Forced Induction Turbo, Supercharger, Methanol, Nitrous |
12-16-2013, 08:15 PM | #141 | |
Drives: ~
12-16-2013, 09:55 PM | #142 | |
Drives: Subaru BRZ with Delicious Innovate
there was one other variable.. the second tuner was @delicious on the 75mm pulley.. so that might be a factor.. bill also told me not to run the 70 without an intercooler on 93 because it might be hard to make consistent power.. and I track it.. ill get the intercooler as soon as that white shit is done falling from the sky and I can actually do something with the extra power. Take a look at my build thread in my signature.. there are graphs there.. it is a V-Dyno graph but I did some testing to see if it could be trusted.. also in the build thread.. and surprisingly the runs were very repeatable.. the numbers might not be perfect but you can definitely see changes which is all I am concerned with.. Ill get a chassis dyno once I am done screwing around to see how it compares to others...
12-18-2013, 12:24 AM | #143 |
Drives: ~
that's wierd. I read that they tried a 66mm pulley but it only gained like 1 psi more than the 70mm. So the boost provided by 75mm pulley is pretty much the limit for this supercharger? Or does it have to do with the superior tuning at Delicious?
12-18-2013, 07:48 AM | #144 | |
The combination of getting out of the efficiency range of the supercharger and the belt slipping with the 66mm pulley caused the minimal gains.. innovate will be selling a 69mm pulley. Why 69mm? look hard enough on the google and you might find something similar... because it is an off the shelf part.. maybe not the bolt pattern or offset but the less they have to machine the less it will cost and they can pass the savings on to us .. how much will 1 mm do?? probably as much as losing 10 lbs.. i dunno.. but if numbers are what you are going for why not.. ill stick with my 70..
Tags |
visconsneaky? |
Similar Threads | ||||
Innovate Supercharger!!! | Titanmotorsports | Forced Induction | 62 | 08-24-2014 10:25 PM |
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 24 | 09-20-2013 03:04 PM |
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-13-2013 01:34 AM |
FA20CLUB 60 Trim Turbo 16 PSI Results Are In | FA20Club.com | Forced Induction | 148 | 07-22-2013 08:00 PM |
Innovate Results! | Pure Automotive | Mid-Atlantic | 22 | 07-17-2013 10:09 AM |
