12-17-2015, 07:46 PM | #533 |
Drives: 2013 FRS
12-18-2015, 11:46 AM | #534 |
Drives: 14 BSP Edelbrock BRZ
In every drive by wire car I've owned doing a reset makes it feel sluggish, especially the throttle response. It's like the first few mm of pedal travel do nothing. Give it a day or so of driving. Definitely all of your learned parameters have been reset, so if you have 93 octane you will lose any timing advance the ECU had.
12-18-2015, 01:26 PM | #535 | |
Drives: 2013 FRS
This make sense, I suppose one aspect is that it needs to recalibrate all the sensors so it knows the sensor limits correctly.... during that time I'm sure it's preprogrammed with some very conservative values to ensure the safe running of the engine. |
12-18-2015, 01:51 PM | #536 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
The Following User Says Thank You to BigFatFlip For This Useful Post: | CxG (12-18-2015) |
12-18-2015, 01:54 PM | #537 |
Drives: 2013 FRS
That's a really good point! I wonder how many people who have installed have faced this same thing and not understood and posted reviews based on that initial experience. I wonder how long I should drive it before dyno and other performance testing.
The Following User Says Thank You to 86fun For This Useful Post: | CxG (12-18-2015) |
12-18-2015, 10:36 PM | #538 |
Oh you won't be disappointed. It will still pull hard, it just won't be as responsive initially.
12-20-2015, 08:10 AM | #539 |
Drives: Toyota GT86 euro version
Ok just some question, i will order mine mid-january.
Everyone seems to say "it feel like stock with more power", when i'm looking at the torque curve, i just can see that it will absolutely not fell like the great canyon torque dip. There is some miles to do before go WOT after installing it ? Some miles to do before having the full power from the supercharger ? In straight line do you feel a real difference ? Ok it's not for what we bought the frs/gt86/brz but i can't understand how can you say that is not what you expect from this supercharger, maybe because you're living in the US and have lot of v8, v6 cars that pulls hard, and get you stucked in the seat ... but will it feel a little bit like that ?not that mutch of course... The gt86 is my daily and i'm driving an AT. I'm living in Strasbourg and i go often to germany driving on the autobahn with no limit speed ^^ I've seen a german tuner with a sprintex supercharger hit the 170mph !! I hope that i will feel what i see on the dyno results and that i will it some serious speed just for fun ^^ |
12-20-2015, 11:35 AM | #540 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Absolutely yes. You can't not feel a difference. With an AT (which i have as well), you can't rev it up and launch it from a full stop, so at the low end of the revs (under 3000) it'll still feel almost stock. But once you get past that, it's a huge difference. If I'm cruising along and just do roll-ons, there's a big difference in acceleration. If I keep in the power band, then even more so.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 Last edited by shiumai; 12-20-2015 at 02:23 PM. |
The Following User Says Thank You to shiumai For This Useful Post: | Paulo86 (12-21-2015) |
12-20-2015, 12:15 PM | #541 |
If you are asking about a "break-in" period similar to when the car is new, then no, there isn't one, you can go WOT right out of your driveway/shop. You will, on the other hand, have the same "dead pedal" as discussed earlier, but that is mainly due to the ECU flashing and having to relearn parameters and should go away after a few hundred miles of driving.
The Following User Says Thank You to BigFatFlip For This Useful Post: | Paulo86 (12-21-2015) |
12-20-2015, 02:31 PM | #542 |
Drives: UK GT86
Or you just do the pedal/throttle learning before you start the car for the 1st time and then you don't get any dead pedal at all
.: Stealth 86 :.
The Following 2 Users Say Thank You to Kodename47 For This Useful Post: | BigFatFlip (12-20-2015), Paulo86 (12-21-2015) |
12-20-2015, 06:30 PM | #543 |
Everything is answerd for me ! Thanks a lot guys !
12-21-2015, 11:21 AM | #544 |
12-21-2015, 11:49 AM | #545 |
Drives: 13 GBS BRZ
The Following 2 Users Say Thank You to Porcupint For This Useful Post: | KoreanJesus (12-04-2018), Paulo86 (12-21-2015) |
12-21-2015, 12:59 PM | #546 |
Glorious BRZ Master Race
Drives: Subaru Libird
Yes, the dead pedal fix works. I've had to disconnect my battery on two occasions... once when I installed a CAI and another when I installed a steering wheel. Noticed sluggish throttle response, did the procedure I saw others posted about, and instantly felt better throttle response. Still curious if this is published anywhere by the OEM. Here's more detailed discussion: http://www.ft86club.com/forums/showthread.php?t=39480
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
