07-08-2019, 02:08 PM | #3137 |
Drives: 2013 BRZ Limited 6MT
With all this talk about failing bypass valves I decided to check mine. What I found was... it was never connected . It never has been connected since I installed it ~10 months and 2k miles ago. I bought it 2nd hand and the hose was not with the kit. It's also not called out anywhere in the manual. When I started the car, I heard the vacuum leak coming from the vacuum line on the manifold. After scrubbing the install instructions, I decided it must have been from the previous owner for a boost gauge and I plugged it.
I have since installed the hose, and confirmed the bypass valve was functioning. Driving the car however I notice little to no difference. I re-captured my data logs and sent them back to Delicious to do a sanity check; I will follow up with any significant findings. My thought was for those who have been having recurring bypass valve issues, as a work-around, just cap the port. I'm not sure if this is detrimental to anything long term, I'm just basing this off the fact I drove a year w/o it. |
07-08-2019, 07:56 PM | #3138 |
Drives: 14 BSP Edelbrock BRZ
You have been driving around with the supercharger pressurizing the intake even when you are under light throttle. What kind of gas mileage do you get? I would expect it to be pretty terrible in that state.
07-09-2019, 01:06 AM | #3139 |
Drives: Toyota Celica
Hi, thanks for this thread. First post in years as I am finally getting back into my 2013 BRZ.
I have just ordered the Edelbrock e-force. My mechanic has installed one on a Miata and said it took him a few days, and therefore wanted to charge $3000. I explained to him everyone and there mother says it takes 7-8 hours. I trust him that he will get it done in that time, that it was more difficult on the Miata. (I hope) I live in Monterey so options are limited here. Also, I don't know shit about tunes and what's CA carb legal. I want a nice sounding exhaust to pair with this SC. I was thinking the Magflow. Will this effect the tune that is provided with this SC? All I ask, more speed, nice sound, and I"m done : ) Thanks again, and sorry for the rookie questions. |
07-09-2019, 04:18 AM | #3140 |
Drives: Manual 86 GTS
Toyota 86 GTS
This is a Dyno Dynamics tune done with my new E-force. I know this particular dyno reads lower than Dynojet etc. Does it compare on par with other tunes here? I wouldn't have a clue how it looks as I have no experience. I know I got about a 60kw at wheels extra and about 100nm of torque extra. How does the graph look to you? The first two days I got the car back it felt like a bullet. Now after a week I can still feel the extra power but it doesn't feel as quick low down below 4k rpm as it first did. Maybe I'm just used to it by now I just thought it should be more of a punch in your gut. I still love it and the car runs exceptionally well. I'm sure I'm just hungry for more power perhaps Other mods done: Tomei UEL headers Perrin 2.5 catback Exedy Button Clutch 1050 Injectors DW fuel pump NGK Sparkplugs 18 by 9.5 in wheels running 265/35 Michelin PSS MCA Coilovers |
07-09-2019, 04:34 AM | #3141 | |
My thoughts: Get rid of the UEL header and get a good 4:2:1 header (or decat the OEM header) Get a 2.5" overpipe (my Ultrex cost $100) and decat the front pipe
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
07-09-2019, 04:47 AM | #3142 | |
I really love the boxer rumble hence the UEL headers. I know I might have sacrificed a few HP for that. The car is ferociously loud with the current exhaust. I'm sure decatting it and/or adding front/overpipes would just attract the cops. Really don't want to get pulled over and slapped with a defect notice. |
07-09-2019, 08:26 AM | #3143 | |
My UEL header lasted a week before I put the OEM decated header back on, I didn't see the point of having the extra noise the UEL header made for no additional performance over a decated OEM header. A EL header with a full decat exhaust will be similar to your current set up Try and find a used OEM header and front pipe, punch out the cats, and throw a 2.5" overpipe into the mix and see the difference in sound, if you like the sound, tune it up for some decent gains without the extra noise. My current full decat system sits at around 90 db at 7k rpm IIRC, it was over 100 db with the UEL header, and cold start was obnoxiously loud. Hell, even just a OEM header and front pipe decated, for the cost of some gaskets you can test for sound levels, the additional power will come with a tickle on the tune. Opinions may vary
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits Last edited by 86MLR; 07-09-2019 at 08:50 AM. |
07-09-2019, 09:57 AM | #3144 |
Yes, gas mileage has been pretty abysmal. I see high teens around town, and low 20s on the highway (not trying to conserve by any means however.)
07-09-2019, 10:43 AM | #3145 | |
I usually average 26mpg over a tank of gas, with mixed city and highway driving and the occasional heavy pull just because it's fun. If I take a trip and only do highway I've seen as high as 33mpg for the tank driving 70-75. |
The Following User Says Thank You to toast For This Useful Post: | Chris3007 (07-09-2019) |
07-09-2019, 04:18 PM | #3146 | |
It's about a 9.5 hour install done right, professionally. It can be done faster, if rushed. |
07-09-2019, 06:27 PM | #3147 | |
I plan to add a Magna-flow cat back exhaust with it. I"m hoping that's a good set up, can't find any posts with that setup. |
07-09-2019, 06:45 PM | #3148 | |
07-09-2019, 08:07 PM | #3149 |
Drives: Asphalt FR-S
This kit isn't that difficult to install.
I've done it with a friend over a single day. Simply read all the instructions before, make sure you have everything you need (extra hose clamps, smaller hose for the bypass valve as the stock one is a bit too big, extra gaskets for the MAF, throttle body and intake plenum, coolant for the car radiator and supercharger and some brake fluid for the clutch bleeding). The rest of the hardware is included and you just follow step by step. If I managed to do it in a day with a friend (neither of us is a mechanic, but we have some base knowledge and followed every instructions thoroughly), a mechanic should have no problems doing it in a day, barring any big issue. The hardest part was the fuel lines disconnect being a pain. Sent from my Pixel 2 using Tapatalk |
The Following User Says Thank You to Mad1723 For This Useful Post: | Chris3007 (07-10-2019) |
07-09-2019, 08:35 PM | #3150 |
Thank you
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
