Old 06-29-2015, 10:10 AM   #141
Koa
Sweeper
Koa's Avatar
Originally Posted by nunonuna View Post
Do you still have this file available???
The link you provided seems not working.
Thanks for the heads up- I'll update with a summer link! That tune was for winter blend
The Following User Says Thank You to Koa For This Useful Post:
nunonuna (06-29-2015)
Old 07-06-2015, 06:44 PM   #142
86_PWR
Drives: 2015 FRS RS 1.0
I have the borla uel and trd airbox. I am running the ots stage 2 93 map. I am considering buying th gs intake if there is a map for it. Is there a map available for gs with uel on 93?
86_PWR is offline   Reply With Quote
Old 07-15-2015, 10:01 PM   #143
86_PWR
Hello....anyone make a map for 93 octane?
Old 07-15-2015, 11:26 PM   #144
steve99
Drives: FT86
the maf scalling difference between stock intake and grimmspeed are very small, you will be fine with grimmspeed intake and ots tune.
you can always make it better with custom scaling though.
Old 07-16-2015, 10:42 PM   #145
86_PWR
I guess that was my question; is there a map with custom scaling for the GS with uel on 93?
Old 07-17-2015, 06:43 AM   #146
steve99
Drives: FT86
if you have an oft email the openflash guys and i think they will send you a grimspeed intake map
else just do your own maf scaling
Old 07-18-2015, 01:19 AM   #147
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
The only difference between Stage 1 OTS and Stage 1 Grimmspeed is the MAF scaling. There are no other fueling changes. So if you get the Grimmspeed file you can just copy its MAF scaling into whatever ROM you want.
If you want, shoot me a PM. Going to be on a plane most of the day headed home but I can send you the file this evening.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 07-18-2015, 09:18 AM   #148
nunonuna
nunonuna's Avatar
I guess he is looking for stg 2 tune for grimmspeed since he has UEL header.
Someone correct me if I'm wrong, but it seems that MAF scaling is best option for those of who runs stage 2 ots.
nunonuna is offline   Reply With Quote
Old 07-18-2015, 09:47 AM   #149
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I re-scaled my MAF for the GS intake on my stg 2 tune. At first I tried copying the MAF from the stg 1 tune but it had LTFT off by 6%-7%.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 07-18-2015, 10:40 AM   #150
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
anybody has a scaled stage 2 uel file working with a grimmspeed intake?
malubawla is offline   Reply With Quote
Old 07-18-2015, 06:01 PM   #151
phobos512
phobos512's Avatar
Good lord people the only difference between a standard tune file (at any stage) and a Grimmspeed tune file is the MAF scaling. It's not hard to put that data in yourself once you have Shiv's Grimmspeed stage 1 tune - you just copy the MAF scaling table using ROM Raider. Again, this works with any stage tune file. There are no fueling changes, no timing changes, no code changes - doesn't matter EL UEL 91/93/E85 - changing intake only means changing MAF scaling, which is what I would provide if asked as I previously stated.
Old 07-19-2015, 03:22 AM   #152
nunonuna
nunonuna's Avatar
I would rather listen to below two reputable people's comment than your comment.
Maf scaling is not the only difference between stg 1 and stg 2 tune. As far as I understood, it is not ideal to just to copy MAF scaling from stg1 to stg2.
Originally Posted by Shiv@Openflash View Post
That is correct. MAF scaling for the Stage 1 and Stage 2 maps are different. So copying over the MAF scaling for Grimmspeed Stage 1 to an OTS Stage 2 will probably not get you want you want
WARNING: This is only for stage1 oft maps. Stage 2 maps both petrol and E85 have offset maf scaling and different PRIMARY OL FUEL TABLES. You need to do a bit more work to get the grimspeed intake working correctly on stage 2 maps
Old 07-19-2015, 08:44 AM   #153
phobos512
phobos512's Avatar
OFT Tune for GrimmSpeed Intake
Maf scaling is not the only difference between stg 1 and stg 2 tune. As Steve99 stated, the primary ol fuel table is also different. As far as I understood, it is not ideal to just to copy MAF scaling from stg1 to stg2.
You seem to have a problem understanding English. The only difference between a Stage X tune and a Stage X tune PLUS GRIMMSPEED - IS THE MAF TABLE.
I'm not talking about differences between a Stage X tune and a Stage Y tune!!!!!!! I know there can be SIGNIFICANT differences between Stage X and Stage Y.
BY WAY OF EXAMPLE...Start with a Stage 2 UEL 93 tune (i.e. Publicly available 2.067 tune from OFT site). Copy over the Grimmspeed MAF table from the tune Shiv made (this is a stage 1 tune but YOU ONLY COPY THE MAF TABLE GET IT). You now have a Stage 2 UEL + Grimmspeed 93 tune. It's that simple!
I swear with some people it's like talking to a wall...
Old 07-19-2015, 09:10 AM   #154
phobos512
phobos512's Avatar
Believe me, don't believe me, whatever.
Here's the tunefile that Shiv created for 93 Octane B00C Stage 1 with Grimmspeed. Again, I did not create the file linked below, it was provided to me upon my asking.
https://infotomb.com/bygzn
You can take this and extract the MAF table and use it in whatever tune you want, or you can keep being obstinate and believe that there's something else that has to happen to make this useful. Your call. I'll tell you though that I also am using the MAF table in this file in the latest tune Shiv helped me out with, which was to create a Stage 2 93 EL Tune specific to the PTuning header - in other words, many peoples' holy grail of tuning right now. I'd be happy to post that one up also if I was asked. Just like I would have done with this one.
DIY - GrimmSpeed Intake Installation Guide GrimmSpeed DIY (Do-It-Yourself) Guides 60 09-08-2017 10:12 AM
** GrimmSpeed BRZ/FR-S Air Intake - GROUP BUY ** GrimmSpeed Engine, Exhaust, Bolt-Ons 1902 08-29-2017 07:47 PM
GrimmSpeed Intake Before and After OFT Tune + Review F1fletch Engine, Exhaust, Transmission 76 06-30-2016 02:40 PM
For Sale: GrimmSpeed Intake *newish* xDanger_208x Engine, Exhaust, Bolt-Ons 13 11-30-2014 10:16 AM
WTB GrimmSpeed intake VakaGT Want-To-Buy Requests 0 11-18-2014 12:19 PM
