Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
05-08-2014, 05:39 AM | #29 |
Drives: toyota
I follow the 4k rpm guideline as the manual actually says that.
After break in, if I put it at 7k, I'll probably never hear that rev limiter beep. Maybe I'll put it at 6k so that I can still hear it occasionally. |
The Following User Says Thank You to djmm For This Useful Post: | Chattanooga FR-S (05-08-2014) |
05-08-2014, 07:52 AM | #30 | |
Drives: Monogram Firestorm
I figure I spent my money on this as my daily driver, something I plan on keeping for at least 10 years, so I'd rather follow the manual just to make sure it didn't come back to bite me several years from now. If it also gave me time to get used to the car's power, handling, etc., then that's a bonus. And no, I do not always follow every rule/guideline/law/etc., but I probably stay on the more cautious side most of the time. Even with that, I still enjoy this car every time I see it or drive it, still drive it fast and twisty sometimes, and I don't feel like I really lost out on much of anything by following the manual for the first 1k miles. After all, it was only a couple weeks. |
05-08-2014, 08:14 AM | #31 |
Drives: 2014 BRZ Limited
A couple of things to consider:
While new engines are manufactured to better tolerances and with better materials than they once were, there is still a period in which the engine is being broken in, as evidenced by the metal particles you will find in the oil on your first oil change. This is a period when all the parts are wearing against each other to find their fit as they flex, expand and contract. An engine cannot be manufactured such that the metal does not change at all during the break-in period. Break-in is also a period when the zinc and phosphorus in the oil are bonding with the metal to help create hard, slick surfaces on the wear parts. While there doesn't seem to be as big a reason to baby these engines, they don't come from the factory the same as they are after a few thousand miles. What's more important than limiting your revs is the break-in suggestion that you vary the load on the engine and avoid using cruise control. Driving along using the cruise control breaks the engine in at a single load and will cause the rings to seat for that load only. You want the cylinder to initially wear in a tapered shape so that the rings seat properly all the way through the stroke, but using cruise extensively during break in tends to create more wear at the top and bottom and less at the middle, so that the rings never really seat quite right throughout the stroke. |
The Following User Says Thank You to extrashaky For This Useful Post: | AznKirby (05-23-2014) |
05-08-2014, 08:15 AM | #32 |
Drives: Raven Black
drove to 1001 miles and beyond
05-08-2014, 08:19 AM | #33 | |
Drives: 2013 asphalt scion FRS
And yes, my car hit red line, drove all gears, hit every rpm. I'm a believer that you drive a car the same way you intend to for its life. Has worked on every motor I have ever rebuilt/bought new. From crates to 200k rebuilds.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
The Following 2 Users Say Thank You to J_kennington For This Useful Post: | 86-tundra (05-08-2014), Pseud0logik (05-09-2014) |
05-08-2014, 08:28 AM | #34 |
Drives: 2014 FR-S 6MT Whiteout
These days break-in has more to do with liability (hey, we told the owner to take it easy, it's not our fault he wrapped his car around a tree because he didn't know how to drive it yet) than with mechanicals.
The Following User Says Thank You to phobos512 For This Useful Post: | 86-tundra (05-08-2014) |
05-08-2014, 08:30 AM | #35 | |
Drives: toyota
But I don't baby it either (or else what's the point of buying the car) - only plans to every now and then to rev it hard when I feel like it and when the road condition is safe. |
05-08-2014, 09:23 AM | #36 | |
I think Toyota/Subaru know their customers are not going to stay below 4000 RPM. What you don't want during the break-in period is constant abuse of the engine. This guideline gives you enough load on the engine to properly seat everything without abusing it while the surfaces haven't set up. |
05-08-2014, 05:41 PM | #37 |
Speed Chaser Thrill Seekr
Drives: 2014 Asphalt Monogram FR-S 6MT
I took this picture
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint My Build |
05-08-2014, 07:12 PM | #38 |
Troll Hunter
Drives: fr-s, tundra
I've still yet to see any solid evidence indicating something broke due to driving hard in the break in period. The only real way to tell would be to drive 2 identical cars the exact same way after 1k miles, but hoon one and drive one like a grandma for the first thousand miles.
I dunno how many times I hit redline on the way back from the dealership.. it would probably make most of you cringe
05-08-2014, 07:15 PM | #39 |
Drives: N/A
I pulled over a took a picture.
Sent from my Nexus 10 using Tapatalk
2014 BRZ, SWP, OFT, Kosei K4R 17x7 with ZII SS
05-08-2014, 07:59 PM | #40 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Two week roadtrip. Passes and canyons.
"I gotta rock." -- Charley Brown |
05-08-2014, 08:12 PM | #42 |
Drives: 2013 Firestorm FRS
dropped a couple gears and hit redline on the freeway
Similar Threads | ||||
Just hit 1000 Miles | vinh359 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 02-16-2014 05:48 PM |
Almost at 1000 miles. Oil change when? | TheGuyWithTheFireStorm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 08-08-2013 12:31 PM |
FS in IL - OEM tires only 1000 miles | Captain Insano | Wheels and Tires | 9 | 07-21-2013 06:39 PM |
1000+ miles | jarviz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 31 | 02-02-2013 12:23 AM |
1000 miles | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-29-2012 02:42 PM |
