Forced Induction Turbo, Supercharger, Methanol, Nitrous |
05-26-2019, 06:42 PM | #15 |
Drives: brz 2017 hksv2
how can you say jackson racing is "better choice" than innocate when they are totally different sc type
05-26-2019, 07:14 PM | #16 |
Drives: 2017 toyota 86
Not saying JRSC is bad by any means. But it definitely is over hyped by the fan boys and used to be heavily pushed by some vendors on here. I was on the verge of getting it but read way too many people having there blowers fail on them and taking months to get a replacement. Scared me off. Seems like most failures with sprintex where minor resolvable issues, install error or bent rods from too much torque. The unit itself as long as you didn’t starve it of oil seemed pretty reliable. For wanting 300whp or less and not wanting to go turbo id say it’s a solid option if you can E85 or are willing to WMI (which to be fare increases cost even more) and intercooler is a must.
05-26-2019, 10:41 PM | #17 |
If this is a purely street driven car, the sprintex 210 kit is nice. I got mine used with 30000 on the on the blower from a member here and works great. Keep looking and you can fine deals. Got mine for 2800$ and this was IC cooled. Do you need to be carb legal? If not why not go turbo?
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
05-27-2019, 12:22 AM | #18 | |
Drives: 2013
05-27-2019, 12:28 AM | #19 | |
Drives: 2013
05-27-2019, 12:32 AM | #20 | |
Drives: 2013
05-27-2019, 12:57 AM | #21 |
Dismember
Drives: 2013 Red Scion FR-S
No centrifugal is low to mid range. Harrop or Edelbrock then. Not sure why you want low to mid when high is what makes the car so fun.
05-27-2019, 01:19 AM | #22 | |
HKS/JRSC will have the lowest power band with least low/mid range torque. Harrop and edelbrock are in between closer to sprintex though. This is all in comparison with all kits making 300whp peak or less. If wanting more then 300whp which becomes increasingly less reliable especially for DD then sprintex can’t hang as it maxes out at 300whp. But at or below 300whp it’s a good option for a fun spirited DD. JRSC/HKS aren’t bad but you need to rev it out to get power good for tracking when constantly at high rpm. Plus side with lower low/mid torque you may be able to run a little higher peak whp more safe and reliably but still need to really rev it out. See attached dynos 1st sprintex. Second is JRSC Last edited by 86TOYO2k17; 05-27-2019 at 01:30 AM. |
05-27-2019, 12:33 PM | #23 |
Drives: 2013
i see the torque on the spintex is crazy right off idle lol, but they no longer sale the non intercooler version and the intercooled one is more expensive then the hks and jackson racing. the hks/JR kits dont have as much torque down low this is true but its still better then stock. so really i think im ok with that. if i want the power out i can decide myself how high to take the rpms, and for a daily driver that choice comes along alot. i think im going to go HKS with their v3 system, weirdly enough i like that it uses the stock air box. p.s. other then a tune, can i just run this kit with no other mods? etc MAP sensor?
05-27-2019, 01:07 PM | #24 | |
BTW no kit will be truly plug in play. Your adding power and tq to an engine that was not design to handle the extra power. Expect the worse and hope for the best. But with any kit the 2 most important things are: Tune Proper install Sent from my ONEPLUS A5010 using Tapatalk
05-27-2019, 02:15 PM | #25 |
And oil / coolant temps.
05-27-2019, 04:33 PM | #26 | |
Regardless, both kits are basically bolt ons, just need a tune. Neither come with a map sensor but it’s not required they can be tuned just fine with the MAF. An oil cooler is highly recommended. I already had the OEM one so just got a mishimoto radiator and temps are fine. If I didn’t already have oem oil cooler I’d probably get a real oil cooler. You’ll also want some good tires, probably some 8.5-9” wide rims with a 245 tire to be able to actually put the power down or you’ll probably be spinning stock tires to the top of 2nd. |
05-27-2019, 05:49 PM | #27 | |
Drives: 2013
05-27-2019, 06:22 PM | #28 |
Dismember
HKS is centrifugal. Doesn't match what you say you want.
Similar Threads | ||||
Question about FI / Innovate | azynneo | Forced Induction | 47 | 06-15-2015 08:09 PM |
Question; What Strut-tower bars and cross-braces fit with Innovate Stage 2 I/C SC? | Michael Blue | Forced Induction | 5 | 05-26-2014 01:30 AM |
Question: vortech+innovate possible? | cjsporl1996 | Forced Induction | 32 | 03-28-2014 07:47 PM |
Innovate Motorsports Supercharger Question | jjkerr626 | Forced Induction | 3 | 01-04-2014 08:12 PM |
Innovate OT-2 | jamesm | Engine, Exhaust, Bolt-Ons | 0 | 12-03-2013 10:38 AM |
