Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-26-2019, 12:22 PM | #29 |
Drives: 2016 Scion FRS
If you still have the previous wheels and tires, it would be really easy to see if the extra wheel/tire width (and possibly weight) has the impact that you are experiencing.
Also, easy and worth checking tire pressure. |
The Following User Says Thank You to steverife For This Useful Post: | soundman98 (11-26-2019) |
11-26-2019, 12:58 PM | #30 |
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
11-26-2019, 01:21 PM | #31 |
Wes
I would also suggest this based on my personal experience of getting sticky tires with 18x9.5 wheels and having this floaty sensation in the corners with what felt like lateral movement, which I think I even made a thread about somewhere. Ended up being coilovers. After I firmed up the settings, the handling "symptoms" went away, although still present at high cornering speeds, which leads me to believe that it's damping, which is also supported by the fact that I have entry level coilovers. I think once I switch to a quality suspension like KW or Ohlins, it should go away. Then again, I have to go pretty damn fast in a corner to trigger that suspension reaction.
Instagram: @gt86ws
The Following 3 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post: |
11-26-2019, 03:43 PM | #32 |
Drives: 2018 BRZ PP (Modified)
I know many on this forum like to harp on the wide wheels thing -- but in my firsthand experience on Rays 18x9.5 +38s wrapped in 255s with HKS coilovers and SPL RLCAs, the car still handles like it should and is still easily light on its feet. Definitely is a little less darty/nimble on initial turn-in compared to stock, but is by no means "sluggish". I'm also between -2.5/-3 deg camber all around so the car is still eager to turn. If I were doing trackdays every week I would swap to 17x9s Volks & RE-71rs to try and get every second back I could, but on the street there's not that much difference in feel in my opinion. Can't beat the concave look on the 18x9.5s either
With this kind of setup though, alignment is key. Out of the box the HKS coils felt very mediocre, sloppy even, but after a proper alignment and ride height adjustment it was like night & day. My bet for OP is either the suspension components were not installed properly, or whoever did the alignment did a poor job. Definitely would get a second opinion on the alignment & suspension setup from a good racing/performance shop before blaming the wheel/tire combo. Hell, I had 18x9.5s on purely stock suspension for a couple days before my coilovers came in and it didn't feel that bad (looked hilarious though)... |
The Following 2 Users Say Thank You to Shizuka For This Useful Post: | strat61caster (11-26-2019), why? (11-27-2019) |
11-26-2019, 07:18 PM | #33 |
ProCrastinationConsultant
who's making custom coilovers anymore?
11-26-2019, 07:34 PM | #34 |
Drives: '13 FRS - STX
Depends on your definition of custom, if it's pretty loose than pretty much everyone not an old German company will customize for you (Bilstein/Koni/KW+Ohlins, although all except KW are easily revalvable either first or second party)
Most are certainly just spring swaps on cartridges picked from a catalog. |
11-26-2019, 07:51 PM | #35 |
https://mcasuspension.com/products
From Street ultimates down, or up. Although all are available with different spring rates, it's the valving and dyno work that makes the big difference.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
The Following 2 Users Say Thank You to 86MLR For This Useful Post: | soundman98 (11-26-2019), wparsons (11-28-2019) |
11-27-2019, 08:10 PM | #36 | ||
Only happy when it rains.
Drives: series.blue
Of course for the street I see no reason to run anything other than 16's, but that limit's tire selection drastically because 17's have become standard for so long. I really wish hub swapping was a thing so I could switch to 4x100. Quote:
11-27-2019, 08:58 PM | #37 |
i didn't think custom solutions could be had for under $10k. nice to know now.
11-28-2019, 06:35 AM | #38 |
11-28-2019, 10:00 AM | #39 | |||
I also ran 16x7 Enkei RPF1s on our 2nd BRZ which were awesome (also I'm now selling them if anyone is interested). Quote:
Fully custom isn't always better...it depends on the quality of components used to build the shock and the expertise of the person designing and building everything. You can reshim a crap coilover for a custom valving profile, but if you're still using crap shock fluid and a crap piston and crap adjuster/shaft, it's only gonna be (maybe) slightly better crap. But a good custom shock can give you what you need especially at the higher end of the scale IF you know what you're asking or are working with someone who does. Happy Thanksgiving y'all. - Andrew |
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: |
11-28-2019, 10:24 AM | #40 | |
Noob
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
Better question may be...What am I really looking for the car to feel like, to know whether a wider would be beneficial or detrimental? Sorry new to track days. I have some Tarmec 2's sitting on my shelf waiting to go in this winter. I plan to keep running stock wheels with Hankook RS4 225 for now but after FI I was thinking 17x9. I liked what I have read on the Maxxis VR1 and was thinking probably in a 255 after the SC. (Built engine with 10.1 this winter) I'm going to lose a few horse by staying naturally aspirated this summer but I need to work on my line more than anything anyway. Sorry to hijack but I though the similar question could help OP. Sent from my Pixel 2 XL using Tapatalk
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599 -1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black |
11-28-2019, 12:35 PM | #41 | |
Drives: Crapcan
The RS4 is a good learner tire but I find Hankook's tire compound to have an abrupt breakaway. |
The Following User Says Thank You to NoHaveMSG For This Useful Post: | why? (12-02-2019) |
11-28-2019, 12:56 PM | #42 | |
Noob
Similar Threads | ||||
2013s less responsive than 2017s? | 370zBRZ | BRZ First-Gen (2012+) -- General Topics | 25 | 07-28-2018 05:24 PM |
Car feels a little less peppy | Riftur | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 04-15-2018 06:02 AM |
Which entry level turbo kit is the most responsive? | Keenercarguy | Forced Induction | 54 | 04-18-2017 03:40 AM |
Am I the only one that feels bothered by this (R.S 1.0) | 1GiantTurtle | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 12-11-2014 08:18 PM |
18's or 19's ... What looks and feels best on FR-S. | Jon1084 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 65 | 07-19-2013 06:42 PM |
