Old 08-16-2014, 08:17 AM   #197
steve99
Originally Posted by TheRoadWarrior View Post
Curious: is Australian 98-100ron fuel the same as the UK octane rating?
Over here the highest octane rating available is 99ron from tesco.
Octane ratings are done in some kind of contraption in a lab as I understand it. So fuels can perform differently in the real world, even in same country the performance of a say 98RON fuel can vary as far a knock resistance goes.
Best to just log for knock and see which brand of fuel is best.
Old 08-17-2014, 07:04 AM   #198
tmichel
tmichel's Avatar
Drives: Sonic Blue 2014 GT86
Hey Steve before you changed to 85 which 98 were you running?
tmichel is offline   Reply With Quote
Old 08-17-2014, 04:56 PM   #199
steve99
Used Shell V Power 98 , seems better than Caltex Vortex 98 for knock.
however United 100 octane seems to be the best if you can get it.
Old 08-17-2014, 06:13 PM   #200
tmichel
tmichel's Avatar
Got Shell in it at the moment will try United in the next tank, also loaded your map now on OFT but will try the fuels first as you suggested.
The Following User Says Thank You to tmichel For This Useful Post:
steve99 (08-17-2014)
Old 08-17-2014, 06:22 PM   #201
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Shell used to always put extra shit in their fuel to "clean your engine" and BP was more potent. I haven't tried Shell for 10 years!
Old 08-17-2014, 06:51 PM   #202
tmichel
tmichel's Avatar
I used to run BP in my XR5 as it gave it the most poke but Shell was a close second.
Old 08-18-2014, 11:02 PM   #203
tmichel
tmichel's Avatar
Missus rang me today to say how much smoother the car is running now , thanks OFT and Steve.
Old 08-21-2014, 11:44 PM   #204
steve99
Added some more info to original post for Intake Air Temperature vs Ignition Timing retard tables if knock is temperature related.
Old 09-27-2014, 06:01 AM   #205
tmichel
tmichel's Avatar
http://datazap.me/u/tmichel/98-bp-27...-5-6-7-8-11-12
Steve can you please have a look at this one flat rd BP98 3000 to 7000 and I think I measured what I should?
Old 09-27-2014, 07:39 AM   #206
steve99
Hmmmm looks a bit ordinary IAM 0.52 FLKC over 2 degrees correction
what map are you running V2 ? are you stock or on stage2 man/auto ?
definitly try shell vpower 98 or preferably united 100 ron that BP fuel does not appear to be much good.
If your stock manual i can send you a map for Shell 98.
tmichel (09-27-2014)
Old 09-27-2014, 09:41 AM   #207
tmichel
tmichel's Avatar
Yep running V 2 on stock manual if you could send the map for Shell that would be great
Old 09-27-2014, 11:40 PM   #208
steve99
OK attached is ROM for 98 RON Its based on OFT V2x tune with some timing pulled at top end and at low/med rpm high load due our crappy fuels.
also has IAT vs Ignition retard increased for our high temps and added some ignition retard if Coolant temps get to over 100C (212F).
Also has couple of mods to high rev cold start to quieten it down less MAF adjustment less Ignition retard and less RPM at cold startup.
The Following 4 Users Say Thank You to steve99 For This Useful Post:
blue cat (09-29-2014), Gums (10-12-2014), tmichel (09-28-2014), Wayno (09-27-2014)
Old 09-27-2014, 11:45 PM   #209
Wayno
Wayno's Avatar
In case you haven't heard, United is discontinuing P100 very soon
The Following User Says Thank You to Wayno For This Useful Post:
steve99 (09-27-2014)
Old 09-27-2014, 11:53 PM   #210
steve99
you can make your own P100. Add 6 litres of E85 to a tank of 98 RON (ethanol free stuff)
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Pistol (10-11-2014), tmichel (09-28-2014)
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
