09-02-2015, 07:38 PM | #547 |
Drives: 2017 86
no rings and no problems here. just star pattern the lugs like you're supposed to and you'll be fine.
09-02-2015, 10:50 PM | #548 |
Drives:
Hub rings are by no means necessary.
They are convenient for the person who swaps your wheels. They do not carry any load once the lug nuts are torqued to spec. They support the wheel in place while you hand-place the lug nuts. -Nat |
09-12-2015, 09:37 AM | #550 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
The Following User Says Thank You to drewbot For This Useful Post: | Astroboy (09-12-2015) |
09-12-2015, 09:38 AM | #551 |
Drives: None
10-05-2015, 01:20 AM | #552 |
Drives: 2013 FRS
Is there a groupbuy for these in black? Can't find one.
10-06-2015, 08:03 AM | #553 |
Mr.Fujitsubo
Drives: 2018 STI
What's the driving feel like with such huge tires and wide rims? I feel like this setup looks amazing, but i'm worried that it will make the car feel heavy in regards to handling. True or false?
I'm just comparing, cause i wanted these in the SBC but they only make them in larger sizes, while i wanted more like 17x7.5 cause they are light and i can use 215/45/17 tires.
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review |
10-06-2015, 09:58 AM | #554 |
Drives: FR-S and Mazda 3 Sky
Here is a nice post I saw a few days ago, this pretty much answers your question:
http://www.ft86club.com/forums/showp...74&postcount=8 Not sure I can categorically agree with all yet #1 for sure, I pretty much went up by +1L/100kms when I switched to wider setup. Partly because more fun, partly just physics. #2 can not confirm, with the nameless axle back, I dont notice any difference in noise #3 Slightly, feels that way. I think this can be influenced by your alignment too. #4 Have yet to see #5 Did not notice any difference in ride quality. I actually think because of the rubber, in some way its more pleasant. One thing not mentioned, in my opinion, steering is a little bit heavier, its noticeable at first, for about the first hour, then you get used to it. I'm talking here about lightweight 17x9 setup with 245 tire. Going 18 + wider tire the effects will probably be even more noticeable. One thing to keep in mind is your alignment to manage the poke, you will need at least 1.25-1.5 degrees of camber up front to make it look reasonable. Rear At 1-1.25 looks good too. Don't worry too much about making it worse, its a blast with better tires, plus it looks good too, I think 17x9+35 or so is a great balance for looks and performance. Go out to the meets, maybe someone can let you drive their car with similar setup to get a feel, you can hop back in your car and immediately compare. |
The Following User Says Thank You to df.dima For This Useful Post: | Mr.Impreza (10-06-2015) |
10-20-2015, 03:01 PM | #555 |
Enkei RPF1 17x9+35 and Michelin Pilot Super Sports 245/45/17
The Following 2 Users Say Thank You to mixxxx For This Useful Post: | akahenry (11-08-2017), Mr.Impreza (10-22-2015) |
10-21-2015, 09:51 AM | #556 |
Drives: 2014 BRZ Limited SWP
The Following 9 Users Say Thank You to Kuri For This Useful Post: | Aztec (10-21-2015), dattran86 (10-27-2016), DustinS (10-21-2015), kevaughan (04-11-2022), nisti (10-22-2015), racing_reject_001 (10-28-2015), SkAsphalt (12-04-2015), Surok (01-09-2018), trigger happy (11-14-2015) |
10-21-2015, 11:19 AM | #557 |
Fast enough
Drives: 2013 Subaru BRZ AT
Having trouble finding the answer to this. (Did search but was confused)
I'm planning on going with these 17x9 RPF1's with 235 tires. Will they clear on a 100% stock BRZ suspension setup? Do I need a different offset to make it work? |
10-21-2015, 12:07 PM | #558 | |
we have two guys on 245/40/17 on the same wheel and offset. |
10-21-2015, 12:42 PM | #559 | |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
I'm running 17x9 +35 But only -1.4 front And -1 back How does that setup handle?
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread |
The Following User Says Thank You to Aztec For This Useful Post: | BRZHarley (10-21-2015) |
10-22-2015, 09:35 AM | #560 | |
I did -2 for a good awhile. It's flush with the fender. |
Similar Threads | ||||
Wheel Directory: Enkei RPF1 17x9.0 +45 | LevinPhan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 264 | 04-11-2018 06:57 AM |
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** | LSD Motorsports | Groupbuys | 246 | 08-29-2013 01:35 PM |
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 | Touge Factory | Wheels and Tires | 2 | 02-05-2013 04:53 PM |
