-2016, 10:02 AM | #10 |
Master Tuner
no it is specifically tested on the HKS boosted FA20 platform, also the MX-5 uses this oil.
This is ester based oil so you can make any oil inbetween the normal grades. oil pressure is much more stable and oil temp keeps very constant. |
02-25-2016, 10:13 AM | #11 |
Drives: 2014 BRZ (SOLD)
I run 5w30 Mobil 1 (High Mileage Oil) car has 10kmiles on it.
Supercharged 2014 DGM Limited
02-25-2016, 10:13 AM | #12 |
Sarcastic SOB
Mobil 1 0W40 is also a true ester based oil (one of very few widely available in most stores) and is probably A LOT less expensive than HKS. I think it is the German spec oil.
The Following User Says Thank You to wbradley For This Useful Post: | ST-A (02-26-2016) |
03-15-2016, 11:29 PM | #13 |
Drives: '14 BRZ, '01 S2K
I've been running Castrol Edge 0w30 for the last 20k miles supercharged. I posted all my UOAs in another thread if you want to check it out.
http://www.ft86club.com/forums/showt...=13286&page=21 |
Similar Threads | ||||
What header are you running/ supercharged fa20's only | Epic_integra | Engine, Exhaust, Transmission | 15 | 03-30-2019 01:57 AM |
Weight distribution after supercharged BRZ? | Drakelee117 | Forced Induction | 8 | 02-08-2015 02:51 PM |
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 11:38 AM |
my supercharged brz | zenny | Member's Car Journals | 17 | 04-29-2014 08:46 AM |
My Supercharged GTS | Aussie Willy | Member's Car Journals | 23 | 07-12-2013 06:06 PM |
