Old 08-02-2015, 08:15 PM   #1
pantdino
Drives: Firestorm 2013 FR-S
any real fix for non-linear throttle?
My apologies in advance for not searching for this topic, but I couldn't find anything after searching using a dozen different word combinations.
This car has the typical "Japanese" throttle response, where you get a lot of response with the first bit of pedal motion and the gain beyond that point is much less. I tried the "disconnect battery, reconnect, then depress pedal 15 times" (or whatever it was) but it made no discernable difference.
Does the car really "learn" your driving style or is that BS?
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 08-02-2015, 08:17 PM   #2
juliog
juliog's Avatar
Drives: 86
Most tuning solutions let you alter the throttle mapping to your liking.
juliog is offline   Reply With Quote
Old 08-02-2015, 09:30 PM   #3
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
AT or MT?
The Following User Says Thank You to Wayno For This Useful Post:
NWFRS (08-02-2015)
Old 08-02-2015, 10:00 PM   #4
pantdino
Originally Posted by Wayno View Post
AT or MT?
AT. But when in Sport or Manual mode the torque convertor is locked up, so it is difficult to feed in a little throttle without the car without jerking
Old 08-02-2015, 10:01 PM   #5
Wayno
Wayno's Avatar
Yes, the AT map is non linear compared to MT. The only choice you have is a tuning platform. The good news is you can just copy the MT map directly over. No actual tuning required.
Old 08-03-2015, 01:46 AM   #6
pantdino
Can you recommend which would be the easiest / least expensive platform?
I have to admit my ignorance-- is this something I can do myself?
Thank you,
Jim
Old 08-03-2015, 01:51 AM   #7
Wayno
Wayno's Avatar
Openflash tablet. See software sub forum.
Old 08-03-2015, 08:01 AM   #8
burdickjp
Drives: 2013 ultramarine Scion FR-S
OFT would be easiest.
Tactrix would be least expensive.
burdickjp is offline   Reply With Quote
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Linear (No progressive) springs Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 08-23-2014 05:23 PM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 12:44 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
