Software Tuning Discuss all software tuning topics. |
04-04-2016, 02:38 PM | #15 | |
Drives: 2015 Firestorm Scion FRS
The Following User Says Thank You to G-awesome For This Useful Post: | deuncos (04-04-2016) |
04-09-2016, 07:21 PM | #16 | |
I haven't applied the JDL specfic cam timings yet. Let me know your thoughts! |
The Following User Says Thank You to G-awesome For This Useful Post: | deuncos (04-10-2016) |
04-09-2016, 08:28 PM | #17 | |
04-09-2016, 10:18 PM | #18 | ||
Drives: FT86
its getting a bit of knock arround 3000 area that looks like its dropping iam, you need to log iam as well drop kc learned. the ltft are a bit high in places, so probably needs a bit of maf scaling |
04-10-2016, 01:26 AM | #19 | |
04-10-2016, 09:55 PM | #20 |
I think I'm starting to understand datalogging/dyno runs/tuning much better after doing a bit more research!
I figured out how to use RomRaider, apply the JDL cam timings and updated the OFT tune accordingly. I never thought I would ever mess around with ECU tunings but there's a first for everything and it was really cool learning experience. Anyways, I found a fairly quiet office park in Vancouver and did a bunch of runs hoping that no cops miraculously popped up during a run. Here's the fresh batch of datalogs: First gear pulls (3 runs): http://www.datazap.me/u/gawesome/201...3?log=0&data=1 Third gear pulls (3 runs): http://www.datazap.me/u/gawesome/201...0?log=0&data=1 So from my understanding, I noticed that IAM stays constant at 1 for the first gear pulls which is good but with 3rd gear pulls, it fluctuated from 0.98 to 0.94 so there's a tad bit of knock? Chevron is the only gas station in Canada that sells 93+ Octane gas (which is what I use) and is the most convenient. Shell 91 V-power is the next best thing but with fewer fueling locations. Let me know your thoughts! |
The Following User Says Thank You to G-awesome For This Useful Post: | deuncos (04-11-2016) |
04-10-2016, 10:54 PM | #21 | |
Drives: FT86
looks reasonable It running a bit on the rich side higher rpm maybe just do the OL maf scaling or maybe try wayno's example maf scales or have a read of his guide to adjust your ol maf scale . As its rich its not dangerous but will likely cost you a few hp. yes you have some knock in a few places, if that's the best fuel available easiest option will be to copy the BASE TIMING B table from wayno's example maps, its smoothed and has a degree of timing removed over 5000 rpm. that will likely sort your knock. get your fuel sorted first then tackle the knock. |
The Following User Says Thank You to steve99 For This Useful Post: | G-awesome (04-10-2016) |
04-10-2016, 11:50 PM | #22 | |
Drives: Toyota 86 GTS
People on petrol should be using the OTS AVCS tables or the UEL tables copied from my examples. |
04-11-2016, 02:00 AM | #23 | |
Drives: FT86
Yep use wayno,s avcs for uel will likey be slightly better for petrol. although it was optimised for ofh catless header. |
04-11-2016, 04:15 PM | #24 | |
The Stig's German cousin
Shiv stated earlier in that thread that the E85 AVCS shouldn't differ from the petrol map: Furthermore I have tried both the OTS mapping and this special mapping on my JDL UEL, and the car went from "why doesn't it drive like my friend's" to "this car totally drives like my friend's!" |
04-16-2016, 08:39 PM | #25 |
Since Shiv released his OFH tune a few days ago and I'm currently mucking with my Stage 2 UEL tune at the moment, I decided to load the OFH tune in my car just to test it out on my JDL catted UEL header for shits and giggles. One thing I noticed right away is that the cold start has been disabled since the OFH are catless which makes sense.
Here's the results (2 runs): http://datazap.me/u/gawesome/2016041...ta=1-8-9-10-13 Just note, I haven't modify the tune with the JDL VVT data, base timing B tables, MAF scaling, or any of the good stuff yet. This is purely a baseline run. So if I'm interpreting the data correctly, my fuel is still running a bit rich as before (but not as bad as before?), and I'm getting a bit of knock. Thoughts? |
The Following User Says Thank You to G-awesome For This Useful Post: | tato.valverde (04-18-2016) |
06-18-2016, 08:38 PM | #26 | |
Drives: 2013 GBS BRZ Limited
You should log a run all the way up to redline though, I'm also running a JDL Catted UEL header as well, and on the Stage 2 tune I saw most of my knock between 7000-7300 RPM, and had to pull a small amount of timing. Here is a recent run of mine: http://datazap.me/u/bfife22/618-run-...0&data=1-10-12 If you've since updated your tune with the JDL VVT data, let me know how it worked out for you!
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
06-19-2016, 01:13 AM | #27 | |
I did a lot more research and experimenting with many tunes since then and I'm currently running a modified stg2 tune on better quality shell 91oct gas than the chevron 93oct gas that I was using before. Turns out using crappy gas with the catted uel header made my engine very knock-y around mid to high range rpms and made my IAM fall faster than Justin Bieber's fall from grace! I used a more OEM maf scale using Wayno's stg2 'lean' version which got my afr closer to commanded afr so it's running less rich and better ltft overall. Also pulled a bit of timing in the knock-y areas. Will be adding a touch more timing back into the ignition map and collecting more data to make sure I'm not pulling tooo much timing. Looking at your log, I think you can optimize your MAF a bit further so it's closer to commanded afr so it's not as rich. It should improve your ltft closer to 2-3% instead of 7%. Or you can leave it as is so it's running richer as a precautionary measure at the expense of more fuel used. Will be working on my 93oct tune next! I should be done by the end of summer at this rate! |
The Following User Says Thank You to G-awesome For This Useful Post: | TofuJoe (11-24-2016) |
06-19-2016, 12:41 PM | #28 |
Drives: 2015 86 GTS
Your tune looks much better.....
Can I just check - did you apply the JDL specific AVCS timing to your tune? If not, was is just OTS OFT Stg 2 UEL AVCS timing or did you customise? |
Similar Threads | ||||
catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 12:32 PM |
Catted Header or Stage 1 Tune first? | Mr.Impreza | Engine, Exhaust, Transmission | 12 | 09-04-2015 05:35 PM |
JDL Catted UEL header VS ft86speedfactory catted UEL | Teclis | Engine, Exhaust, Transmission | 4 | 05-28-2015 02:19 PM |
Catted header or catted front pipe? | wilfredwong | Engine, Exhaust, Transmission | 5 | 02-09-2015 06:11 PM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
