Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-12-2015, 11:09 AM | #1 |
Drives: 2013 Raven FR-S
Sway Bar Creaking
I have a Whiteline 20mm front sway bar and every time I go over a bump it makes a creaking sound. I think it's probably the bushings that are making the noise. What's the best way to get rid of the sound? I was going to lube the bushings when I installed it, but it said on the instructions that Whiteline bushings didn't need to be lubed. Kind of confused as to why it sounds like this if that's the case.
11-13-2015, 02:07 PM | #2 |
Drives: 2013 Satin White Pearl BRZ
Probably lube it and get use to the noise the stiffer poly bushings make
Sent from my SAMSUNG-SM-G900A using Tapatalk |
11-13-2015, 08:20 PM | #4 |
Drives: 2019 Mazda Miata RF
Just use the right type of lube, so you don't affect the plastic. fwiw Hotchkis suggests a non-lithium based moly grease for their bushings.
11-16-2015, 12:40 PM | #5 |
Can anybody suggest a good lube to use on Whiteline bushings? Also, what's the story with teflon tape? I've heard that can get rid of squeaking as well.
11-16-2015, 01:28 PM | #6 | |
Frosty Carrot
Drives: The Atomic Carrot
Use a dedicated grease (Silicone, Lithium, or Molybdenum Di-Sulfide). Prothane and Energy suspension have their own formulations, which appear to be a silicone w/ PTFE particles suspended in it. I can't link to a non-vendor site... but there are many suppliers. Even your local auto parts store will have suitable lubes (typically labeled "synthetic brake caliper grease")
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
The Following User Says Thank You to Shankenstein For This Useful Post: | smg1138 (11-16-2015) |
Similar Threads | ||||
Popping, Crunching and Creaking Noise | MyEvilMonkeys | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 07-22-2020 12:50 PM |
Creaking during turning after coilovers? | Rifle | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-10-2015 12:51 PM |
Clutch clicking/creaking | Bg8780 | Issues | Warranty | Recalls / TSB | 4 | 03-24-2015 11:27 PM |
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. | FRSport.com | Brakes, Suspension, Chassis | 0 | 01-23-2015 12:38 PM |
Seats creaking | Wes | Issues | Warranty | Recalls / TSB | 28 | 06-15-2014 06:19 PM |
