Old 06-09-2016, 04:30 PM   #141
bradsm87
Drives: It has 4 wheels
Originally Posted by Canehda View Post
If you look hard enough there are a bunch of porsche boxter S engines starting to come on the used market as a lot of the early cars had catastrophic electrical problems that made the rest of the car useless... I would get a porsche H6 over the subaru in a heartbeat as the porsche engine is lighter... engine swaps will be a huge pain regardless so why not have a porsche engine to show for it!
Would be very cool but that option has the following issues:
Price
Availability
Gearbox compatability
Probably Width
Also I'm loving the CAN Converter and the guy can currently program it for GM or Subaru engines.
bradsm87 is offline   Reply With Quote
Old 06-09-2016, 04:48 PM   #142
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
Originally Posted by jsimon7777 View Post
I have not heard of Caymans totaled over electrical issues. Got a link?
i didn't say cayman...
Canehda is offline   Reply With Quote
Old 06-09-2016, 04:53 PM   #143
Canehda
Canehda's Avatar
Originally Posted by OkieSnuffBox View Post
Are these the same engines with IMS problem?
IMS issues are a problem that can be fixed fairly easily with proper parts (LN engineering kit) when the engine is out of the vehicle, the reason it turns off so many potential porsche owners is that you have to pull the engine which is a huge cost, if its already out of the vehicle for the swap you might as well change it
The Following User Says Thank You to Canehda For This Useful Post:
Chad_W (06-10-2016)
Old 06-09-2016, 06:17 PM   #144
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Or Boxsters. Same car.
Old 06-10-2016, 10:36 AM   #145
Chad_W
Drives: 2013 BRZ DGM
This also makes all of the IMS failed Porsches good potential swap material...the cost of engine replacement can easily excede the value of the vehicle. There are plenty of LS1 options of course, but imagine finding a clean bodied boxster with a failed M96 engine and swapping in a ej255/ej257 ...you'd have something pretty comparable to brand new Boxster S for 1/4 the cost and 20 times the effort....
Chad_W is offline   Reply With Quote
Old 06-12-2016, 03:57 PM   #146
Canehda
Canehda's Avatar
they are not. The 986 which is the vehicle that I am saying would be a good swap candidate existed for 8 years before the 987 (model with cayman) came out.
Old 06-12-2016, 03:58 PM   #147
Canehda
Canehda's Avatar
exactly... they are fun cars
personally other than doing it for the lols i would prefer just getting a 987 cayman, after driving a few it is making a great case for replacing my brz if the 2017 BRZ is unreasonably expensive with performance package
Old 08-04-2017, 10:18 PM   #148
mrspindlelegs
Drives: 2014 Scion FR-S Monogram Series
Originally Posted by BRZHarley View Post
The Contour 2.5 SVT Cosworth V6..... Really sweet motor in its day!
That would be a very poor choice. That 2.5L Duratec V6 produces 195 - 200 Hp and 165 - 169 ft/lbs depending on which model year you pull the motor from. That's going to be an awful lot of work to swap it in with negligible gains over the FA20. The 2.5L also had a serious problem with spinning rod bearings because Ford cheapened the powdered scintered rods when they started selling the SVT. The intake manifold would get caked-up with carbon / oil residue due to that dual plane manifold and a poorly designed PCV system.
The 3.0L Duratec would be a better choice (better intake manifold, cooling and oiling passages and PCV system) but it still has lousy connecting rods so you will have to plunk money into K-1 rods, rebalancing and all the gaskets and torque-to-yield bolts if you want it to last before figuring out how to fit it in the car. I pretty sure you will need a custom oil pick-up and oil pan because neither the 2.5L or 3.0L Duratec was ever put in a rear drive-only car.
If you want the powerband behavior of the SVT, you will have to find a good set of cams and chains from the 2.5L to swap-in as the 3.0L factory cams are not as rev happy. Fortunately, those are easy to find used but not necessarily with low mileage on them.
Aftermarket support for the Duratec V6s seems to be pretty poor too.
There is a lot of potential in these motors but there are much better options for the OPs project.
2014 FR-S Monogram Series, Raven Black, MT
Mods -ARP wheel studs, Bilstein B6, Michelin Pilot Sport 4S, Diode Dynamics "Tail-as-Turn" kit
Future Planned Mods - Ace 350 Header & Tune. Oil cooler.
Fuel Economy - Best was 37.2 mpg, Worst was 28.2 mpg
mrspindlelegs is offline   Reply With Quote
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 06:32 PM
Looking for a second car, what would you choose? cdo221 Other Vehicles & General Automotive Discussions 31 04-25-2014 11:50 PM
If you had to choose.... FRyeS Off-Topic Lounge [WARNING: NO POLITICS] 51 07-31-2013 08:17 AM
Help me [maybe?] choose a new car: tree fingers Other Vehicles & General Automotive Discussions 24 04-16-2013 05:27 PM
Why did you choose the BRZ? pinoyplaya BRZ First-Gen (2012+) -- General Topics 43 10-10-2012 03:34 PM
