11-18-2023, 03:41 PM | #211 | ||
Drives: None
It does seem like there is no good dirt cheap way to do it right. $800-ish minimum using a Setrab fan/cooler pack, Genesis pump, thermostat, and lines. We will see, I'm not really sure where I want to mount everything too, I'd rather it be in the right rear of the car for weight distribution.
11-21-2023, 02:01 PM | #214 | |||
Drives: Fr-s
The Following User Says Thank You to redlined600 For This Useful Post: | RedReplicant (11-21-2023) |
11-21-2023, 03:00 PM | #215 | |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
Regarding sensitivity to set up, you are right in that higher spring rates, all else equal, make the set up more sensitive. Higher rates also make the car more sensitive to driver inputs. So smoother, slower inputs are required to extract the extra speed potential. Sway bars are springs too so adding more bar has the same downsides of more spring; additional sensitivity to set up and driver input. Agreed though, when we wen to 616/616 (11kg) rates on Blub, it was definitely a tad harder to drive than 500/500, but also quicker. Let us know what ends up working for you.
The Following 4 Users Say Thank You to 949 Racing For This Useful Post: |
11-22-2023, 06:58 PM | #216 | |
Drives: None
By setup/tire dependent I mean that the car can go from right on balance wise to too tight depending on the track and tire heat cycles. For example, at Arizona Motorsports Park on sticker RC1s the balance was pretty good. When I went to Podium Club with 5HC on the tires and an incredibly rubbered / abrasive surface the car was tight mid corner, which cascaded to the expected higher front tire temps and accelerated wear. I ended up going out and measuring everything this afternoon. Current relevant parts: 500/600 Rates w/ Roll Center Correction 22mm Perrin front full soft / Karcepts rear, prior was a Mann on full stiff 17x9.5 +40, 5mm spacer up front to keep the tire out of the dust boot OSGiken Diff I can add the rest of the front camber plate (it is one hash mark on the plate), the rear I need to find a thin jamb nut for and it'll give me -3.3*.
11-24-2023, 12:13 AM | #217 |
Drives: None
Talked to a few other friends that were at Podium Club that day and they all reported the same thing - cars felt great at Arizona Motorsports Park a few weeks earlier then lots of understeer at Podium Club. Track was really just overly hooked up.
I signed up for a Porsche Club event for 12/2 at Podium Club - leaving the springs at 500/600 and bringing all three rear bars with me.
The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | autoracer86 (11-24-2023), RToyo86 (11-24-2023) |
11-26-2023, 02:13 PM | #218 |
Everything else being equal, adding grip will tighten a car up a bit. Once we get a car setup working for a particular tire, we tend to just raise or lower the rear to fine tune mid corner balance. Front is typically as low as we can go without bottoming so adjusting rake is our preferred trackside tweak for different tracks or weather conditions.
Pyro readings good?
The Following User Says Thank You to 949 Racing For This Useful Post: | RedReplicant (12-03-2023) |
11-28-2023, 09:53 AM | #219 | |
At the track
Drives: '14 FRS - Former e92 M3
This seems to be common on newer surfaces for the cars to be pretty understeer-prone on new surfaces and then ease up over time, we experienced similar here when Eagles Canyon was repaved. Just adjusted setup accordingly per each track.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
The Following User Says Thank You to Kelse92 For This Useful Post: | RedReplicant (12-03-2023) |
12-03-2023, 03:49 PM | #220 | ||
Drives: None
Yesterday went pretty smoothly other than some dumb first session PCA shenanigans involving me, a Cayman GT4, and a Cayman GT4 Clubsport.
First session was a waste since the Clubsport refused to point me by, but it let me know the Karcepts bar I'd put on full stiff wasn't enough so I slapped in the OEM 2017+ 15mm bar I brought with me and that helped a lot. Played with the knobs a bit and I was pretty happy with the balance for the grip at Podium Club while somehow experiencing zero EPS cutout. I was able to get a handful of rolling lap matches to my PB in the last session of the day on a set of almost corded RC1s. I was playing it pretty safe all day, especially through the uphill after the esses and the following left hand downhill sweeper, since there was nothing to win. I had AIM issues, so this is the quickest complete lap from session 3. A pretty casual 1:42:18. I'm pretty happy with that since I left a bunch of time on the table being safe in a few spots and the difference a set of stickers makes over 22HC ones. This is half a second off my PB. Quote:
Also, there is a roughly 10-15f delta between the hotter front temps versus rear. Is that about normal, or do you try and get them to be pretty much within 5 degrees or something. I'm slowly coming to terms with the idea that the car doesn't need to have any drama to be fast, if that makes any sense. It is just smooth and ridiculously easy to drive.
The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | autoracer86 (12-07-2023), villainous_frx (12-03-2023) |
12-03-2023, 07:33 PM | #221 |
Most radials are fastest when inside temps on loaded side (left tires on clockwise track) are 15-20 hotter than shoulder with a fairly even gradient across tread. Inside tires will be cooler. Some course heat fronts more than rear, other courses are the opposite. More than F to R temps I simply look for balance. When its really easy to get the nose pointed down to the apex with only gentle trail braking and allowing early power application without power oversteer. And yeah, when it's dialed, its very easy to drive fast. You'll find that your fastest laps are the ones with the least steering input and corrections. Basically steering with the pedals. Bit of trail brake on entry, full power early without lots of steering lock to get the job done.
Regarding RC1 pressure, yes slave to the pyro numbers. Be willing to experiment but the pyro will get you in the right neighborhood. Our pyrometer FAQ .
The Following 3 Users Say Thank You to 949 Racing For This Useful Post: |
12-12-2023, 08:05 PM | #222 |
Drives: None
Last NASA event of the year went pretty smoothly, didn't drive real well and corded my other set of RC1s but I pipped the 5 record by .030s for a win. Got to play with my collection of rear bars too.
1:47:717 on official timing We don't know what NASA is going to do rule change wise for 2024, so I'm kinda frozen at this point. I ended up doing the math on my new motor dyno from a couple of months ago and got 199whp. This so happens to be the exact number to run a 1.0 tire with zero changes to the car... I'm mostly considering this because I'm out of tires, Maxxis is currently backordered on the RC1, and I need a set of something in the next three weeks for the first events of the 2024 season. RE71RS or CR-S, we will see. I intend to go get destroyed at Utah NASA nationals in August.
The Following 7 Users Say Thank You to RedReplicant For This Useful Post: | 949 Racing (12-13-2023), autoracer86 (12-13-2023), DocWalt (12-13-2023), gt5759 (12-13-2023), new2subaru (12-13-2023), Pat (12-12-2023), villainous_frx (12-13-2023) |
12-13-2023, 07:00 AM | #223 |
Drives: '22 BRZ
Going to consider the new Toyos too?
I'd do the CR-S before the RE-71RS for your use, I think.
12-13-2023, 10:49 AM | #224 | |
Drives: 2017 BRZ
I found the CR-S to not have the same lateral grip as the RE-71S. The CR I felt put the power down better oddly enough. They both ran pretty much the same times for me. The RE also had more grip first out the gate, CR needed some heat to come on. Just my worthless two cents on any of this. Also, the Yoko A052 was faster for me than either of those, but I am not a tester and did not do all of this on the same day. |
Similar Threads | ||||
Silviacrazed's FR-S adventure | Silviacrazed | Member's Car Journals | 52 | 06-01-2021 10:20 PM |
Harrop 2015 TVS kit image.. | FT86_AU | Forced Induction | 255 | 07-25-2016 02:50 AM |
SubieBuis BRZ Adventure | subiebui | Member's Car Journals | 13 | 12-06-2015 04:57 PM |
Off The Grid Adventure | m.box.design | Northwest | 8 | 03-22-2014 12:05 PM |
What would you consider an adventure trip in your FRS/BRZ? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 04-07-2013 05:54 PM |
