04-06-2019, 05:13 PM | #54839 | |
humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | Sapphireho (04-06-2019), soundman98 (04-06-2019) |
04-06-2019, 06:05 PM | #54840 | |
Drives: 2017 BRZ
I might ping you later - even if y'all can't help me directly I've found usually folks in the trades know each-other. I don't look for work on the side typically, when it's also a day-job. I'm open to it, but I never ask for it. Just seems wrong. House was actually built in '03. New foundation (deeper, longer than the traditional Chicago house, still standard 25x125 lot...) so we don't get the tax break for being on an old foundation. I've already replaced the outlet, twice. Should be wired right, I tested for hot. Next step is to run a fish tape through to see if it catches on anything (test for breaks in the conduit best I can). Hope to avoid trenching since the line goes under the cement poured-in-place A/C pad (only one of two units is still on it... it was placed under the deck, stupidly... that's bad for condensers - and it HAD to be under something because it's actually below the back door...) I've probably messed up code on the DIY front already... had to move some walls and outlets. Had to cap a gas line (I had that work checked... actually asked the guy to fix it and he said it was done right - he still fixed a bad waste-water joint that was leaking at the washer drain...) I try to read all the rules and stick to them, but... More fun is trying to figure out how to get new conduit to the front of the house for the home theater. The existing conduit is at capacity. Yay home ownership.
The Following User Says Thank You to cjd For This Useful Post: | soundman98 (04-06-2019) |
04-06-2019, 06:11 PM | #54841 |
Dismember
Drives: 2013 Red Scion FR-S
I schooled my CPA and saved myself big bucks in taxes. Where should I donate half the ill-gotten gains?
04-06-2019, 06:15 PM | #54842 |
ProCrastinationConsultant
to me. let me know when you need my paypal.
04-06-2019, 06:18 PM | #54843 |
there's a lot of cast in the suburbs as well. but most suburbs now allow you to convert to pvc.
04-06-2019, 06:22 PM | #54844 |
Dismember
I don't donate to lost causes.
The Following User Says Thank You to EAGLE5 For This Useful Post: | soundman98 (04-06-2019) |
04-06-2019, 06:41 PM | #54845 | |
humfrz |
04-06-2019, 06:43 PM | #54846 |
04-06-2019, 07:07 PM | #54847 | |
Drives: 2017 BRZ
Can't be any worse than running a 7x200 amp, a 700x2 amp, a 500x2 amp, a 1x200 amp, preprocessor, computer, and projector off a 20A circuit... (thank goodness for soft-starts! And never needing any of that power...)
The Following User Says Thank You to cjd For This Useful Post: | humfrz (04-06-2019) |
04-06-2019, 10:10 PM | #54848 |
what do you need a 7w x 200ch and a 1w x 200ch amp for?
04-06-2019, 10:15 PM | #54849 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
04-06-2019, 10:35 PM | #54850 |
Drives: 2017 BRZ
I have a 7.2 + shaker setup in the home theater.
7x200 is the main 7... 700x2 is for the 4x15" log throw (36mm xmax) sub in the front wall, 500x2 is the 2x15" long throw setup in the riser for the rear seats. And 1x200 on the front row shakers. The 7x200 is 100 lbs... Don't look at the pair of 1000W monoblocks I have on one of my other setups... Also on a 20a circuit also 100lbs each. I usually listen at maybe 1/4W output... Just a wee bit of headroom.
04-06-2019, 11:18 PM | #54851 |
¯\_(ツ)_/¯
I think this simulation has run its course. Back to the bridge.
04-06-2019, 11:39 PM | #54852 |
義理チョコ
Awaiting orders, sir.
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
