Old 01-18-2016, 03:58 AM   #1
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
How to wash your engine bay area (DIY)
Hi guys!
In the spirit of FT86club, how much it has given to me and how amazing the community is, I thought i'd make a DIY on how to properly clean your engine bay when cool and make purty.
Prep time: 10min
Cleaning time: 30min if in hurry, 1hr-3hr recommended!
BEFORE
Things needed:
1) GUNK Foam
2) GUNK engine 'protector' aka dresser
3) Small One Dollar store brush or similar to this. Can also use a baby bottle brush like this for the hard to reach areas.
4) Terry towel or thin towel to later help the drying process [optional]
5) Distilled water if possible. If not, just use tap.
Step 1:
Things to consider:
Covering the alternator
Covering your intake
Covering your fuse box
Covering your battery***
Covering your oil filter*****
If there is something you think should not get wet, cover it! Better safe than sorry!
***You can also remove your battery. I did not. Instead I had music playing.***
*****Oil filter collects water between oil filter cap and where it connects! FYI*****
Step 2:
If you have a vacuum that can also blow air, leaf blower, or even better, a air compressor, blow air on to your engine to remove light dust, leaves and other non-native pollutants that may be in your engine bay.
Step 3:
Once you are ready to go, shake the GUNK can for a good 15 seconds, then spray the engine all over from a distance of 15 inches or about 1 foot away. Wait about 5min so that the foam starts to degrease/unstick the dirt and then grab the brush[es] and start to brush away!
I waited about 10min, then sprayed some more and brushed again!~
Step 4
Use distilled water to rinse the engine bay. If not, just softly spray bay down with a hose. Be careful to not spray directly into areas with a strong pressure. Doing so may get water in hard to dry areas, or force water into/inside components.
Allow car to dry or aid in the process.
Use terry cloth/towel/etc to help the drying process. You can also use an air compressor to blow the water that has created puddles in your engine bay.
Step 5
Use this time to remove the plastics covering your electronics (after no water is dripping) and wiping down the battery, exterior of alternator, intake box and fuse box. It shouldn't be crusty with dirt much. Easy wipe and clean.
Step 6
Grab your GUNK engine dresser and lightly:
1) Spray a terry towel and rub on all black components including wires and tire covers.
OR
2) Spray all over engine**** and after letting it sit for a good 5min, wipe with the terry towel.
****if you sprayed all over engine, for a few days it will smell like GUNK spray when driving****
I waited about 5min, then resprayed a few areas. Outcome is below.
Final step:
Re-add the battery if you removed, and make sure no plastic pieces are left on. Wait about 2hrs after GUNK dresser is on to start so that it can set on plastics. I waited overnight with hood open and placed a fan on for 40min blowing into engine bay to aid the drying process.
Note: you can start your engine right after you are done washing, but I prefer to be safe and allow water to evaporate.
Also, using distilled water reduces the likelihood of water spots (white spots) on engine components.
I also took over 3-4hrs to do this whole process so my battery died due to having radio on, doors open and trunk open.
Special thanks to the old geezers of ft86club who are always ready to set dealerships on fire when they don't get things their way. You guys know who you are!
Feel free to share how you clean your engine. This is my first time cleaning the FA20. It was a 4/10 dirty. Remember, proper timely maintenance is the key to a long lasting engine.
BEFORE
p.s. if you like my DIY let me know so I can make a few more in the future!~
Packofcrows is offline   Reply With Quote
The Following 19 Users Say Thank You to Packofcrows For This Useful Post:
Anthony (01-19-2016), brandonblt2 (01-18-2016), Delfin (12-01-2018), Elkton86er (01-18-2016), JMon85 (04-27-2018), khantran04 (02-28-2016), kravi (11-23-2016), mike_ekim1024 (01-21-2016), MisterSheep (01-18-2016), mixtape (07-28-2016), MJones_RB (05-10-2017), ollie (01-18-2016), PandaSPUR (01-19-2016), RL_BRZ (01-19-2016), shaynek (01-18-2016), Sideways (01-18-2016), Teseo (01-19-2016), VMRamos (01-18-2016), zberz (01-18-2016)
Old 01-18-2016, 05:15 AM   #2
ollie
ollie's Avatar
Drives: GT86
Cheers buddy it look brand new after the clean. Never though about cleaning my engine bay but will do now
ollie is offline   Reply With Quote
The Following User Says Thank You to ollie For This Useful Post:
Packofcrows (01-18-2016)
Old 01-18-2016, 11:39 AM   #3
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Thanks for this!! Been always trying to find an efficient way of washing our engine bays.
Instagram: trevor.parque
Old 01-18-2016, 11:50 AM   #4
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
Nice DIY. I also use Gunk engine protector to keep everything looking clean in the engine bay.
But, you forgot to add to rinse with water between step 3 and 4 before drying your engine bay.
Sideways is offline   Reply With Quote
The Following 2 Users Say Thank You to Sideways For This Useful Post:
MisterSheep (01-18-2016), Packofcrows (01-18-2016)
Old 01-18-2016, 11:50 AM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
LOL I rinse, spay de-greaser if I feel like it, then use interior vinyl shine on the whole engine while its wet (and dont bother dry it) and it takes me all of 3 minutes to get this look. I don't bother cover anything lol. (and yes the gold foil has since been removed after much experimenting I determined it was not effective enough)
The Following 3 Users Say Thank You to go_a_way1 For This Useful Post:
MJones_RB (09-23-2019), Pedro13 (09-24-2020), smg1138 (05-12-2017)
Old 01-18-2016, 01:11 PM   #6
Packofcrows
Thanks! I spaced out there. Fixed.
The Following User Says Thank You to Packofcrows For This Useful Post:
Old 01-18-2016, 06:55 PM   #7
zberz
Drives: 2015 Lightning Red BRZ
Looks good! You're a better man than me for spending that much time on the engine bay.
sent from my phone using black magic
zberz is offline   Reply With Quote
Old 01-19-2016, 05:05 PM   #8
Packofcrows
spending time for the benefit or the car, or OCD? Not sure yet. heehee
Overall it was a fun activity. Next up will be a stock wheel cleaning, proper interior maintenance and proper 'quick' wax+detailing exterior. Just look at my crazy garage items!~
The Following 2 Users Say Thank You to Packofcrows For This Useful Post:
new2subaru (01-19-2016), Teseo (01-19-2016)
Old 01-19-2016, 08:19 PM   #9
zberz
Nice. I can be OCD about maintenance and the exterior, but that's a lot of time spent making the engine bay pretty when you're probably going to be the only one seeing it. Maintenance though... I cringe when torque specs aren't included...
Edit: If you have a good method for the quick wax, please share. I normally spend 2+ hours with carnauba wax.
Old 01-19-2016, 09:20 PM   #10
Teseo
Drives: frs
Alert! Anal guy
Old 01-19-2016, 09:26 PM   #11
us3less24
chris86
Drives: Frs 2015
Send a message via Yahoo to us3less24
I always wanna know how to clean, and now I know how to clean the engine bay. But so lazy to do that hahaha but gonna save it for the future hahaha
Sent from my SAMSUNG-SM-G900A using Tapatalk
us3less24 is offline   Reply With Quote
Old 01-19-2016, 11:24 PM   #12
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
Attachment 129391
moar details?
phanguy is offline   Reply With Quote
Old 01-19-2016, 11:27 PM   #13
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Originally Posted by phanguy View Post
moar details?
Literally thats it. Rinse then spray with vinyl dressing while wet thats simply it. No need to cover anything or scub if you rinse it often enough.
Old 07-28-2016, 03:01 PM   #14
tskaohu
tskaohu's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWS
Shame the pics are gone, would make it a bit easier trying to figure everything out hahaah
1320 Performance Headers & Overpipe | HKS Hi-Power Spec-L Catback Exhaust | Delicious Tuning Flex Fuel Kit | Delicious Tuning Stage 2 Tune | Tein Flex A Coilovers | 20 & 25 MM Spacers
tskaohu is offline   Reply With Quote
Looking for Touchless car wash 626 area Cyau Southern California 4 06-14-2014 10:26 AM
Underbody car wash in Bay Area BigFatFlip Northern California 3 03-04-2014 05:00 PM
any weekly meets in the queens area or long island area subyboy NY / NJ / CT / PA 23 08-26-2013 07:51 PM
Can you recommend a hand wash car wash in Las Vegas whaap Southwest 3 05-14-2013 07:55 PM
Any Good Touchless car wash in Phoenix area JesseE Southwest 0 04-11-2013 05:12 PM
