08-13-2013, 10:35 PM | #1681 | |
Drives: 5th Gen Toyota 4Runner
For your second question I have no answer.
08-13-2013, 11:22 PM | #1682 | |
Drives: S
Also, for my second question, I should mention that I got XXRs which allow for 5x100 or 5x114, which is why I brought up the adapter option. |
08-14-2013, 07:06 AM | #1683 |
Drives: Toyota 86
Hello Guys
Im a complete novice when it comes to wheel fitments so im looking for some feedback on the set up i want to go with. Ive ordered a set of 18" 57xtreme gramlights sp spec Front: 8.5+40 Rear: 9.5+40 They should arrive in a months time What kind of size tires should i be looking at if i dont want that stretched look?. Also my car is still running with stock suspension for the time being, possibly lowering it -1" with springs at a later date. Would i have any rubbing issues? Sorry if anybody has answered this question before, im still trying to sift through the 77pages of this thread |
08-14-2013, 12:08 PM | #1684 |
Drives: DGM BRZ Limited
Hey guys,
I'm looking at a similar wheels as 8ball above me, but with a square set-up. I'm open to either a 8.5 or 9.5 width with the 40 offset. I would prefer 9.5, but if it would rub, I'm happy with 8.5, assuming that doesn't rub. I'm also open to what width tires I should look for. I don't want to have any undertiring, but I'm ok with some overtiring. I like the look of having the tire about the same as the wheel, but if I have to err in either direction, I'd rather have more tread. I was thinking 245/35 for the 9.5s and 225/40 for the 8.5s. I'm worried about potential rubbing in the front. If I use spacers to flush the wheels, will I still have to worry about rubbing? For now I'm stock height, but I'm probably going to get some Fortune Auto coilovers and drop the car about 1". Thanks! |
08-14-2013, 02:20 PM | #1685 | |
Drives: FR-S Firestorm 6MT
235/40R18 is a bit tall and since these go on the rears, they will affect gearing a bit too. Plus with a true square setup, tire wear will be better because you can rotate properly from front to back. I'd go for a 245/35R18 tire as it is a perfect size for a 8.5" wheel (on my 9's they look slightly stretched), plus also an exact match for the OEM diameter. You could also go with a 225/40R18 if you don't want to go this wide. (and a 235/35R18 is a pretty hard find btw) You shouldn't need to run adapters or spacers in the rear, this combo will put you flush already. See pic below (18x9+35 on 245/35R18 Continentals) |
The Following User Says Thank You to Slick For This Useful Post: | ill86 (08-15-2013) |
08-15-2013, 01:24 AM | #1686 |
Drives: S
Thanks! Seems like most people opt for the 225/40 tire on this setup; any benefits of one over the other (225/40 vs 245/35)? I do like the idea of a shorter side wall.
Also, I dont want any poke in the front, which means if Im flush in the front, I'll be sunken in a tad bit in the rear with a square setup, right? How low is your drop? My Sportlines ship tomorrow! Quote:
08-15-2013, 01:33 AM | #1687 |
Drives: Toyota GTS 86 Pearl White
helpppp
Does anyone know what size the rims and tyres are on this sexy beast ?
original link : http://forums.nasioc.com/forums/show....php?t=2370021 Thanks guys! |
08-15-2013, 02:14 AM | #1688 |
Only going down about an inch. Got the RCE Tarmac 0s so that drop should be perfect.
08-15-2013, 05:06 AM | #1689 |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
does anyone know if 17x8 25 offset with 225/55/17 will fit and not rub? i want some thickness to the side wall
08-15-2013, 08:31 AM | #1690 | |
I think you'll be flush in the rear and a smidge of poke in the front. The camber from the Sportlines will help pull the top of the tires in a bit, so it should look very flush in the front. Have a look before your alignment to see if you like it, it still pokes a bit, you can add crash bolts (for extra camber) in the front for a bit more. |
08-15-2013, 08:44 AM | #1691 | |
Ultimately, you need to maintain as slose as possible to the OEM tire diameter which is 24.7" (or 844 revs per mile). |
08-15-2013, 09:05 AM | #1692 | |
Work Emotion CR Ultimate "Kiwami" 18x8.5 +47 / 18x9.5 +38 No idea on tires, it appears it is the Work demo car from Japan, so perhaps try searching that. Wheel Directory in case some of you don't know it exists: http://www.ft86club.com/forums/showthread.php?t=7535 And here is a thread on these particular wheels: http://www.ft86club.com/forums/showt...Emotion+Kiwami |
08-15-2013, 10:44 AM | #1693 | |
Drives: S
Thanks.
...but wouldnt the sidewall be shorter on 245/35 than 225/40? I actually think I'll go with the 245s over the 225s; I think the tires i chose (ventus v12) will be a tiny bit wide, but i think id rather that than stretch 'em. Quote:
08-15-2013, 11:00 AM | #1694 | |
Btw, I'm on a 1" drop using Eibach ProKit and extra camber via Subaru crash bolts on front ($5 each). My camber is -2.2F, -2.0R. |
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
