Old 07-11-2019, 12:59 PM   #85
Jdmjunkie
Drives: Scion FR-S 10 Series
Originally Posted by Boccaccio View Post
Installing the spacer in the coming days. To the ones who already installed it, did you need to lengthen the cruise control wiring/cables
No issues with the wires other than there being a little less slack to work with, but is definently doable without extending the wires.
Jdmjunkie is offline   Reply With Quote
Old 07-11-2019, 03:57 PM   #86
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Originally Posted by churchx View Post
..but rising total offset to 7cm makes me cautious a bit to just pull a trigger on purchase prior hearing similar setup experiences.
5cm. Not 7cm.
It is exactly what you would expect; the steering wheel is 5cm closer to you, the control stalks are 5cm further from wheel.
949 Racing is offline   Reply With Quote
Old 07-11-2019, 10:05 PM   #87
churchx
churchx's Avatar
Drives: 2014 GT86
949 Racing: 5cm from spacer, +2cm from J-Luth wheel's itself offset.
Old 07-11-2019, 10:22 PM   #88
949 Racing
949 Racing's Avatar
Ah. You are correct. Sorry!
Old 07-12-2019, 02:21 AM   #89
Boccaccio
CAD monkey
Boccaccio's Avatar
Drives: '15 GT86 Giallo - Supercharged
Thank you, JDMJunkie
@churchx, sure thing Will let you know and send some pictures along the way. Regarding operating the steering column stalk, I'll try the Vertex Turn-Signal extensions -->
https://www.vertex-usa.com/media/cat...img_5725_2.jpg
Maybe down the road, if time will allow it, I'll design and manufacture my own version of the extensions.
Cheers
Boccaccio is offline   Reply With Quote
Old 07-12-2019, 02:35 AM   #90
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Or you could be like 90% of drivers and just not signal.
Old 07-12-2019, 02:42 AM   #91
churchx
churchx's Avatar
Drives: 2014 GT86
Boccacio: oh. Thanks for linking those. They seem to look well, adjustable. Clutch Dog had mentioned another extender, but it looked more bulky. I guess, extenders should fix what i am cautious if offsetting too much, to be able to operate stalks without taking hands of wheel. Stalks of course are usually non-used in sport (unless turn signals in local passing rules as on some tracks), mostly for daily driving (but which is of much longer mileage/time spent at), but if reviewers praise layout/ergonomics "enveloping driver", with everything "in right places", if some change it according specific use (eg. longer gearswitch lever for shorter travel between wheel & lever), if even this spacer is product to enhance ergonomics .. i simply didn't want that to be at expense of worsening it somewhere else. I'm used to think that it is bad driver's habit to switch them not with fingertips but with whole hand off wheel, so wouldn't want to be forced to do that myself due mod
EDIT
jsimon7777: twins are not bmw for that to be so . Also i guess it's specific country driving culture, here in LV it's 10% of drivers not turn-signaling. Also in addition to turn signals there is also switching far & low beams to not blind oncoming traffic in timely fashion that needs to be done many times during long cruise at night. And even in HPDE, as i mentioned above, there might be track-specific passing rules (to signal that you have noticed one overtaking and will keep on one side). Somewhere nothing, somewhere hand wave in opened window, somewhere - turn signal blip to opposite side.
Old 07-12-2019, 02:59 AM   #92
Boccaccio
CAD monkey
Boccaccio's Avatar
@jsimon7777, like church already mentioned, I tend to not forget about the indicators, so they don't feel lonely and untouched like in a bmw :P
@churchx, my first experience with this spacer was in a friend's 996 C2. Even with my big hands, I struggled with the indicators, so for me, the extensions are a must.
If they happen to interfere with my steering wheel interaction during track driving, I'll just take them off
Old 07-12-2019, 03:01 AM   #93
EAGLE5
Dismember
EAGLE5's Avatar
It all seems like a good reason to buy a 3D printer. An extension just isn't a difficult problem to solve. Making it out of metal is overkill. There's always rubber bands, glue, and popsicle sticks.
Old 07-12-2019, 11:35 AM   #94
extrashaky
Drives: 2014 BRZ Limited
To the ones who already installed it, did you need to lengthen the cruise control wiring/cables?
I'm combining the spacer with the Revolution/J.Luth steering wheel.
[MENTION=137794]I too have J.Luth wheel and not too keen on putting stock wheel back, but rising total offset to 7cm makes me cautious a bit to just pull a trigger on purchase prior hearing similar setup experiences.
I still haven't had time to do mine (hopefully tomorrow), but I also have the same wheel branded as ATC. If I remember correctly, the aluminum center bracket that holds the airbag is the exact same in both the stock and extended wheels. So if their claim that you don't have to extend the wiring for the stock wheel holds, it should be the same for the J Luth/ATC/Keys wheel.
Old 07-12-2019, 11:41 AM   #95
extrashaky
The "Vertex" extension is $30. From the pictures at least, I don't see any difference between that extension and these $8 and $11 extensions from Amazon. It looks like they bought them from the same Chinese supplier and just etched the "Vertex" name into the handle. A ~$20 difference in price isn't that big a deal, but why pay it if the product is exactly the same thing?
B Blesiya Practical Wheel Turn Signal Lever Position Up Kit Turn Rod Extension - Red
Ruien Aluminium Car Styling Adjustment Steering Wheel Turn Rod Extension Turn Signal Lever Position Up Kit
There are a whole bunch of these on Amazon ranging from $8 to $18. There's even one with the exact same design, but reproduced in plastic instead of aluminum.
The Following User Says Thank You to extrashaky For This Useful Post:
churchx (07-14-2019)
Old 07-14-2019, 02:59 AM   #96
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Shameless Plug: I made a DIY on how to install the spacer
https://www.ft86club.com/forums/showthread.php?t=135771
Clutch Dog is offline   Reply With Quote
The Following 7 Users Say Thank You to Clutch Dog For This Useful Post:
Capt Spaulding (07-16-2019), churchx (07-14-2019), EAGLE5 (07-14-2019), extrashaky (07-14-2019), sato (11-22-2019), turbofan (08-28-2019), Vracer111 (07-15-2019)
Old 07-22-2019, 10:54 AM   #97
EAGLE5
Dismember
EAGLE5's Avatar
Website said preorder for July 19th shipping. Any update?
Old 07-22-2019, 01:55 PM   #98
949 Racing
949 Racing's Avatar
Ah, few days late. Tracking shows the 23rd. We allowed an extra 10 days as a cushion.. still wasn't enough. Sorry!
949, spacer, steering
MY2018 GT86 OEM Steering Wheel Spacer AndMsc Cosmetic Modification (Interior/Exterior/Lighting) 7 06-15-2020 08:51 AM
Do spacer's/adapter's cause heavy steering? lupindub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-30-2016 09:36 PM
TE37SL Red $2799 - Rays Volk Racing & GramLights, Advan RSII, Eibach Spacer eauto Wheels and Tires 316 10-15-2014 01:41 PM
Steering Wheel Adjustment or Spacer Goya Cosmetic Modification (Interior/Exterior/Lighting) 5 09-29-2014 03:54 AM
RAYS RACING DURA NUTS EXTENDED 50MM RED WITH LOCK 20 PCS 12X1.25MM ???? 20valvewynn83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-07-2013 04:33 PM
